Old 12-21-2006, 08:25 AM   #1831
Winner's Circle's Avatar
Originally Posted by Pyramid
it does, but if you need more than 4 degree camber on the rear with short uppler link configuration, trimming rear uprights required (attachment noted).
Thanks for the reply. Right now I have enough rear traction with the upper rear pin in the default position. I usually run 3 to 3.5 degrees of camber on the left rear and about .5 mm less on the right side.
I want to try this option setting because I am going to be trying some DUAL COMPOUND FRONT TIRES in the near future. These tires will have an inner ring made from a softer compound that is intended to get to turn more. If this experiment works, I will offer these tires for sale through the Winner's Circle website http://gasrccar.com
I will test the tirese within the next 2 weeks weather permitting.
Lee Muse
[email protected]
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 12-25-2006, 05:56 PM   #1832
Greg M's Avatar
What clutch set up are you guys running? I've been running the kit set up with a crap engine, but am bolting some decent power in next week and wanted some ideas.
Greg M is offline   Reply With Quote
Old 12-26-2006, 12:15 AM   #1833
Paolo,
Could you post your set-up with the medium wheelbase? also can you tell us if you are running anything special.
Thank you.
Roedor is offline   Reply With Quote
Old 12-26-2006, 03:48 PM   #1834
hey
can anyone take some pictures of there fuel tank spring please
i have taken the lid of my fuel tank, and then forgot the way the spring was attached normally
thanks in advance
bigboss is offline   Reply With Quote
Old 12-26-2006, 04:05 PM   #1835
Team Kamikaze's Avatar
go to www.mytsn.com there are pictures showing the fuel tank as well as all the information you need
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 12-26-2006, 04:26 PM   #1836
thanks, but i tried there and i cant get any close ups to see how the spring is fitted into place
Old 12-26-2006, 09:44 PM   #1837
Greg M's Avatar
I have no camera, but can describe it. When looking from the front of the car, the spring comes down from the front left side to the tank and out the back on the right to the lid. Hope that make sense.
I'd like some info on what you guys are running for clutches, flyweights etc.
For some reason there doesn't seem to be alot of talk on these cars and it would be great for some factory drivers set ups and insights to be posted.
Old 12-27-2006, 04:39 PM   #1838
hey guys, was wondering if u guys can help again...
just built my s960 and have a problem setting up the ride height,
- i have set the front downstop value to 1mm.
- but the lowest ride height i can get is 10mm, thats 3mm higher then default set up,
could this be my tyres im runnin on, they are 72mm diameter.
any help?
thanks in advance
Old 12-27-2006, 04:51 PM   #1839
Greg M's Avatar
I've only mounted up a few sets of tyres, but from memory they are about 68mm, so I'd pick the tyres as the problem. I think the split should be 6mm between the size of your rears and fronts, so I normally have to true the fronts down to keep that split with the rears. I guess someone will correct me if I'm wrong.
Old 12-27-2006, 05:04 PM   #1840
Orfeous's Avatar
Send a message via ICQ to Orfeous Send a message via AIM to Orfeous Send a message via MSN to Orfeous Send a message via Yahoo to Orfeous
any help?
thanks in advance
Have you tried to read the setup-book and checked all suggestions?
Orfeous is offline   Reply With Quote
Old 12-27-2006, 11:06 PM   #1841
Racer Z's Avatar
any help?
thanks in advance
What color springs are you running on the car? Also what is your shock position?
RC AMERICA, HUDY, XRAY, Nexus Racing, Desoto Racing, 301 Raceway(RIP). XRAY T4/NT1 coming for that #1 spot!! AKA-Melvin Aulston
Racer Z is offline   Reply With Quote
Old 12-28-2006, 01:19 AM   #1842
i set the car up on all default set up, i fink i just have to double check for errors
Old 12-31-2006, 10:36 PM   #1843
jeff1's Avatar
does 960 fuel tank part. 902110 fit on vector 2000 radio plate? I broke the holder of spring
jeff1 is offline   Reply With Quote
Old 01-01-2007, 06:50 AM   #1844
Jeff,
The 902110 is a 950 tank which is slightly different thatn a 960 tank. The difference is in the area at the back right where the carburetor slide is. The 960 has a deeper recess to clear the carb slide.
The Vector tank is PN# 1430 and it is a completely different shape as far as the length and width and will not fit into the area provided on the radio tray.
I have both of these tanks in stock in case you can't fix what you have.
Happy New Year!
Lee Muse
[email protected]
Old 01-03-2007, 04:50 PM   #1845
avs
avs's Avatar
just built my s960 and have a problem setting up the ride height...
the lowest ride height i can get is 10mm...
...could this be my tyres im runnin on, they are 72mm diameter
thanks in advance
Yes, 72mm is a bigger tire, most fronts start at 70 but that only accounts for 1mm of excess ride height.
With the blue springs up front even with a minimum preload setting the front ride height is still on the tall side. The springs do sag a bit at first, so the ride height will settle a little, just run it.
also with the 960 parts, the spring retainers are now a much tighter fit to the rod end fittings, so verify that you have the rod end fittings bottomed out in the spring retainer.
avs is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
