Old 09-28-2006, 10:17 AM   #1696
duneland's Avatar
OK, here is the ultimate set-up for weight reduction:
Aluminum screws(titanium where needed), Hollow magnesium shafts (filled with hydrogen), LiPo receiver pack attached to magnesium plate!
duneland is offline   Reply With Quote
Old 09-28-2006, 12:09 PM   #1697
madbeats's Avatar
Default Periodic table
some body buy periodic table.
we need some general properties and data information.
Serpent 966/720 Mugen MTX4R Xray NT1-Mugen MTX-4 Knack R conversion Hong Nor X1CR
madbeats is offline   Reply With Quote
Old 09-28-2006, 01:02 PM   #1698
M7H
M7H's Avatar
Originally Posted by duneland
You must be thinking of hydrogen. Helium is not explosive.
No, it makes you talk strange.........
Serpent
M7H is offline   Reply With Quote
Old 09-28-2006, 01:50 PM   #1699
Orfeous's Avatar
Send a message via ICQ to Orfeous Send a message via AIM to Orfeous Send a message via MSN to Orfeous Send a message via Yahoo to Orfeous
Originally Posted by Darint
Aluminum screw set is by far the best bang for the buck when it comes to lightening the car. Lipo is nice, along with Titanium Pillow Balls.
Yes, but alu screws can only be used on parts of the car that dont have load or what the word is :P the screws can break.
so titan screws is maybe my choice.. and titan pivot balls.. but they are expensive i dont think iam gonna install a lipocell not right now.
but it had been fun to test.
Orfeous is offline   Reply With Quote
Old 09-28-2006, 02:42 PM   #1700
M7H
M7H's Avatar
Screws in my car are aluminium, and yes the can break, but there is a solution for that... don't crash.....
Titanium screws will also be torn out of the plastic parts in case of a crash, result is the same, your out of the race........
Serpent
Old 09-28-2006, 03:42 PM   #1701
Orfeous's Avatar
Ok, it's hard to not crash sometimes
as i said.. i am going to buy alu- and titan screws for lighten the car.
then maybe the new light steel axle. Then everything else doesnt do many on the weight as i know.?
Old 09-28-2006, 05:11 PM   #1702
Orfeous's Avatar
Pictures of my car
tips are welcome!
http://umea3.mine.nu/gallery2/main.php?g2_itemId=420
hope that the url works..
Old 09-29-2006, 06:51 AM   #1703
Send a message via MSN to PMSorber
Its best to only apply alu-screwsn above the chassis, if you do it below it will change your center of grafity (I hope this is typed correctly).
Regarding alu and Titan, if you apply alu and / or steel parts on a moving titanium surface it will wear quite hard. (bearings on a titan shaft).
These materials just do not mix on moving parts.
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 09-29-2006, 06:58 AM   #1704
Pictures of my car
tips are welcome!
1) Put your steeringrods on top, now they will get disconnected after a collition.
2) Lower your rear shocks to the carbon connection position.
If your circuit has hairpins: install the new lower rear wishbones and make your stabi more flexable.
@ConSult Trading
Old 09-29-2006, 07:35 AM   #1705
M7H
M7H's Avatar
It looks to me like you switched the front upper steering arms, so left and right are switched.......
Difficult to see, but from this picture I get this idea.
http://umea3.mine.nu/gallery2/main.php?g2_itemId=489
Serpent
Old 09-29-2006, 10:45 AM   #1706
Orfeous's Avatar
Okey, i see
Old 09-29-2006, 10:46 AM   #1707
Orfeous's Avatar
What do you mean with my steeringrods? i dont understand.
hairpins?
Old 09-29-2006, 02:18 PM   #1708
M7H
M7H's Avatar
hairpins?
Compare this picture with yours...
http://www.m7h.nl/m7h/950R_files/950-3.JPG
The steeringrod connection near your wheels, should be on top.......
Serpent
Old 09-29-2006, 03:00 PM   #1709
Exclamation
hairpins?
my words ... Just ask one of the Serpent guy's at your local track?
Your car need some adjustments if your track has some sharp 180-degrees turns. The rear of your car must be softer than normal in order to prevent the rear end to break out.
@ConSult Trading
Old 09-29-2006, 03:05 PM   #1710
Orfeous's Avatar
ok, i think i have a picture of our old track
but i must find it first
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
