Old 09-12-2006, 02:31 PM   #1666
Winner's Circle's Avatar
Originally Posted by going4#1
Anyone using the new ackerman set? I notice there is a lot of play between the set and the upper radio plate. I've stuck in a washer to help remove some of it but I was wondering if there was a method that didn't require extra parts.
The adjustable ackerman fit my car exactly like the original non adjustable servo saver.
There is a washer that is suppose to sit on top of the center post. It is machined out on one side. It is part # 902152 - radio plate spacer.
Lee Muse
[email protected]
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 09-12-2006, 10:21 PM   #1667
Default Aluminium Brake Pulley
Does anyone have an effective method for keeping the grub screw from coming loose from the aluminium brake pulley? I've tried locktight but it still gets loose. Very frustrating.
Thanks in advance.
going4#1 is offline   Reply With Quote
Old 09-13-2006, 07:00 AM   #1668
going4#1 Does anyone have an effective method for keeping the grub screw from coming loose from the aluminium brake pulley? I've tried locktight but it still gets loose. Very frustrating.
I used two shorter grub screws - put one in and tighten it down - then follow the first one with another grub screw and lock them together.
Never had one come loose this way.
Bob The Builder is offline   Reply With Quote
Old 09-13-2006, 10:56 AM   #1669
Originally Posted by sn4il
Hi.
How do You guys setup Your track width on 960 using Hudy Tweak Station??
My tweak station shows around 205mm (rear) instead 260-262?
What am I doing wrong?
Thnx
sn4il
Don't worry, you are not doing anything wrong. Your Hudy Station is working just fine. There is a 20mm offset for the front wheels and 30mm offset for the rear.
example: 205mm in the rear on the Hudy Station is a trackwidth of 265mm with the rear wheels installed on the car. (205+30+30=265)
example: 205mm in the front on the Hudy Station is a trackwidth of 245mm, with the front wheels installed on the car. (205+20+20=245)
Hope this helps.
Kendall is offline   Reply With Quote
Old 09-13-2006, 04:13 PM   #1670
sn4il's Avatar
Hope this helps.
Thanks a lot Kendall.
This is exactly what I was looking for.
sn4il is offline   Reply With Quote
Old 09-13-2006, 07:54 PM   #1671
Bob, the shortest grub screw I can find is 3mm long x 4 mm wide. Are there grub screws 2mm x 4mm?
Old 09-15-2006, 07:53 AM   #1672
avs
avs's Avatar
Originally Posted by emankov
Hi all
Sorry for my noobness but i have a small question regarding 960 assembly...
After completion of step 1.5, i have an horizontal "endplay" of the axle, of about 0.3 mm..Is this normal, or the axle should be rock solid with no horizontal movement watsoever?
There are shims supplied that you can stack on the inside or out of the steering block. i believe i used 3 total on each block. see related picture on page 46 of this thread. (you don't need the conical washer, just 3 of the thin 'washer' supplied.
avs is offline   Reply With Quote
Old 09-17-2006, 10:07 PM   #1673
Default rev coming out
it was nice to see Chris Verano out this weekend running a 960 after his 2 month off of 1/8 he still has it. he should do well at the Kyosho race
Bryon
bestindebt is offline   Reply With Quote
Old 09-17-2006, 10:46 PM   #1674
Trader Rating: 17 (100%+)
Any of you guys heading to Cincinnati for the 1/8 Nationals in October?
seabass2500 is offline   Reply With Quote
Old 09-18-2006, 01:08 AM   #1675
going4#1
I use a dremmel to shorten them when I can't get hold of the correct length screws.
Old 09-18-2006, 12:00 PM   #1676
Orfeous's Avatar
Send a message via ICQ to Orfeous Send a message via AIM to Orfeous Send a message via MSN to Orfeous Send a message via Yahoo to Orfeous
guys!
have you seen those "new" parts that has been released?
http://www.mytsn.com/products/
the new lightweight steel middle axle...
the new wishbones.. etc..
Orfeous is offline   Reply With Quote
Old 09-18-2006, 08:01 PM   #1677
Originally Posted by Orfeous
guys!
I hear a new 2-speed shaft is coming out soon as well. Should be interesting . . .
Old 09-19-2006, 04:06 PM   #1678
Orfeous's Avatar
yes, that should be nice
Old 09-23-2006, 08:46 AM   #1679
Default Leaky fuel tank
Anyone using the new fuel lid? Anyone getting a leak? After putting on the new lid my fuel tank now leaks from the rear of the new lid. The leak isn't super serious but I'd rather not have it. Any solutions? When is the new 125cc with silcon ring lid coming out?
Old 09-25-2006, 04:45 AM   #1680
Send a message via MSN to PMSorber
Default sideplate bearing
no, it isnt enough..
It depends if you also have installed the new bearingblocks with 3 bearings. If you have not, the play on this outer-bearing will be to much and will never be locked. I just sand both metal parts a bit and the glue it with pattex instand glue.
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
