Old 09-09-2006, 03:19 PM   #1651
I installed the new side stiffner set #903205 but found that with the aluminum pulley it did not spin freely. I had to go back to the original plastic pulley.
robd is offline   Reply With Quote
Old 09-10-2006, 04:55 AM   #1652
Orfeous's Avatar
Send a message via ICQ to Orfeous Send a message via AIM to Orfeous Send a message via MSN to Orfeous Send a message via Yahoo to Orfeous
the new sideplate with alu spacer isnt good. the bearing got play
Orfeous is offline   Reply With Quote
Old 09-10-2006, 08:27 AM   #1653
Rob, I actually filled down the pulley so it could sping freely. That worked for me.
going4#1 is offline   Reply With Quote
Old 09-10-2006, 08:45 AM   #1654
sn4il's Avatar
Default Track width
Hi.
How do You guys setup Your track width on 960 using Hudy Tweak Station??
My tweak station shows around 205mm (rear) instead 260-262?
What am I doing wrong?
Thnx
sn4il
sn4il is offline   Reply With Quote
Old 09-10-2006, 10:40 AM   #1655
Send a message via MSN to PMSorber
You have to glue the bearing with 2 small drops.
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 09-10-2006, 05:14 PM   #1656
captian's Avatar
ya i ran into the same thing round off the pulley . and you will be fine.
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 09-10-2006, 07:27 PM   #1657
What kind of glue did you use? Is it okay to use C.A Instant Glue (the kind you use with tires)?
Besides the fit issue with the aluminium pulley, I found the side an excellent addition to the 960. Acceleration does seem stronger with the plate.
Old 09-10-2006, 07:32 PM   #1658
Originally Posted by M7H
My shoes where on the pins, as I think they react more agressive then, being pushed by the pin ofcourse and not trailing the pin......
I don't spend a lot of time (money) in practice, I only race, so don't have a lot of time (money) to experiment.....
But my next experiment will be, to put another grubscrew in and place the weights between the pins, as they are shorter and they can be placed in between......
Tried it this weekend. In-between pins, with grub screw, spring is 10mm 1.8, and gap is 0.55. Tension on spring is 1.5. The car is very quick with this setup but still looking for a bit more punch.
Old 09-10-2006, 07:41 PM   #1659
Orfeous's Avatar
no, it isnt enough..
Old 09-10-2006, 10:21 PM   #1660
ghoppa's Avatar
Trader Rating: 54 (98%+)
Default RC Pro Race #4-Las Vegas
I just want to say "GREAT JOB" to Mr. Steven Jackson out of Las Vegas, Nv for a great showing with his Maxy Pro Race Fueled/Serpent 960 this past weekend here in Vegas for the final leg in the RC Pro Series-Western Division.....
If it wasn't for receiver pack failure, he would have been on the podium....
It's been a long time since I've seen him pilot a car the way he did this past weekend and it's only getting better
"Now lean out that Motor"
R1 Wurks - ActivRC - ApexRC - P1 Brands
ghoppa is offline   Reply With Quote
Old 09-10-2006, 10:29 PM   #1661
I wonder, if lock-tight works with metal screws on metal holes, would it work for a metal bearing on a metal surface?
Another thing you might try is sanding away a bit of the coating on the bearing holder and glue at that position. The bearing holder looks like it is coated with something. Perhaps a heat resistant material? The coating may be smoother than bare metal and resistant to the effect of an adhesive (i.e. a non-stick coating).
Old 09-10-2006, 10:32 PM   #1662
Default New ackerman set
Anyone using the new ackerman set? I notice there is a lot of play between the set and the upper radio plate. I've stuck in a washer to help remove some of it but I was wondering if there was a method that didn't require extra parts.
Old 09-11-2006, 03:12 AM   #1663
Orfeous's Avatar
rotating bearings are never good with alu.. it will be worned out with time.
and make irritating play.
i use the original sideplate.. and original middleaxle holder.
Old 09-12-2006, 02:06 AM   #1664
emankov's Avatar
Hi all
Sorry for my noobness but i have a small question regarding 960 assembly...
After completion of step 1.5, i have an horizontal "endplay" of the axle, of about 0.3 mm..Is this normal, or the axle should be rock solid with no horizontal movement watsoever?
emankov is offline   Reply With Quote
Old 09-12-2006, 01:40 PM   #1665
captian's Avatar
i am useing it and the little play is good so you don"t have any binding when the streering is under load .and it let the spring have some play to do its job.
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
