Serpent 960....
#1531
Originally Posted by michael 1
duneland, put the front swaybar back try 45. front shock mid. also try 1 mm
shim on front roll center this shoud give more steering at entry and mid corner
also try mounting the body a little more forward and less caster
on the rear a little more sway bar angle , ride ht 1 mm split between front and
rear( lower on front )
#1532
960 custom
Hi. here is some photos of my custom 960 ..
#1533
960 custom
& a few more ..
#1534
Registered User
very nice. you have given me some ideas
#1535
serpent 960
Thanks... If you get time check out the 200mm outlaw car I poasted to day ..
#1536
reminds me of the veteq with the side rails . nice work
#1537
Originally Posted by duneland
OK, maybe someone can point me in the right direction here. I will list my current set-up. I have not been able to get enough steering (mostly concerned with entry & apex).
Front;
50wt (serpent oil) 3 holes/red springs
lower hole on tower
Sway bar disconnected
Dynamic caster set-up (this helped some, would have to post pics but it reduces caster as suspension is compressed).
35sh Serpent/Jaco
Short wheelbase helped, but had to go back to long for exhaust clearance.
0mm roll center spacers
Rear;
50wt. 2 holes/blue springs
Upper hole on tower
20 degrees or so sway bar
38sh Serpent/Jaco
middle roll center position for lower pins
I have adjusted toe & camber settings through the normal range.
I have also moved a bit of weight forward (1 once of lead to front of battery tray, LiPo battery behind the lead. Result is same weight as NiMh but slightly more forward).
The Jaco 38's test 2-3 points softer than the Jaco 35's! Will try 40 rear/35 front.
Any other ideas?
Front;
lower hole on tower
35sh Serpent/Jaco
Rear;
Upper hole on tower
38sh Serpent/Jaco
Any other ideas?
#1538
mega zx21 ds II
i ran the engine sat at rev ad sunday at the club race I had some bad luck at the start i got hit and my ins box came off so i had to come in to reinstall the ins box. i will do beter next time. the engine is fast out of the box it is a good choice i made with the purchase . the car worked really well i needed harder tires i only had 40's it was a little soft i will try 42's next time .
bryon
bryon
#1539
bryon
bryon
man your pitman is fast.
HAHAHA
#1540
..Any other ideas?
..Any other ideas?
#1541
avs- Adding the lead to the front of the tray, improved steering. Just not enough to suit me.
Darrint--Will try more holes &or lighter oil. The dynamic caster is achieved by installing ball studs on the upper arms (near the hinge-pin area) & another set of ball studs on the upper plate @ 45 deg. angle to the rear. Connect with a turnbuckle. All caster spacers are removed. As you get deeper into the corner & chassis roll increases, you get a reduction in caster. Increase or decrease the overall amount of caster by adjusting the turnbuckles. Dan Louis came up with the system. I got an immediate improvement in overall steering when I installed it (want more tho).
Will try adjusting roll-centers and shock pistons/oil today.
Thanks for the suggestions.
#1542
#1543
Anyway, new rear lower arms will be available soon. Beside being stiffer, the difference will be the sway bar attachment point (more toward the wheel)
Paolo
#1544
Thanks Paolo, I may have those blocks in stock. I'll order the new arms soon.
#1545
I mean which way does the upper arm move while lifting the wheel, does it go forward?, so less caster angle of the wheel on the track?
