Serpent 960.... >
Serpent 960....
Serpent 960....
Old 08-04-2006, 09:20 AM
  #1501
i am fan of lipos in the transmiter, just dont really see the advantage
of taking weight out of the lowest and center part of the car
too me this seems counter productive if i was looking to save weight
it would be in the upper deck and in rotating mass (serpents light wt.
pully adapters- alum. (upper only) pivot balls- alum.mid shaft
just my thoughts
michael 1 is offline
Old 08-04-2006, 09:38 AM
  #1502
duneland's Avatar
I agree. The car was designed with the weight of a 5 cell pack in mind. By adding the weight to the front of the tray, I brought my rx pack back to the intended weight & shifted it slightly forward. End result is a much better power supply & weight distribution more favorable to steering.
Switching to LiPo for a weight savings, seems like a bad idea to me. It does offer a much better power supply though & gives one the freedom to adjust the fr/rear weight bias.
duneland is offline
Old 08-04-2006, 01:40 PM
  #1503
Perez's Avatar
When I ran my Evolva I really did not notice the difference between running the stock AA batteries compared to the AAA batteries. I tested it back to back and just couldnt see or feel any handling differences. The AAA were considerably lighter and always held enough juice for the mains. I bought some AAA's to try out on my 960. Anyone else do this?
Perez is offline
Old 08-04-2006, 01:59 PM
  #1504
Winner's Circle's Avatar
Default batteries
I tried the same thing plus I tried Lipoly batteries which were significanly lighter and I could not tell a difference in performance either.
Winner's Circle is offline
Old 08-05-2006, 07:28 AM
  #1505
if i had a 960 i dont think i had felt any difference with any weight changes..
Orfeous is offline
Old 08-05-2006, 09:10 AM
  #1506
Racer Z's Avatar
The 960 seems to rotate thru the corners better with the lipo but give me a nervous feeling like the car is about to become unglued. I like the 5 cells better. Car feels more planted and stable thru all areas of the track. Just my 2 cents
Racer Z is offline
Old 08-05-2006, 10:25 AM
  #1507
duneland's Avatar
I noticed a significant difference when I added the weight to the front of the tray. Corner speed & lap times improved.
Wouldn't think of going back to NiMh! Hell, I could forget to bring my charger & be OK for the whole weekend!
duneland is offline
Old 08-05-2006, 04:23 PM
  #1508
Racer Z's Avatar
Isn't that the truth
Racer Z is offline
Old 08-05-2006, 04:25 PM
  #1509
Racer Z's Avatar
Has anyone tried the Ceramic bearings in the 960? Also if so do you run it with the grease in the bearings or pop the shields out and use oil instead.
Racer Z is offline
Old 08-07-2006, 02:31 PM
  #1510
I purchased my ceramic bearing kit from Acer Racing. When I first installed them on my 960 I used the grease that came with them. I ran the new bearings like this for a few races until everything got run in and it was very smooth. Before my third race I took them out, removed the shields and cleaned them with electric motor spray, then oiled them with the Serpent oil, and re-installed them back on the car. I remove and clean them every few races or so and have had no trouble at all.
Kendall is offline
Old 08-07-2006, 02:51 PM
  #1511
seems like a good process!
there should be cheramic bearings everywhere
Orfeous is offline
Old 08-07-2006, 09:19 PM
  #1512
Default mega dsII ZX21
thanks Roniel Chris shimed the engine sat at rev its almost broken in
I am very impresed it hase a very smooth power band its getting fast i ran out of time sat but i wished i have more DS II 's now i just need to figure out how to sell my rex engines i have 1 tuned and 2 Mrio rossi broken in i will perfer to run the DS II's now
THANKS AGAIN RONIEL fo the help BRYON
bestindebt is offline
Old 08-07-2006, 11:00 PM
  #1513
Trader Rating: 4 (83%+)
Hey Bryon:
Nice to hear you are enjoying power of the new DSII engine,i myself was really impressed on its performance from the previous ZX engine,dont to hesitate to shoot me a call on anything you need..
Roniel
Roniel_R is offline
Old 08-07-2006, 11:55 PM
  #1514
Those mega engines seems to be awsome! are they?
Orfeous is offline
Old 08-08-2006, 06:34 PM
  #1515
Roniel I will keep you posted on the engine I will be running it on sat for pratice and club race on sunday say hi to everybody in Florida for me
thanks Bryon
