Old 11-13-2005, 05:46 PM   #121
Super Moderator
Snowy's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Rich Browne
As a note: We will be making:
A) Hardened Aluminum Pullies for the Evolva -
B) Our rear sway bar assembly (must have for the serious racer) and a
C) Digital depth gauge for measuring "head clearance" and motor stroke. 21 motors only
Hi Rich,
Cant wait for the rear sway bar assembly to be available, looks good. Did I see Josh Cyrul using this as well? I have noticed lately that the adjustable swaybay moves from side to side a bit, is this why you guys dont use it?
Also, re: Delta no battery slot chassis. What is the part number for this? Can you still use the standard kyosho battery pack with this chassis?
Regards
Snowy
Snowy is offline   Reply With Quote
Old 11-13-2005, 06:33 PM   #122
Originally Posted by Snowy
Hi Rich,
Regards
Snowy
The Rick Davis designed sway bar doesn't tweek like the Kyosho rear adjustable. Josh, Scott and Ralph all used our sway bar at the Nat's.
The Delta Chassis is a Delta unit - I believe Dave Campbell (Delta) did 50 chassis. I don't know if it's a "sale" item. It is very ridged - but, you must mount the battery in the chassis.
Rich Browne is offline   Reply With Quote
Old 11-13-2005, 07:45 PM   #123
Hi Mike,
We replace rods every 1.25 gallons. No need to change your rod after break in - unless you hydrolock or something odd like that. The following URL is Rody's break-in procedures: http://tinyurl.com/bk43j
Good luck with the motor. Let me know if I can help when you have it running. We gear the motor very low and spin it up pretty high. The pipe and header is very important to end use. Good luck!
Rich
Rich, Thanks for the link great info! What is a good pipe and header combo. I have a max power 2018 pipe with a medium or long conical header, will this work .Thanks, Mike
rc racing dude is offline   Reply With Quote
Old 11-13-2005, 07:55 PM   #124
Default RB power
The 2018 is a good pipe. We use it in milage situations. Thr 1005 RC likes the 9886 pipe with a seven ring conical. You might get the 4 dot, pyramid shape, High Compression head from Nova Rossi. Be sure you ask fot the 4 dot version.
Old 11-24-2005, 09:34 AM   #125
Does anyone know what is the best battery receiver pack to use with the 05 Evolva. Thanks,
Old 11-24-2005, 01:26 PM   #126
Arno's Avatar
I use a pack that has 5 AA 2000 mah cells, and I go through a full race day and still have juice in the pack. And keep in mind that I use 2 digital servos that drain more power than the regular sevos.
Arno is offline   Reply With Quote
Old 11-24-2005, 01:48 PM   #127
ogreasurada's Avatar
So why do they bother to use sub-C cells if AA has more capacity?
ogreasurada is offline   Reply With Quote
Old 11-24-2005, 02:24 PM   #128
Arno's Avatar
I have no idea but I know that you can even get AA's up to 2600 mah and those last forever.
Old 11-24-2005, 02:25 PM   #129
Arno's Avatar
On some cars you cannot fit AA's that's why they use sub c's or AAA's.
Old 11-24-2005, 03:36 PM   #130
Hm...then how come the designers dont make the car equip AA at the first place? Is it because AA is heavier than Sub-C?
Old 11-24-2005, 09:49 PM   #131
Arno,
Racing at CP for TFT race?
Edwin
manokgt4 is offline   Reply With Quote
Old 11-25-2005, 01:41 AM   #132
Arno's Avatar
Originally Posted by manokgt4
Arno,
Edwin
What's up Edwin,
For sure I'll be racing at TFT. We are going to be there tomorrow moring (Friday) just to practice try to come.
Old 11-25-2005, 01:45 AM   #133
Arno's Avatar
That's probably why. I had 5 AAA's before and my car was way under weight from legal, so I put the AA's and it is just right.
Old 11-25-2005, 12:35 PM   #134
I just bought the 05 Evolva from rc-toro. The box only said it was the 03 world champion. Shouldn't it say 05 champion also? How can I tell it is 05 not 03 Evolva?
silverM3 is offline   Reply With Quote
Old 11-25-2005, 12:42 PM   #135
On the outside of the box it sould say this box was open and resealed by kyosho America. Stated that this kit has been upgraded to 05 specs. If it does not you have just the old 03 evolva kit
WTS: Kyosho Evolva 2005 GT Racer R/C Items: For Sale/Trade 1 11-06-2006 06:45 PM
Kyosho Evolva 2005. RcXtion Malaysian R/C Racers 32 09-20-2006 10:47 AM
Kyosho Evolva 2005 kit $250.00 skriete R/C Items: For Sale/Trade 3 07-25-2006 01:18 PM
2005 Kyosho Evolva New in Box ATOMIC R/C Items: For Sale/Trade 0 05-01-2006 09:07 PM
New in Box 2005 Kyosho Evolva $550.00 ATOMIC R/C Items: For Sale/Trade 5 04-30-2006 09:57 PM
