Old 04-09-2006, 02:12 AM   #316
luketob's Avatar
Great! Thanks for the info guys
luketob is offline   Reply With Quote
Old 04-10-2006, 11:38 AM   #317
Tim Johnson's Avatar
Exclamation
Evolva 2005 WC edition #31285b
will be in stock the week of April 25th, for USA.
_______________________________________________________
Support your Local Hobby Shop, because you can't race on Ebay!
Airtronics|Kyosho|
Tim Johnson is offline   Reply With Quote
Old 04-11-2006, 01:37 PM   #318
Grenade10's Avatar
Trader Rating: 37 (100%+)
I purchased an 2005 Evolva new to get back into 1/8 gas after being out of it for 13+ years. All I can say about the kit, is what a change!!! KIt built well out of the box, not like the old kits.
I do have a question as to how to get more turn in with the car. I'm not sure about coming out of the corner as the clutch was not set correct and the clutch was set to loose. However, it was consitant. I was running the setting pretty much as it was shipped. I did change to gray front springs, but still had the black rears in the car. I was running 35's all around.
One area that I know would help would be to use a new body. I had 3 or 4 unused Lolas for the early 90's. I did compair to the new and what a change. The front is almost 1" shorter and the back is 1-1/2" taller.
Thanks for any input.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 04-11-2006, 02:42 PM   #319
Go with the Dome Body - it is awesome. This site is a collection of set-ups and tips:
http://empirercracing.com/blog.html
Rich Browne is offline   Reply With Quote
Old 04-11-2006, 03:40 PM   #320
Thumbs up
Evolva 2005 WC edition #31285B
Has arrived early. They are now ready to ship.
Airtronics|Kyosho|
Old 04-11-2006, 04:36 PM   #321
Tim
Do you know part numbers for these new parts in the WC Kit?
Rear Suspension Holder
Knuckle Arms (EVOLVA) Angle 0
Fuel Tank
ElliotCanada is offline   Reply With Quote
Old 04-11-2006, 04:57 PM   #322
Originally Posted by ElliotCanada
Tim
Fuel Tank
This is a current Parts list - it's a pdf with all the "new" numbers
Old 04-11-2006, 05:23 PM   #323
Super Moderator
Snowy's Avatar
Trader Rating: 14 (100%+)
Tim
Fuel Tank
With the rear suspension holders, you have to purchase 2 x FM533-35. They dont come as a pair.
The knuckle arms do come as a pair: FM503-0.
Is there a new tank??? What is the part number of this?
As anyone noticed after fitting the new suspension holders how much you have to wind out the pivot balls to keep the same rear width as before? It doesn't leave much thread left in the arms.
Snowy is offline   Reply With Quote
Old 04-11-2006, 06:30 PM   #324
Tim
Fuel Tank
FM533-35 REAR SUSPENSION BLOCK
FM503-0 FRONT KNUCKLE 0
FM510C FUEL TANK
Airtronics|Kyosho|
Old 04-11-2006, 08:26 PM   #325
Thanks Rich and Tim.
Old 04-11-2006, 09:02 PM   #326
Grenade10's Avatar
Rich,
Thanks for pointing me in the right dirrection. I have already purchased several Empire parts for the car. I have not put them on yet, thought I'd get a base line feel for the car and then make the change.
I'll check out the Dome body.
I used to run a Serpent Sprint long wheel base 6010 in 2wd. Racing with the guys from C. Springs really helped get me quick before, I was glad to race with them again, even if they went by me like I was driving a Pacer!!!
Old 04-19-2006, 08:05 PM   #327
New Mugen / Kyosho wheels available
Serpent USA is pleased to introduce our line of tires for Mugen and Kyosho 1/8 scale. The wheels has being manufactured for this brands with our latest design and are mounted on Jaco rubber. The quality of the wheel is the same as the version for Serpent cars. They will come in both white and yellow at the beginning. Attached you will find a picture of the new Serpent wheel. The design is the same. This tires will be distributed exclusively by Serpent USA
Tires should be available early next week. Your LHS should have it during next week.
Serpent USA
Paolo M is offline   Reply With Quote
Old 04-19-2006, 10:55 PM   #328
FM510C FUEL TANK
So are there the only parts difference from a regular Evolva 05? where can I get these parts? Thx.
silverM3 is offline   Reply With Quote
Old 04-20-2006, 06:16 PM   #329
Super Moderator
Snowy's Avatar
There a number of upgrade parts as well, enough to justify having an upgrade kit. The picture below are the parts included in the upgrade kit.
Old 04-21-2006, 09:58 AM   #330
Code:
FM503-0
 Knuckle Arm (0 degree)
FM510C
 Fuel Tank with air room cap
FM531-4319
 Front Spring (4.3-1.9/White)
FM532-5319
 Rear Spring (5.3-1.9/White)
FMW8B
 SP Middle Belt (420)
FMW9B
 SP Rear Belt (201)
FMW20
 Off-set Spacer
W6002
 Titanium Shcok Shaft (30)
W6008
 Titanium Shcok Shaft (33)
FMW25
 SP Front Belt (207)
APP01
 APP Brake Rotor & Pad set (32x4mm)
FMW26
 SP Front One-touch Stopper 2
FMW27
 SP Rear One-touch Stopper 2
VZW064
 Lightweight 1st Gear Housing
FMW29
 Rear Universal Swingshaft
FMW34
 Adjustable Servo Saver
FMW36
 Front Universal Swingshaft
FMW37
 Aluminum Middle Shaft Mount
FMW38
 Aluminum Body Mount
FMW39
 Aluminum Front Upper Arm Mount
FMW533-35
 New Rear Hinge Pin Blocks
these are the parts that are added to the WC.
Also here is a list of Kyosho Red Box tyres for the Evolva, that are ready to ship.
Code:
36223-32       	1/8 Foam Tires (#32) Front    	$30.99
36223-35       	1/8 Foam Tires (#35) Front    	$30.99
36223-37       	1/8 Foam Tires (#37) Front    	$30.99
36223-40       	1/8 Foam Tires (#40) Front    	$30.99
36223-45       	1/8 Foam Tires (#45) Front    	$30.99
36224-32       	1/8 Foam Tires (#32) Rear     	$34.99
36224-35       	1/8 Foam Tires (#35) Rear     	$34.99
36224-37       	1/8 Foam Tires (#37) Rear     	$34.99
36224-40       	1/8 Foam Tires (#40) Rear     	$34.99
36224-45       	1/8 Foam Tires (#45) Rear     	$34.99
Airtronics|Kyosho|
WTS: Kyosho Evolva 2005 GT Racer R/C Items: For Sale/Trade 1 11-06-2006 06:45 PM
Kyosho Evolva 2005. RcXtion Malaysian R/C Racers 32 09-20-2006 10:47 AM
Kyosho Evolva 2005 kit $250.00 skriete R/C Items: For Sale/Trade 3 07-25-2006 01:18 PM
2005 Kyosho Evolva New in Box ATOMIC R/C Items: For Sale/Trade 0 05-01-2006 09:07 PM
New in Box 2005 Kyosho Evolva $550.00 ATOMIC R/C Items: For Sale/Trade 5 04-30-2006 09:57 PM
