Old 02-23-2006, 11:32 PM   #226
SteveP's Avatar
You can still use the Serpent starter, you just need to pitch the old adapters that don't even work on the Serpent cars anymore and get the univeral adapters for the Serpent starter box. Here's the info for the univeral adapters:
http://www.mytsn.com/products/product.asp?prid=897
SteveP is offline   Reply With Quote
Old 03-01-2006, 11:35 AM   #227
ziggy12345's Avatar
Im just completing the Evolva 2005 and am using some parts from the XR-8. the receiver box (sealed) from the XR-8 fits straight in along with the PT mount and the switch mount. These parts made it really neat and tidy
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 03-01-2006, 11:38 AM   #228
jeffreylin's Avatar
R/C Tech Charter Subscriber
Default Collari Worlds
In case you all missed it, here is Collari's setup at the 2005 worlds. Check out the size of the pinion he uses
jeffreylin is offline   Reply With Quote
Old 03-01-2006, 12:02 PM   #229
ziggy12345's Avatar
Link not working
Sponsored by:
Norfolk and Chance
Old 03-01-2006, 12:08 PM   #230
jeffreylin's Avatar
Originally Posted by ziggy12345
Link not working
Try this:
Old 03-01-2006, 01:06 PM   #231
ziggy12345's Avatar
Hi
I just tried setting up the evolva and I put on new tyres at the back 79mm Dia. The suspension binds up before the chassis bottoms out. Is there a max tyre dia you can use? It looks like you need 76mm as a max.
Cheers
Sponsored by:
Norfolk and Chance
Old 03-01-2006, 01:42 PM   #232
luketob's Avatar
Hi
Cheers
Check your rear swaybar, sounds like the ballend caps that connect the swaybar sit too high and touch the brake lever when you press the car down. I cut my tires 74 rear and 68 front fresh out of the box.
luketob is offline   Reply With Quote
Old 03-01-2006, 02:09 PM   #233
You might also want to look at the rear bodymount centering pin - may have to elongate the hole in the mounting bracket upwards to allow enough travel for large tires. Excellent car good luck.
Rick Davis is offline   Reply With Quote
Old 03-01-2006, 02:13 PM   #234
ziggy12345's Avatar
The sway bar is not connected and i dissconnected the body mount. It still does it. I will just have to use 76mm tyres
Cheers
Sponsored by:
Norfolk and Chance
Old 03-01-2006, 02:15 PM   #235
Old 03-01-2006, 02:49 PM   #236
Didn't intend to double post - guess that's the last time I'll use the preview feature! Next place to look is the dogbone pins bottoming in the spool slots - almost forgot about this cause I ground mine very early on to try the car very narrow in the rear.
Old 03-01-2006, 04:04 PM   #237
Super Moderator
Snowy's Avatar
Trader Rating: 14 (100%+)
Notice the different Suspension Holder, 7-3.5in, that Collari uses? I have been told that Kyosho will release these in the next few weeks.
Below are some pictures of my Evolva at the recent 200mm Nitro pre-worlds. They included 8th scale in the program as well.
Snowy
Snowy is offline   Reply With Quote
Old 03-01-2006, 06:45 PM   #238
carkillaii's Avatar
Snowy
Sweet Ride
carkillaii is offline   Reply With Quote
Old 03-02-2006, 12:11 AM   #239
Perez's Avatar
hey guys, I just got some 2005 parts in and the upper arms appear to be the same lenght and width as the old ones. Also the measurements on the new bulk head are the same as the old. If im using the empire belt tensioner, i dont really need the new bulkheads right? please correct me if im tripping.
Perez is offline   Reply With Quote
Old 03-02-2006, 01:23 AM   #240
ziggy12345's Avatar
I found the problem. The small 3mm grub screw that holds the tyre retaining clip on the wheel pin came off and was in the axle binding up the drive shaft. It came out when I took the rear to pieces
I lowered the shocks and it feels better now
Cheers
Sponsored by:
Norfolk and Chance
WTS: Kyosho Evolva 2005 GT Racer R/C Items: For Sale/Trade 1 11-06-2006 06:45 PM
Kyosho Evolva 2005. RcXtion Malaysian R/C Racers 32 09-20-2006 10:47 AM
Kyosho Evolva 2005 kit $250.00 skriete R/C Items: For Sale/Trade 3 07-25-2006 01:18 PM
2005 Kyosho Evolva New in Box ATOMIC R/C Items: For Sale/Trade 0 05-01-2006 09:07 PM
New in Box 2005 Kyosho Evolva $550.00 ATOMIC R/C Items: For Sale/Trade 5 04-30-2006 09:57 PM
