Old 02-13-2006, 11:57 PM   #196
nikoskar's Avatar
Originally Posted by Rich Browne
I would suggest a front belt tensioner (empirercracing.com). Plus, there are belts on the market that break easily. Run the FM 538 front Kyosho belt.
Your two speed should work well - Here are some items to check: A) be sure to check that the first and second gears aren't tight and binding. There should be .008" of clearance between FM328-1 and FM 539. B) across the entire two speed shaft, there should be .005" play. Or, push the two speed shaft, in and out - the entire assembly should have play - not too tight. C) Your air gap should be minimal - between the second gear housing and the two speed shoes - no contact - but, damn close - use the "small set-screw" to set - evenly top and bottom. D) Bottom out your adjusting spring (FM423) - now back both out 2.25 turns. You should be close.
Good Luck
Thank you very much for your help. I check it.(The front belts that have breaked is the original kyosho. I contact you again when i check it.
nikoskar is offline   Reply With Quote
Old 02-14-2006, 08:18 AM   #197
If you want help (I'll do my best) - feel free to eMail me at: [email protected]
Rich Browne is offline   Reply With Quote
Old 02-18-2006, 09:06 AM   #198
bsmooth's Avatar
Trader Rating: 17 (100%+)
Default tires
..Could someone tell me what tires everyone likes for the Evolva, where you get them, and does anyone offer a quantity discount? I'm looking at buying enough for the season.
Thanks in advance for any help.
-Steve
bsmooth is offline   Reply With Quote
Old 02-18-2006, 10:36 AM   #199
-Steve
Jaco's or Kyosho Red Box
Contact Ace Hobbies - Jr or Kevin good prices, good guys
Old 02-18-2006, 05:26 PM   #200
I heard you guys are working on the new rear lower suspension pin holder. Have seen some factory Kyosho guys running different suspension holder. What's the difference with yours and when will it come out?
slide_228 is offline   Reply With Quote
Old 02-18-2006, 06:07 PM   #201
We have two upper front holders coming out. One is based on the 2005 design - except it can be lowered by 3 mm and will not bend like a similar product. The second, a 2003 derivative, has the pin hole location inboard slightly (compared to the '03). It can also be lowered by 3 mm over the stock unit - plus, it won't bend.
The rear block you are inquiring about is still a prototype.
Old 02-18-2006, 07:18 PM   #202
Arno's Avatar
Default Two speed shaft
Does anyone have a problem with their two speed shaft bending all the time? And what do you do to prevent that from happening?
Arno is offline   Reply With Quote
Old 02-18-2006, 08:25 PM   #203
They do bend easily. It doesn't seem to cause any issues. As a suggestion - this will make the two speed "hit" a little softer (perhaps slowing the "bending"). Reduce the air gap between the second gear housing and the two speed shoes. Adjust until the shoes make contact - then back out so there is no rubbing. Be sure that both shoes are adjusted the same.
Old 02-18-2006, 09:37 PM   #204
Arno's Avatar
Thanks Rich,
Does anyone make a lightened two shaft that might be stronger than the stock one?
Old 02-19-2006, 07:19 AM   #205
Thanks Rich,
Nothing for sale that I'm aware of.
Old 02-20-2006, 09:50 AM   #206
bsmooth's Avatar
Default screw kit
..Does anyone know of screw set for the Evolva that is the same color (black) as the kit screws?
Thanks ,
Steve
Old 02-21-2006, 12:03 AM   #207
luketob's Avatar
Hi guys,
I need help finding tires for my evolva, i've been looking my LHS and online stores but only could find 35's and 37's shores...i'm looking for 40's shore tires. Maybe someone can tell me where to get them.
thanks
luketob is offline   Reply With Quote
Old 02-21-2006, 12:08 AM   #208
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Originally Posted by luketob
Hi guys,
thanks
I'm sure that Dana will be getting tires for you very soon.........
By the way, your car was looking really good today, seriously
Walter Diaz
wad is offline   Reply With Quote
Old 02-21-2006, 12:33 AM   #209
luketob's Avatar
That's nice to hear it Walter, i'll check with Dana when he's going to have them. My car is running great today, i'm getting the hang of it but still need alot of improvement in driving department . Thanks for helping me with the car.
Old 02-21-2006, 06:02 AM   #210
Send a message via Yahoo to speedy100
Rich, in the new 05' front upper pin holder kyosho have made some reinforcement by using thicker material. I found it is much stronger than the 03' so the problem should have been fixed....a very nice update and I look forward to your empire new mount.
speedy100 is offline   Reply With Quote
WTS: Kyosho Evolva 2005 GT Racer R/C Items: For Sale/Trade 1 11-06-2006 06:45 PM
Kyosho Evolva 2005. RcXtion Malaysian R/C Racers 32 09-20-2006 10:47 AM
Kyosho Evolva 2005 kit $250.00 skriete R/C Items: For Sale/Trade 3 07-25-2006 01:18 PM
2005 Kyosho Evolva New in Box ATOMIC R/C Items: For Sale/Trade 0 05-01-2006 09:07 PM
New in Box 2005 Kyosho Evolva $550.00 ATOMIC R/C Items: For Sale/Trade 5 04-30-2006 09:57 PM
