Old 10-03-2001, 06:57 AM   #16
ozzyNEOdriver's Avatar
i'm quoting from the wd40 can;
"wd40 cleans and protects effectivly cleans most surfaces of;... rust and corrosion"
( it attacks rust but it doesn't attack steel)
".......drives moisture off metal surfaces wirring cables spark plugs...."
it can't be bad for a glowplug if it isn't bad for a spark plug??.... i think....
maybe i was wrong about the silicone based thing.
ozzyNEOdriver is offline   Reply With Quote
Old 10-03-2001, 07:03 AM   #17
Manticore's Avatar
R/C Tech Charter Subscriber
piston and sleeve are not steel !! they are soft metal. Non of the pro use WD40.
3in1 oil is good for the job.
Manticore is offline   Reply With Quote
Old 10-03-2001, 07:52 AM   #18
gottcha.
i'll use 3 in 1 or real afterun from now on.
Old 10-03-2001, 07:53 AM   #19
Regional Moderator
disaster999's Avatar
humm....but im using odonnell fuel...this shouldnt happen right?
and the plug that came with my engine is a turbo plug...and when i open up the engine, theres nothing cooked on the plug!
i dont think its that problem...ill try richen the engine up more!
disaster999 is offline   Reply With Quote
Old 10-03-2001, 07:54 AM   #20
Regional Moderator
Manticore: i thought you siad that engine oil works too....like...get the thinest you could find...and its cheap too...for a hole gallon of oil!
Old 10-03-2001, 07:56 AM   #21
Manticore's Avatar
Yes 1:1 car engine oil works too ! get the thinest possible. i.e. 0WT.
Old 10-03-2001, 08:12 AM   #22
M 5
They do??
Last time my brother ran out of gas on the road and my dad took two 1 litre apple juice bottle and filled it up, it only cos 40bux.
From now on I'll take my cars to the gasoline station and feed them there!
M 5 is offline   Reply With Quote
Old 10-03-2001, 08:19 AM   #23
Manticore's Avatar
Originally posted by M 5
They do??
Hey hey,
engine oil is different from gasoline
Old 10-03-2001, 08:29 AM   #24
Regional Moderator
were talking about engine oil in place of after run oil! not for the fuel! nitro cars cant run with gasoline!
Old 10-03-2001, 09:01 AM   #25
automatic gear box oil also works as after run.
Old 10-03-2001, 09:20 AM   #26
Manticore's Avatar
Sure it does. whatever protect metal will work
Old 10-03-2001, 09:51 AM   #27
Snake_bit's Avatar
Marvel Mystery oil Is Great and Cheaper them 3-N-1 oil and Only 4.00 a Guart so it will last a few months.
Snake_bit is offline   Reply With Quote
Old 10-03-2001, 10:18 AM   #28
Regional Moderator
its normal is the engine is leaking right? like through the bearings in the front? its making a huge mess and attracting a lot of dirt!!
Old 10-03-2001, 10:22 AM   #29
Manticore's Avatar
an engine with properly aligned bearings should not be leaked while running but it will leak if you put too much oil inside when it is not in used.
Old 10-03-2001, 10:50 AM   #30
Regional Moderator
oh...okok...then i think i put too much after run oil inside..heheh!!
[FS] Novarossi RS12 S2 - New and Rebuilt Engines squarehead R/C Items: For Sale/Trade 0 12-26-2007 05:45 PM
Tuning Tips. sl4ppinb4ss3r Electric On-Road 21 07-13-2006 04:35 PM
mp 777 sp 2? looking for any tuning tips gabbyb3 Electric Off-Road 2 03-05-2006 06:10 PM
mt12 turbo tuning nismoflip Nitro On-Road 23 10-17-2003 12:54 AM
I am planning to Break in my MT12, Give me some tips Team_Akina_1 Nitro On-Road 24 03-06-2003 08:44 PM
