Old 10-31-2013, 09:29 AM   #1
Default Ntc3 shift issue... beginner asking a tired question
My first post!
So I recently gave my Ntc3 rtr + a thorough cleaning. Sprayed it liberally with WD-40. Far too liberally... Now it won't shift into second gear. First is all I get, without difficulty. I've read every thread about "ntc3 shift problems" on this site and others. The thread I've found that most closely matches my issue, was by a guy who had cleaned his ntc3 with denatured alcohol and this had de-lubed the one way bearing in the tranny. I've already purchased some one way bearing lube and I'm ready to dissect and lube that thing. I just thought I'd post this up and see if anyone knows a trick to more accurately diagnose the problem other than just finding someone who had a relatively similar problem and copying his solution. Thanks in advance for any advice you care to lend!
gt29905 is offline   Reply With Quote
Old 10-31-2013, 09:53 AM   #2
scary_jerry's Avatar
Smile
Originally Posted by gt29905 View Post
My first post!
If your car moves under power, it sounds as though the 'one-way' is working.
It may be the dose of WD40 on your trans clutch shoes that needs to be fixed.
I would picture replacing the trans clutch shoes since I've heard mixed results from attempts to 'degrease' friction parts.
scary_jerry is offline   Reply With Quote
Old 10-31-2013, 04:45 PM   #3
blis's Avatar
My first post!
I once lubed my 2 speed hub bearing with oil, the centrifugal force spread it all over the 2 speed clutch and it would not shift. If the 2 speed shoe has a shiny silver gloss from slipping, clean it down with brake cleaner to remove the oily residue.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 10-31-2013, 05:32 PM   #4
Thanks!
Are there any household equivalents to brake cleaner? Perhaps denatured alcohol or something available at a pharmacy or supermarket?
I live in South Korea and getting to an auto repair shop will be difficult.
Old 10-31-2013, 05:42 PM   #5
Suspended
Any cleaner/degreaser will do !!! Take your time....
bertrandsv87 is offline   Reply With Quote
Tags
ntc3, won't shift
