Old 10-31-2013, 04:32 AM   #31
Phil Trotta's Avatar
These rules although nowhere does it say they are set in stone are the best thing that can happen for this class. Roar finally recognizing this class will show more events for these cars at biggest events each year Nationals. State races. Regionals. Etc.
I don't run this class and only did a short time but now guys should focus on attending these events and helping to set rules in stone
Rim choices
Carb restrictors
Width. Kick up. Etc etc
This is a great thing for gt drivers. Don't jump off the bridge just yet.
PHIL TROTTA
Phil Trotta is offline   Reply With Quote
Old 10-31-2013, 07:09 AM   #32
modhobby's Avatar
Trader Rating: 25 (100%+)
Rim choices
Carb restrictors
This is kind of the crux of this issue. Are the rules set in stone or not? Are they guidelines or rules? When can the GT nation of racers expected adjustments? Monthly, quarterly, yearly, when? UNTIL that is figured out, all it does is cause confusion in a healthy GT8 class. So when you show up to a ROAR race are the rules really the rules?
However, this is only going to play out if the track owners decide to actually follow ROAR rules. For Regional/National events that are ROAR sanctioned, you have the power to participate or not. With all the sentiments stated so far, I have to agree that the rules seem arbitrary without proper knowledge of the history and goals the GT racers want to realize for this class.
REDS Racing USA
modhobby is offline   Reply With Quote
Old 10-31-2013, 09:22 AM   #33
British Menace's Avatar
Absolutely!!....
There are a perfect set of workable rules for this class already thought out and laid out within IGT8F.
At the very worst ROAR should just adopt these rules for the class. Saves all the confusion.
At least these ROAR Rules/ Guidlines are only for ROAR sanctioned events and wont interfere with the bulk of GT racing going on.
Regards,
BM
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 10-31-2013, 10:21 AM   #34
scary_jerry's Avatar
Smile
Originally Posted by British Menace View Post
Absolutely!!....
Regards,
BM
It's got to be some kind of 'trick'........I just checked my 'full set' of carb inserts and there is no '6mm' in there, the smallest is a 6.5mm.
*1Speedy mentioned the difficulty in trying to tune an engine with a 6mm insert............there go the guys that thought they were getting the hang of their first nitro car.
BM.....I for one want to see our buddy 'VictorVector' survive with 'one set of tires'........he's well known as a 'tire shredder' at his 'local haunt'. (but he's fun to race with)
scary_jerry is offline   Reply With Quote
Old 10-31-2013, 10:44 AM   #35
Hehe ... theres one or two "tire-shredders" around Jerry so I don't think he's alone there. One not too far from my keyboard
We did iron out the tire rule though.... careful reading of that rule shows you can only use one set of tires for 'each' race?! So I guess you can change tires for each qualifier and main if you want. (If it's ok to call a 'qualifier'... a race?
Haha ... no surprise's there on the 6mm carb inserts really. People making up rules that don't know what they're doing or have not looked into it properly.
Still .... we must be patient. Maybe after another 4 years we will have "adjusted" the rules to be able to start an engine or two.
Regards
BM
Old 10-31-2013, 11:13 AM   #36
pressure's Avatar
Default Thank u ROAR....But........
Rim choices
Carb restrictors
+1
I have wanted to call ROAR out on for basiically ignoring GT racing for the last 10 months but instead I waited to hear from them. The rules stated may not work for everyone but at least we have a starting point. I will set my car up for ROAR competition at ROAR events and hope to attend the first National ROAR event to include GT racers. Ill support whatever GT rules that are prevelent at the local tracks I travel to.
Thinking that adding a class and gettting it 100% right on the first shot would be incredible but getting acknowledged by the governing body that we all support is long overdue. If its just a matter carrying a 6mm carb restictor and retuning your engine no biggie. But with a 150ml tank and 6mm restrictor I can run for almost 14mins, why not lenghthen my qualifiers? I think the kick up issue should be revisited only because it excludes a strong group of racers and manufactures. But all in all this is a long overdue first step in the right direction.
my 0.04 cents
ITS COMPLICATED......................
pressure is offline   Reply With Quote
Old 10-31-2013, 11:22 AM   #37
Gary NJ's Avatar
Regards
BM
I assume when you say "people who haven't looked into it properly" you're referring to yourself...
I just "looked into it" at A Main and had no problem finding a 6mm insert by both NR and RB, either of which will fit 95% of the carbs folks run (I honestly don't know about something like a Picco...)
Look, I'm no apologist for ROAR here - I just take exception to comments that imply that ROAR hadn't thought about what they were doing. These rules clearly show that the writer(s) thought A LOT about what they were doing, and made some very conscious choices. You may not agree with the rules they wrote...but they are not stupid rules. There is a difference.
Gary - GMK Supply
www.gmksupply.com
Great products. Goofy names.
Gary NJ is offline   Reply With Quote
Old 10-31-2013, 11:36 AM   #38
tonylunatic's Avatar
Trader Rating: 45 (100%+)
Originally Posted by pressure View Post
+1
my 0.04 cents
So just curious are you and Phil going to start running GT8? Are all your races (local, club, etc) ROAR sanctioned?
We haven't even touched the whole Tech issue, so is every motor going to be Inspected before or after for internal mods?
Again I respect ROAR for coming out of hibernation mode, but I truly feel and believe they woke up to just muddy the water.
Its beyond clear they are not in touch with the mass majority of GT8 racers or races. Are we forgetting rules were submitted more then once over the last 3yrs, are these the rules that were submitted? Or are they a diluted version and or just attempt to slow real progress?
Im not a ROAR member haven't been for a few years now I attended our Region 9 ROAR event 2 weeks ago, entries were extremely thin. We get more entries at our club races!
Btw I placed 2nd in GT8, in a full bone stock IGT8F "SPEC" car.
Serpent/Desoto Racing USA~Murnan Modified Motors~PTRC Racing Fluids~Flo-Control ~IGTHobbies.com
tonylunatic is offline   Reply With Quote
Old 10-31-2013, 01:40 PM   #39
MantisWorx's Avatar
Trader Rating: 28 (97%+)
How many licensed short chassis bodies exist?
MantisWorx is offline   Reply With Quote
Old 10-31-2013, 03:18 PM   #40
Good point. Prob just the ofna dp8 and the m-type clk. most kyosho bodies for the short chassis gt1 can't be had
Brett Adams
Mugen MGT7
o.s. savox futaba
66 Box Nova all motor LSX
1966ss is offline   Reply With Quote
Old 10-31-2013, 03:23 PM   #41
Thumbs up
I may run gt8 at bigger events .... Our tracks up here require roar membership to race due to insurance
We have had gentlemens agreements on rules on bodies and weight ... With no Problems ..
IMO I'm sure the 6mm Venturi is not final in stone. But if it was it would eliminate a pit stop or two in med to long mains
I believe the tire rule is to elimInate guys putting On fresh tires for main Like in f1. You run a set of pre scuffs
In the end IMO I think it's better to work with roar and get it as close to acceptable Because the national title would look great on anyone trophy case
PHIL TROTTA
Old 10-31-2013, 03:48 PM   #42
JLock's Avatar
I have about 10 painted/unpainted Kyosho bodies stashed away in the back of my walk-in closet. Been picking them up in my travels over the last three years.
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 10-31-2013, 04:02 PM   #43
azeroth's Avatar
Trader Rating: 20 (100%+)
hmmm ok kick up hmm as i understand must remain in buggy conversions ok but it does not stipulate that a manufacturer cannot come out with all new flat chassis gt ala ofna gtp gtp2 gtv2 dm1 just that it is shaft driven like a buggy and not belt like 1/8 open
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 10-31-2013, 04:13 PM   #44
FREELANCE_RCer's Avatar
Trader Rating: 27 (100%+)
china's companies: team c and ofna should now produce a GT8 with front end kick chassis.
FREELANCE_RCer is offline   Reply With Quote
Old 10-31-2013, 04:33 PM   #45
azeroth's Avatar
OK But why? they already produce a flat chassis car it only mandates that kick has to remain if a conversion and kick up is the angle of attack of the hinge pin like anti squat on the rear and can be in the form of hinge pin mounts and the rules do not state a min or maximum kick up just saying
