Old 11-27-2013, 09:43 AM   #181
T-Hawk's Avatar
Originally Posted by bassman2 View Post
I can't say it better. THANK YOU BM!!!. Lets focus on LOVE and SPEED (focus LOVING one another off the track and focus on SPEED on the track). TOGETHER 1/8 GT racers around the country and other parts of the world make this class better every year..
I love you Andy, you big cuddly teddy bear
-Ryan Newbury-
TomAHawk Racing - On-Time Services - XRay Racing - Sweep Racing - RoseCityScaleRacing.com -
T-Hawk is offline   Reply With Quote
Old 11-27-2013, 10:33 AM   #182
bassman2's Avatar
Right back at you Ryan!!! Lets keep it platonic in case someone gets the wrong idea.....
Andy Liu "Flyin' Hawaiian"
2015 teams/sponsors:
Serpentamerica/Desoto Racing, Murnan Modified Motors, VP powermaster Fuel, Sweep Racing USA, Speed Passion, BUKU performance products
bassman2 is offline   Reply With Quote
Old 11-27-2013, 10:56 AM   #183
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
I totally agree with IGT8F way of act and the nature of the organization ... GT Class is a very nice class to race, and im pretty sure that at some point even IFMAR will consider to support the class.
Keep growing and more important, lets keep racing !!!
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 11-28-2013, 03:42 PM   #184
dlarry's Avatar
As promised here are the rules update.
ROAR GT8 Rules update
1. Engine: SEE 9.3 of ROAR~ any .21 size 5 port engine or ready to run kit with a factory .25 or .28 (must keep pull start on .25 and .28 if ready to run came with it.) For level 3 and below events only. Level 4 and above events any .21 5 port motor only
1. Max carb bore 7mm
2. Pipes: ROAR guidelines.
1. Rubber extensions to stinger OK
2. No internal moving parts”.
3. Chassis: Any 1/8 scale buggy or Truggy based shaft driven nitro powered vehicle. (Any off-road conversion is OK) with front kick up.
1. Chassis with Kick up cannot be altered to change original manufacturers design.
2. Stock and factory optional chassis are permitted, but it must retain all the characteristics of the standard off-road chassis on which it’s based. Chassis must be identical to their off-road counterparts in all dimensions except where it’s necessary to convert the chassis for on-road use. Carbon fiber chassis are not permitted.
3. For 2014 season only Ofna and Team C racing flat chassis are allowed. Starting in 2015 All chassis must have front kick up flat chassis will no longer be allowed. 4. Body: Any commercially available factory licensed replicas of ALMS, GT1 or GT2, Super GT, DTM, and V8 Supercar Cars. Licensed Bodies required for ROAR Competition starting 1/1/2015. For 2014 any commercially available body that resembles a GT body. Body must be a 2 seater with 2 doors. 1. Sports Cars: Closed wheel cars designed specifically for racing in full-size series. Engine Head may not protrude above body.
A) Wings and spoilers can be used if they are the original with the body and cut on the factory lines.
B) All wheel wells must be cut out and rear of the bodies should maintain tail lamps and cannot be completely cut out. Wings must be attached to the body.
C) No wedge style Bodies
D) All body approvals will be subject to scrutiny of the respective or collective advisory
committees regarding compliance to the “spirit of the rules.” An objective evaluation
shall determine the status of each submission based on the adherence to the said rule
E) • Bodies must be factory licensed replicas of the aforementioned street or race cars, but no “race-only” bodies are permitted. Bodies based on Daytona Prototypes, or the odd Super GT cars that are not representative of a commonly available street car, are not permitted.
F) Bodies must include full front and rear fascia’s, and conform to the rules herein that limit openings in the body for the purposes of re-fueling, starting, engine tuning, and antenna holes
G) Bodies must be fully detailed in order to compete in ROAR competition. The body must have visible window, body panel and trim markings, and the windows must be mostly clear. Some intrusion for creative painting purposes and tinting is permitted, but the windows must be transparent. Bodies must have headlight and grill detail.
Transmission:
• Transmission: Single speed or two-speed only. Single speed configurations must include a solidly mounted spur gear to a standard bevel gear center differential or a solid spool (no one-way bearing). No other differential types will be permitted.
• Two-speed transmissions must use an automatic centrifugal shifting mechanism that is not remotely adjustable or programmable. Because of the nature of the two-speed transmission design, no center differential is required, but the transmission must include a solid center shaft that doesn’t allow differential action between the front and rear drive assemblies.
Clutch: Only buggy based 2, 3, or 4 shoes systems No radial type clutches (Centex)
DRIVETRAIN
• A shaft-drive system with two gear-type open differentials are required.
• No one-ways, spools, locking “Torsion-type,” or externally adjustable differentials are permitted. The gear diffs can be tuned only with the use of silicone-based fluid.
• Identical F/R drive ratios are required – no F/R under drive/overdrive permitted.
• A single speed mounted to a center spool, or an included two-speed transmission are permitted.
• The drivetrain shall be a center shaft system with ring and pinion gears driving the differentials.
• Shaft-drive only – belt driven cars are not permitted. The drive system must maintain the same features as used in the original off-road configuration except where noted, including the center differential/two speed transmission with separate front and rear center drive shaft’s.
• Only standard mechanical brakes are permitted – hydraulics are not permitted. Up to two brake discs are permitted anywhere on the center driveshaft’s. Brakes may not be located on the outboard axles.
Fuel Tank: Up to 150cc max fuel capacity
Wheels: • Wheels must use a 17mm hex hub consistent with the dimensions and function of the hubs used in 1/8 off-road racing. The wheel must be affixed by a 17mm wheel nut, threaded on to the hex hub. Quick change mechanisms are not permitted.
• Dish wheels are not permitted. No more than 30-percent of the face of the wheel may be solid. The wheel “face” will be defined as all areas of the wheel between the mounting bead and the center mounting hole.
Tires: Rubber Tires only – (maximum width: 47mm) Traction compound: OK
• Tires must be “production” tires – hand cut tires or those not available to the general public are not permitted. “Available” is defined as having been sold to consumers a minimum of 30 days prior to the official start of the event. Tires must be molded rubber – no foam tires are permitted in any class.
• Spec tires chosen by ROAR will be mandatory at all level 4 and level 5 events. Input from the host facility regarding favored compounds for track conditions will be considered, but the final decision on spec tires will remain with ROAR. The best interests of the racers will be the overriding criteria in choosing a proper spec tire. Financial, sponsorship, and/or business relationships of the host facility cannot be considered.
• All races must be completed on the same tires used to start each race (qualifying and finals). Tire changes are not permitted except when a wheel and/or tire are determined by the race director or a ROAR official, to be damaged. Excessive tire wear does not constitute damage
Weight: Minimum dry weight of 3500 grams (with body and all four tires on the) vehicle)
Car Dimensions:
Item Limit Specification
Length (B) Maximum TBD
Width Maximum 310 mm
Height (measured with suspension fully compressed Maximum 250 mm
Wheelbase (a) Maximum 379 mm
Minimum 270 mm
Weight Minimum 3500 grams
Wheels Mounting Bead Diameter Maximum 79.00 mm / 83.50 mm
Overall Diameter Maximum 88.50 mm
Width Maximum 44.45 mm
Tires Diameter Maximum 119.22 mm
Maximum 109.22 mm
Width Maximum 46.99 mm
Rear Wing Side dam Length Maximum TBD
Height Maximum TBD
Chord Maximum TBD
Width Maximum 217 mm
David Larry
Shepherd Velox V8, Serpent 411 Eryx 4.0, Novarossi, Bryons Fuel, Airtronics
dlarry is offline   Reply With Quote
Old 11-28-2013, 05:41 PM   #185
DK McGee's Avatar
Trader Rating: 36 (97%+)
So the DM1 and Team C Will only be good for 2014 and then a shelf Queen? They should be grandfathered in
Marcos.J is an idiot along with his side kick's:flaming:
"And now I'm editing your signature and letting everyone know that you are permanently banned from " your truly Marcos.J aka the idiot
DK McGee is offline   Reply With Quote
Old 11-28-2013, 05:59 PM   #186
RoketRdr's Avatar
Angry
EXACTLY!
RoketRdr is offline   Reply With Quote
Old 11-28-2013, 07:06 PM   #187
DK McGee's Avatar
Owell Were OutLaw anyway here in the south "Run What Cha Brung" and hope ya brought enough
Old 11-28-2013, 07:56 PM   #188
Grenade10's Avatar
Trader Rating: 37 (100%+)
Well, I was hoping for an other year or two with the DM-1car, but in the long run having all chassis on the same set up should help. Plus, new manufactures now have rules to work from.
Surprised no one talked about the change to a 7mm restrictor, and ANY 5 port motor for regionals or nationals.
David, thanks for getting these rules out.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 11-28-2013, 08:16 PM   #189
azeroth's Avatar
Trader Rating: 20 (100%+)
OK at least it is a real and reasonable set of rules i will just run mine at club level events and concentrate on my 1/10 or 1/8 cars and forget gt and about my scratch & modded conversion builds as well
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 11-28-2013, 09:15 PM   #190
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Originally Posted by RoketRdr View Post
EXACTLY!
I agree, Larry can you please explain this? wouldn't it make more sense to just not allow any NEW flat chassis mfg? As of right now TeamC/OFNA cars are the second most popular short chassis and the most popular long chassis cars out there.
MantisWorx is offline   Reply With Quote
Old 11-29-2013, 06:25 AM   #191
I think they should consider review this "dish wheel" rules. The best tires on market (GRP and PMT) are out!
MarceloAires is offline   Reply With Quote
Old 11-29-2013, 08:15 AM   #192
pressure's Avatar
.21 5 port w/ 7mm restrictor and 8 min qualifiers and the whole country will be running GT.
ITS COMPLICATED......................
pressure is offline   Reply With Quote
Old 11-29-2013, 09:45 AM   #193
^ I got a p5xlt ready for this kind of game!!!!
Brett Adams
Mugen MGT7
o.s. savox futaba
66 Box Nova all motor LSX
1966ss is offline   Reply With Quote
Old 11-29-2013, 10:12 AM   #194
Trader Rating: 318 (100%+)
Guys are making to much of a big deal about Roar. The local tracks really make the rules.
Also I run Team C car. So after 2014 only Serpent GT will be legal, to funny.
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 11-29-2013, 10:50 AM   #195
In the Tri-state GT racing was strong on 2013. In my opinion bigger than any where on a regular. With Roar rules or not.. . Just a very simple no foam and Evo type clutch rule and weight limit.
Jermaine Mitchell
Mercenary Racer
