Old 07-01-2005, 04:09 AM   #1
dct147's Avatar
Default Can`t turn left
Hi guys,
my car won`t turn left as much as it turns right.
i`ve tried centering my servo differently, but still it won`t turn as much to the left as it is to the right.
Is there anything i should check?
dct147 is offline   Reply With Quote
Old 07-01-2005, 05:23 AM   #2
espo16's Avatar
check the endpoint adjustments (EPA) on your radio.
espo16 is offline   Reply With Quote
Old 07-01-2005, 07:00 AM   #3
stefan's Avatar
Send a message via AIM to stefan
Originally Posted by dct147
Hi guys,
Ask somebody from the southern US, they only turn left
stefan is offline   Reply With Quote
Old 07-01-2005, 07:33 AM   #4
espo16's Avatar
that was a good one
Old 07-01-2005, 07:35 AM   #5
ntc3freak's Avatar
check ur shocks
ntc3freak is offline   Reply With Quote
Old 07-01-2005, 09:52 AM   #6
jhigga15's Avatar
are the grears in the servo stripped?
jhigga15 is offline   Reply With Quote
Old 07-01-2005, 04:40 PM   #7
AndyT 's Avatar
Also check the length on your front steering turnbuckles...if theyre uneven you`ll have different toe settings and different turning characteristics.
AndyT  is offline   Reply With Quote
Old 07-01-2005, 05:13 PM   #8
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
first thing you check is to look at the wheels and see if they move the same both ways left and right. if they do then you have a tweak, first check to see that the shocks are all properly working, remove the springs and then compress the piston and it should rebound out by itself if not you need to rebuild it. once the shocks are good make sure when the shocks are mounted they should not be binding a little wiggle before you mount the shocks you should set the droop on the car, thats if you can on your car you didn't say what kind of car you had and also make sure the shocks are equal in lenght both fronts the same and the rears are both the same and the same spacers or adjust the collars the same then try it out and let us know
Team Kyosho, Team Epic, IDM Engines, J-Tech racing fuels, Airtronics, Superiorhobbies.com
Speedypeterb is offline   Reply With Quote
Old 07-03-2005, 12:51 AM   #9
dct147's Avatar
Thanks for all your reply.
Have just checked my car and this is what i found.
Shocks are alright.
Servo gears are alright.
however, i have noticed a broken part. which is what i`m about to attach. ( i have glued them back together with very strong glue)
However, even when i remove the connecting piece from the servo to the arms of the front wheel and try turning it manually, turns right with ease, when turning left, it kinda gets stuck somewhere halfway.
ok anyway, here are the pictures.
anything else i should check? cause i don`t think this is the main problem.
Old 07-03-2005, 03:10 PM   #10
dct147's Avatar
have done all the above mentioned advice, and still nothing.
However , have discovered that my front left dogbone is slightly bent.
Could this be the problem for my turning left?
Old 07-03-2005, 03:59 PM   #11
Jye
I would think so.
Jye is offline   Reply With Quote
Old 07-03-2005, 10:37 PM   #12
Shocks are alright.
i think you just glued your servo saver.. i would recommend getting a spare steering servo as soon as possible..
OrAnGe PoWeR is offline   Reply With Quote
Old 07-03-2005, 10:54 PM   #13
dct147's Avatar
IS that the steering servo saver?
didn`t know that. am i supposed not to glue it ?
Old 07-03-2005, 11:20 PM   #14
yes. it's supposed to 'give' when you hit something to 'save' the servo from stripping.. hence the name 'servo saver' check the tension on the spring below that plastic piece. i'm guessing you're running the fwo5, just follow the manual (2mm spacing between the bottom of the lock nut and the chassis, not too sure though) if it's less than that, it could also be the culprit.
Old 07-04-2005, 03:55 AM   #15
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
If they looked nicely rounded or almost made. Then yeah that was the servo saver.
Also you want to turn left and right. See how far the wheels are traveling, make a reference point with something then verify the other side can reach its same opposite point. That will let you know if its possible another problem.
Artificial-I is offline   Reply With Quote
Left Turn Raceway-Muncie Indiana nutz4rcyktw Track Locator Forum 22 10-02-2008 05:14 PM
South Florida Touring Cars - Turn Left? amusicwiz Florida Racing 0 10-03-2004 02:56 PM
Reedy Ti Standard Comm Armature, 10 turn & 8 turn brand new jason cheng R/C Items: For Sale/Trade 2 05-20-2004 01:17 PM
Losi left turn only truck!!!!!! gac1983 R/C Items: For Sale/Trade 3 03-06-2004 01:58 PM
Need help on reducing the left and right turn differences in shaft drive Kamen Rider Electric On-Road 8 08-17-2003 07:10 PM
