Old 06-30-2005, 08:03 PM   #1
espo16's Avatar
Default SON OF A B***H!!!!!!!!!!!!!!!!!!
well here goes.
bought a sirio tup af 5 porter.
unintentionally cut the d**m crankshaft too short. tried to order it for two weeks no one in the damn states had it. finally found one in singapore. took three weeks to get it. finally got here, cut the crank the right length this time and started breaking her in. 7th tank she was looking good. started leaning her out. ssssmokinnnn!!!!!! i noticed that my rx pack was really weak. so instead of doing what any other "normal" person would do, STOP AND CHARGE THE PACK, my dumb ass went to the toolbox, grabbed the stock AA pack and put the smallest, flimsy ass zip tie i could find and tied it to my shock tower. what a damn idiot!!! 8th tank hit a bump, battery pack came loose, wire went under tire, came unplugged, you know the rest of the story. full throttle, up a small 2 ft hill (grass), BOOOOOOOOOM!!!!!!!!!!!!! into the fence. i was about 150 yards away so i had to run the fastest damn 150 yards in my life. so fast i could have beaten maurice williams AND justin gatlin. engine ran full throttle for about 15-20 seconds. thank the lord almighty i was running it richer than oprah winfrey. here's the aftermath.
espo16 is offline   Reply With Quote
Old 06-30-2005, 08:10 PM   #2
Jye
it looks you you actually got pretty luck. sure you took some damage in the back but it could have been worst.
Jye is offline   Reply With Quote
Old 06-30-2005, 08:52 PM   #3
BundyMan's Avatar
Yup, actually that put to rest the theory that NTC3 is a fragile car. I mean damn you broke 2 wooden planks and with the little damage the car had....yup could be a lot worse!
BundyMan is offline   Reply With Quote
Old 06-30-2005, 09:27 PM   #4
Hesky's Avatar
Thank god for sh*tty balsa wood fences!
Atleast you know your new engine can haul some serious ass!!
Hesky is offline   Reply With Quote
Old 06-30-2005, 09:32 PM   #5
diesel's Avatar
Hmm...ntc3 isn't fragile after all and you have made a good choice in the engine hehe.
diesel is offline   Reply With Quote
Old 06-30-2005, 09:42 PM   #6
ntc3freak's Avatar
u are lucky that it didn't end up a lot worse man.lesson learned:never use flat receiver pack.or spend some $ and buy a fail safe.u don't want it to happen again,do u???
ntc3freak is offline   Reply With Quote
Old 06-30-2005, 09:42 PM   #7
j03s4y's Avatar
Send a message via AIM to j03s4y
wow....that's a lot of power trying to break through that wood.......the car don't look THAT bad compared to the wood. I mean come on it's wood!!! and it took out 3 planks!!!
j03s4y is offline   Reply With Quote
Old 06-30-2005, 09:46 PM   #8
espo16's Avatar
i have a failsafe. pack came unplugged. no power no work.
Old 06-30-2005, 09:47 PM   #9
ntc3freak's Avatar
oh yeah.i forgot.do u have throttle return spring??? i bet u don't,do u????
Old 06-30-2005, 09:49 PM   #10
espo16's Avatar
Cool
look at pic #5
Old 06-30-2005, 09:53 PM   #11
ntc3freak's Avatar
look at pic #5
yeah.why????
Old 06-30-2005, 09:54 PM   #12
espo16's Avatar
you can see the spring. come on fella i'm grieving over here.
Old 06-30-2005, 09:57 PM   #13
ntc3freak's Avatar
i was not talking about the linkage.the spring i was talking about is a spring attached to the carb so it can close the carb when the rx pack fails.understand???
Old 06-30-2005, 09:59 PM   #14
espo16's Avatar
i quit. you won
Old 06-30-2005, 10:05 PM   #15
Hesky's Avatar
see the 2nd spring attached to the carb and engine crankcase? thats the throttle return spring.
Cheers
