Mugen MTX-3
Old 04-12-2005, 06:24 AM
  #14911
typer's Avatar
Hi robbie!
just want to ask on how do you decide on your ride height. Lets say the track is smooth and the traction is low to medium. I have downloaded several mugen drivers set up and they have 1 mm difference between the front and the rear.Thanks
typer is offline
Old 04-12-2005, 08:44 AM
  #14912
ROBBIE C's Avatar
If the track is smooth I run the car as low as I can because of stability. If the track is bumpy I run the car high just enough that it doesn't hit the bumps. The reason why I run the front lower than the rear is for weight transfer and stability in steering, the back of the car swats on acceleration so I like to run rake in the car to even things out, also the rear tires wear more than the front so this helps keep the car even from front to rear.
ROBBIE C is offline
Old 04-12-2005, 10:56 AM
  #14913
gentleman81's Avatar
hey robbie thanks for all the tips. i am currently running the rear C blocks and have a low traction track. i probably need to spend more time on my camber and toe settings to find my traction huh? i run the b ackerman, the swaybar at 0 deg or flat, (is that to soft. i am going to stiffen up my rear sway bar next race, it is the 2.5 and i had it all the way at the ends, the softest setting.
throught the infield i was able to put up with the push but at the end of the straight i have a terrible time trying to make that turn, i always end up in the boards? the pro guys are almost full steam when they hit the turn and are able to maintain speed, i loose alot of time and speed in the turns if i try to carry my speed too long.
gentleman81 is offline
Old 04-12-2005, 11:01 AM
  #14914
Default ratio
can anyone explain what the gear ratio is and what it does? i know a little about gearing but the ratio is a mystery?
Old 04-12-2005, 11:49 AM
  #14915
ROBBIE C's Avatar
Boddies are verry important to, I think if you run the proper body it will help with your set up.
Boddies to try:
Losi Alfa
Portoform Mazda 6
Portoform Dodge Stratus
Kawahara Honda
ROBBIE C is offline
Old 04-12-2005, 02:07 PM
  #14916
Default Re: ratio
check this LINK
you will find useful info about gearing and more on that site.
penggoy is offline
  #14917
roadrage's Avatar
Trader Rating: 14 (100%+)
where could i get a kawahara honda from? any pics?
roadrage is offline
Old 04-12-2005, 05:42 PM
  #14918
Aaron_ETF's Avatar
Robbie,
I am new, just a quick question, I am wondering if you guys (Pro Driver) using brake? Coz I heard just some they don't use brake, what is the truth?
Aaron_ETF is offline
Old 04-12-2005, 09:19 PM
  #14919
Vinyard's Avatar
Originally posted by Aaron_ETF
Robbie,
I dunno about the rest, but i use the brakes quite often..
to scrub off speed entering a corner... otherwise rolling into a corner in tat high speed may sometimes prove disaterous!
Vinyard is offline
Old 04-12-2005, 10:49 PM
  #14920
Trader Rating: 28 (100%+)
When using a one-way front diff, you can't use very much brake as it causes the car to spin out. If you use a spool or a diff you can use the brakes. Most of the pros run a one-way and therefore have very little brakes.
Scott Fisher is offline
Old 04-12-2005, 11:18 PM
  #14921
asw7576's Avatar
I agree with you...... it's personal driving style, some drivers brake very late before entering corner ( just like the real thing ) and some don't use brake at all but of course off throttle early.
Front ball diff setup gets you more stability or more confidence feeling during slow and medium cornering.
What it takes to build front ball diff ?
asw7576 is offline
Old 04-13-2005, 06:08 AM
  #14922
Asw7576,
Do a search, someone had listed all the part #'s needed to build the front diff a couple of pages back.
Jamie Corrado is offline
Old 04-13-2005, 06:36 AM
  #14923
Asw7576,
Check page 492 of this thread, the info your looking for is there.
Old 04-13-2005, 08:32 AM
  #14924
JustRace's Avatar
Robbie,
I would think they use brakes. I don't see how you can be fast without braking.
As for oneways, you need to set the brakes so the car won't lock up.
JustRace is offline
Old 04-13-2005, 08:38 AM
  #14925
teammpp's Avatar
none of the fast guys here use brakes unless its really necessary. does require a more smoother driving style though.
teammpp is offline
