Mugen MTX-3
I can actually get a really good deal on a reg kit, so what parts are in need of imediate replacement.(i.e. hop ups) or is the stock kit good enough as it is?
By the way, anyone looking for a Nitro TC3?
The stock kit, well built and set up is very competative. The pro kit just has most of the upgrades you will want.
Re: MTX-3 19/16
Originally posted by Quiet
ok guys what's the real deal? some people say you ought to have a 1.5mm split others say 2.5 and even 4mm difference in tire diameter between front and rear, being the front tire the smallest when running 19/16 side pulleys in order to get even or close to even tire wear, what tire size is everyone prepping for the main? I am a newbie to nitro-foam tire stuff! please help.
thanks O.R.
thanks O.R.
offloading mtx's in for sale forum
Do you have a NIB mtx3 prospec to sell?
Re: Re: MTX-3 19/16
Originally posted by joemugen
i am not running the mtx-3 anymore, but when i didnt run the 19/16. put a 23t (from serpent) in the front pully and leave the back stock. run a one mm split. it is better than the 19/16. probably all mugen team drivers are doing this.
We normally run a 1.5mm splint in the main, front tires staring out smaller.
Originally posted by Scott Fisher
the mugen pack is 730ma. I made one out of 850ma batteries. GP has a 950ma AAA battery and I have seen another brand that has 1000ma batts. If you don't want the mugen pack, just make one yourself.
Sony have a 1.100mah AAA cells ... very good ...
spool
does anyone make or sell a spool for the front of my mtx-3. Haywyre
batteries
I managed to solve my runtime problems. I stuffed in two 2000 mA Li-Poly batteries in my Mugen. I'm now getting 2 hours run time. I used the Novak Nitro servo regulator[ cool blue light] . That nocked down the voltage. The weight is 3 grams more than the stock 750 mA. HAYWYRE
Originally posted by Slotmachine
The Kawahara solid diff will work in the front, the only place I ever used it was The Texas Biggie!
Re: Re: Re: MTX-3 19/16
Originally posted by ROBBIE C
Sorry but none of the guys I no are doing this, all we ever run are the stock pully's, we never use anything from another car to make our cars re-act different.
Re: batteries
why didnīt look at the regulator before? excellente idea!
Re: Re: batteries
Re: spool
