Old 03-18-2005, 09:23 AM   #14806
ROBBIE C's Avatar
Send a message via AIM to ROBBIE C Send a message via Yahoo to ROBBIE C
Default Re: what is the highest milli amp battery they make for the mtx3?
Originally posted by gentleman81
Here's my take on the batteries I hope it helps.
Try charging your batteries at a lower amp this will increase the mili amps I normaly charge at .05 amps my batteries peak at over 900 mili amps.
Always have two packs one for pratice and qualifying and one for racing so you don't kill your sells.
Works for me.
ROBBIE C is offline   Reply With Quote
Old 03-18-2005, 12:08 PM   #14807
Default MTX-3 19/16
ok guys what's the real deal? some people say you ought to have a 1.5mm split others say 2.5 and even 4mm difference in tire diameter between front and rear, being the front tire the smallest when running 19/16 side pulleys in order to get even or close to even tire wear, what tire size is everyone prepping for the main? I am a newbie to nitro-foam tire stuff! please help.
thanks O.R.
Quiet is offline   Reply With Quote
Old 03-18-2005, 12:38 PM   #14808
ROBBIE C's Avatar
60/61 1mm split deppending on the tire wear of the track.
Medium tire wear 1.0mm
High tire wear 1.5mm
Old 03-18-2005, 12:42 PM   #14809
teammpp's Avatar
We had to remove the 16/19 conversion because rear tire wear went through the roof. Our track is low wear normally and this past weekend everyone running the 16/19 conversion ended up running off a full set of 37sh in 30mins.
We normally only get 1.5mm max on the outside wheel.
Any ideas?
teammpp is offline   Reply With Quote
Old 03-18-2005, 01:06 PM   #14810
ROBBIE C's Avatar
If it's low wear you only need to run a 1.0mm split
Try this set up
60/61
or
59/60
Old 03-18-2005, 02:02 PM   #14811
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
On our track I am running a 1.5 split with the stock pulleys. I didn't particularly care for the 16/19 conversion.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 03-19-2005, 11:08 AM   #14812
I see that in one of the past posts someone was told to get the MRX3 outdrives and front belt for their car. I was wondering if those outdrives were for a oneway or a diff. Also, what are the part #'s?
shadow1208 is offline   Reply With Quote
Old 03-19-2005, 11:29 AM   #14813
mckrooz's Avatar
Send a message via AIM to mckrooz
They are for the one way. I've had the stock out drives wear a groove in them from the bones. The MRX ones are alot beefier.
Kyosho RRR Evo2
mckrooz is offline   Reply With Quote
Old 03-19-2005, 12:31 PM   #14814
Seisick's Avatar
Default Re: Re: Re: Re: ROll Center
There's two places where you can talk about Mugen product and what's going on at the track................www.mugenracing.com chat forum and Starting Grid chat forum.
If you check out the website you'll notice that we are now updating it daily, our goal is to improve the information needed to enhance the performance of your car.
MyTSN is a private website disign to support whom ever they choose. I think its really cool when a out side source shows that much intrest in a company to do that.
hey robbie, kawaharara belts still backordered? my 1 speed one way bearing is falling apart, two pins are missing, is there any significant difference between the kawahara and the mugen besides weight?, im about to make the order this weekend.wondered if i could just replace the one way bearing but donīt know where to get i!
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 03-19-2005, 08:46 PM   #14815
Rob Phillips's Avatar
I'm about to buy a new TC, does the pro spec need anything else? Any uncommon replacment parts to buy?
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 03-19-2005, 09:22 PM   #14816
rcabj's Avatar
reallly i can't think of any
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 03-20-2005, 11:49 AM   #14817
Default gearing
I just picked up an mtx3 last 2 weeks ago. I ran the stock gearing rations for the standard kit, last week. Not enough for the large track I run at. This week I went to the .08 gears and ran the stock gearing for the prospec. Alot better. Can the car handle a 7 tooth differance in gearing? I was going to try 21/28 and 52/59. Guess I am used to the exceleration of my tc3, so I really do not want to go higher on 1st gear.
I have been driving an ntc3 since the car first came out. In my second time out with the mtx3, I probably was as hooked as I ever felt with the ntc3.
CHUCKMANDO is offline   Reply With Quote
Old 03-20-2005, 12:49 PM   #14818
teammpp's Avatar
Default Re: gearing
We run 21/27 or 21/28 depending on the grip levels. Car should have no problem if the engine is capable of pulling it.
Old 03-20-2005, 05:47 PM   #14819
Thanks P.E., I think my ps12 should be able to handle it when I get it back this week .
Old 03-20-2005, 06:38 PM   #14820
teammpp's Avatar
More than enough.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
