Old 03-14-2005, 08:50 PM   #14791
Number 11's Avatar
Thanks afm
Number 11 is offline   Reply With Quote
Old 03-14-2005, 08:52 PM   #14792
FW-05RR's Avatar
what does Much More Mugen mean or M3?
FW-05RR is offline   Reply With Quote
Old 03-14-2005, 09:05 PM   #14793
rcabj's Avatar
Default axle free play
hi...any of u guys notice if there is a bit/lot of free play for the axle .....i have change the new(for this case the rear upright plus new inside and outside bearing for the axle) and there is still a bit of free play....is this normal?...thanks
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 03-14-2005, 09:20 PM   #14794
bcquick's Avatar
Originally posted by Scott Fisher
The front belt will wear out the fastest of the three belts..
The gearing between the front and rear wheels is not exactly the same. This slight difference causes a little more stress on the front belt. Periodically inspect the belts. Look for teeth that are missing or wearing out and replace them when you can see this. Also I would inspect the pulleys as they will eventually wear as well. When worn, they will wear the belts faster.
Iam pretty sure the front to rear gear ratio is the same on the mtx-3 2.5263
i think the front one way has a lot more to do with front belt wear
and also hitting anything on power will useually strip a belt or fatigue it , as the front cant diff out like the rear something has to give just my .02
bcquick is offline   Reply With Quote
Old 03-15-2005, 01:14 AM   #14795
FREAKAH's Avatar
StepPins, try dis.......
RUBBER TIRE SETTING
FRONT
Track widht 195mm
Ride height 4.5mm
Camber -1º
Caster 3mm
Toe 0.5º out
Rebound 1mm
Bumpstop 0
Anti-roll bar none
Steering Ackerman "B"
Front Diff 20,000
Shocks piston 1 x 1.1
Mugen 600 shock oil
Spring Light Blue
Shock position 2nd hole from bottom
REAR
Track widht 198mm
Ride height 5mm
Camber -1º
Toe 2º in
Rebound 6mm
Bumpstop 0
No anti-roll bar
Lower arm position "B" block
Rear Diff 5000
Shocks piston 2 x 1.1
Mugen 600 shock oil
Spring Purple
Outside hole on shock tower
Upper arm inside hole
One AE aluminum washers under rear upright hub ball end
Sorex 40R w/ Yok 37M, Take-Off CS37
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 03-15-2005, 11:03 AM   #14796
StepPins's Avatar
Thanks AFM and Freakah
Freakah, is this what you used last race?
StepPins is offline   Reply With Quote
Old 03-16-2005, 01:12 AM   #14797
FREAKAH's Avatar
Actually, that's Kent's setup and he got his pretty well dialed.
Second-Hand Racing
RACE WORLD HAWAII
Old 03-17-2005, 03:34 PM   #14798
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Default Power push
can equal tire size front/rear make the car push
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 03-17-2005, 10:08 PM   #14799
gentleman81's Avatar
Default what is the highest milli amp battery they make for the mtx3?
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 03-18-2005, 12:14 AM   #14800
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
the mugen pack is 730ma. I made one out of 850ma batteries. GP has a 950ma AAA battery and I have seen another brand that has 1000ma batts. If you don't want the mugen pack, just make one yourself.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 03-18-2005, 01:55 AM   #14801
rcabj's Avatar
i too made one myself ( actually ask a friend to solder it for me..my soldering is awful )
anyway its 800 nimh...and performs ok...
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 03-18-2005, 03:27 AM   #14802
straightsixers's Avatar
Default Re: Re: ROll Center
I think it makes more sense now. Thanks cdelong for your time on this. Its amazing why no one has responded till now on something so essential for knowledge, and rather focus on listing parts for building a diff.
Understand now why MyTSN is the reference point for many rc racers and essentially adding to Serpent's reputation. It's a shame we do not have something similar going for Mugen, when it is in fact a very competitive car. Hope they read this.
Originally posted by cdelong
I think it's more than meets the eye....
The pro's only mention that the "A" block lower the RC, and not WHY they lower the roll center. The one thing we need to realize is that there is more than one thing drivers are trying to accomplish. I've been on the Mugen forum, and it seems that the "A" blocks (low roll center= more roll) are used when bite is high to add some laziness to the car and to prevent traction rolling. If the car will not roll on the suspension a little, it will just traction roll if the bite is high. Swauger mentioned that the blocks will also change the shock angle slightly (A= more laid down).
Just push the "I believe" button and do what the big dog's do= high bite = Low roll center.
straightsixers is offline   Reply With Quote
Old 03-18-2005, 03:57 AM   #14803
asw7576's Avatar
Red face
I have tested rear C block vs A block :
Using C block the car doesn't roll too much, the rear tires slide little bit in medium and tight corners. More aggressive feeling.
Using A block the car does roll ( I can see the body leans at corners ). I get mid corner understeer, but up to certain point it will slide too if you push too hard.
I suggest C steering ackerman when using C rear block.
Old 03-18-2005, 07:09 AM   #14804
Seisick's Avatar
Default Re: what is the highest milli amp battery they make for the mtx3?
Originally posted by gentleman81
energizer makes the 1000mah aa batteries, you could make one yourself but i prefer the trinity 800mah hump which costs 20, in the end you´ll pay even more since you´ll need the connector, copper bars, shrinkwrap, etc
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 03-18-2005, 09:17 AM   #14805
ROBBIE C's Avatar
Send a message via AIM to ROBBIE C Send a message via Yahoo to ROBBIE C
Default Re: Re: Re: ROll Center
There's two places where you can talk about Mugen product and what's going on at the track................www.mugenracing.com chat forum and Starting Grid chat forum.
If you check out the website you'll notice that we are now updating it daily, our goal is to improve the information needed to enhance the performance of your car.
MyTSN is a private website disign to support whom ever they choose. I think its really cool when a out side source shows that much intrest in a company to do that.
ROBBIE C is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
