Mugen MTX-3
Old 03-12-2005, 06:07 AM
  #14776
cdelong's Avatar
small track you may want 30K. I think 50K is good for large tracks with good traction.
cdelong is offline
Old 03-12-2005, 09:28 PM
  #14777
Number 11's Avatar
Any suggestions on sites I can go to to learn more on the MTX3 I have been driving a NTC3 that last 4 years and someone gave me there MTX3 last winter. I haven't had a chance to drive it yet and I am trying to figure out how to set it up. Basically what I am looking for is a MTX3 setup sheet. If I do this to the car this will happen. It is amazing to me the manuel has no instructions and the website only has setup sheets. I have never had a car with bump stop screws what do those do? Where are the front droop screws I can't find them.
Number 11 is offline
Old 03-12-2005, 09:52 PM
  #14778
gonzoY5's Avatar
The front droop screws are located on the front sway bar mount. You access them from the two small holes on the front body mount. The rear droop screws are located on the rear arms obviously. You access them from the top as well. THey can be found on the rear arms where those little "tabs" (< >) stick out from the side chassis. Bump stops limit how far the car will travel when pushed down. I've never used em. I don't think they're intended for foam tire use. I think it's for Rubbers, but i'm nost sure. None of the foam setups i've seen ever use em. I agree, the manual is tereible on the car in terms of what does what. Check out the X-Ray or MyTSN sites for explanations on how to use the adjustments, they're pretty similar. Good luck.
gonzoY5 is offline
Old 03-13-2005, 06:25 AM
  #14779
RClover's Avatar
Default Re: rear diff oil
Originally posted by rcabj
hi...about to try 50K oil in the rear with fr. 1 way...
anybody has tried this and how does it handles?? thanks
btw...i usually race on small/medium tracks...
i use 10K on a low grip small track. try 10K or 30K. but 50K is for good traction medium size track.
RClover is offline
Old 03-13-2005, 08:46 AM
  #14780
alucard13's Avatar
I ran 30K at a tack with good traction and nice size. It helps alot. I had 10k and could tell the difference. 30k was better for me.
alucard13 is offline
Old 03-13-2005, 09:01 AM
  #14781
Number 11's Avatar
Thanks gonzoY5 the Mytsn site has some good info. It almost has me sold on a Serpent now. I got to try the Mugen out first it is such a nice looking kit just wierd they don't put more effort into explaining setups for this car.
Old 03-13-2005, 01:20 PM
  #14782
gonzoY5's Avatar
Yeah that's one thing Mugen lacks. They make a great car, but if you don't know where to find the adjustments, their documentation sure won't tell you.
gonzoY5 is offline
Old 03-13-2005, 02:45 PM
  #14783
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
does the solid rear work on the front dif
20 SMOKE is offline
Old 03-13-2005, 08:01 PM
  #14784
Slotmachine's Avatar
Default Yes
The Kawahara solid diff will work in the front, the only place I ever used it was The Texas Biggie!
Slotmachine is offline
Old 03-13-2005, 11:45 PM
  #14785
StepPins's Avatar
Default MTX-3 Noob
Hi guys,
Sorry if this may seem repetitious, but I just got a MTX-3 (non Prospec) and will be running in a rubber tire class. Given that I have the correct choice of tires, what will be a good set up for a medium size track with tight turns and switch-backs in the infield (track is a cleaned/blown hardly used parking lot, smooth, with medium traction, and no traction additive layed down).
Right now I am using a front diff with 30k, rear diff with 7k. I would like to know (with your suggested set -ups) diff fluid selection, mugen spring color or spring rate, shock fluid wt., droop, and ride height settings, camber/caster/toe settings,....and what ever you guys could help me with.
I know it sounds alot to ask, but any help with a rubber tire setup for my new MTX-3 would be greatly appreciated!
StepPins is offline
Old 03-13-2005, 11:48 PM
  #14786
Number 11's Avatar
I would like to know that same info as StepPins I am running at a similar track setup and it would greatly help us both.
Old 03-14-2005, 02:12 AM
  #14787
asw7576's Avatar
Default Servo question
Is it necessary to put 13 kilo servo for steering ? wanna make my mtx3 bullet proof
asw7576 is offline
Old 03-14-2005, 06:57 AM
  #14788
afm
afm's Avatar
Default Re: MTX-3 Noob
Originally posted by StepPins
Hi guys,
RUBBER TIRE SETTING
FRONT
Track widht 198mm
Ride height 5mm
Camber -1
Caster 2mm
Toe 0.5 out
Rebound 1mm
Bumpstop 0
Anti-roll bar none
Steering Ackerman "B"
Front Diff 100,000
Shocks piston 2 x 1.3
Oil 60wt
Spring Light Blue
Shock position 2nd hole from top
Tires PMT Slicks 50 shore
REAR
Track widht 200mm
Ride height 6mm
Camber -2
Toe 3 in
Rebound 5mm
Bumpstop 0
Anti-roll bar stock 2mm in
Lower arm position "C" block
Rear Diff grease
Shocks piston 2 x 1.1
Oil 50wt
Spring Light Blue
Shock position 2nd hole from bottom
Upper arm outside hole
Rear uprights cut down 7mm from top with 2mm shims
Tires PMT Slicks 45 shore
There you have it, hope it works for you
AFM
afm is offline
Old 03-14-2005, 07:32 AM
  #14789
teammpp's Avatar
Default Re: Servo question
Its a nice thing to have but 8 kilo is still more than capable.
teammpp is offline
Old 03-14-2005, 07:43 PM
  #14790
nitrodude's Avatar
Can someone tell me the diameter of the first gear spur for the .8 gears on the MTX3? Im working on a little something . and I need that information.
Thanks.
nitrodude is offline
