Old 02-17-2005, 04:24 PM   #14656
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Originally posted by Scott Fisher
If you want to go to the 16/19 conversion, you will need to buy a set of stock Mugen pulleys. This by the way is a conversion for the side belt. I tried the conversion and liked the car with the stock pulleys better. I do not have the excessive tire wear that many others have, but that could be because I try very hard not to slide the car. Either way if you want to try it, it is very easy. As I stated, buy a bag of the stock Mugen pulleys. Remove the front/side pulley and put it aside. Remove the rear 19 tooth pulley and put in on the front. Out of the bag of new pulleys, get the 16 tooth pulley and put it on the rear. You will have to also get the 19/16 belt which is shorter than the stock belt. You are ready to go. Quick and easy. I do not use any aftermarket parts on my MTX prospec and have managed to make the A main at the last two events here in Vegas. The car is quite good out of the box. The only thing I really want to get and have just been lazy is the Kaw 5th body post.
dont forget you need to run 4mm split front to rear tire
Ah10 is offline   Reply With Quote
Old 02-17-2005, 04:47 PM   #14657
gonzoY5's Avatar
I'm starting to think it depends on the tire wear of the track. Ft. Myers had awesome traction and ultra low tire wear. The mugen guys were using stock pulley setup. I'm totally confused about it lately. I've been using a 23t front pulley lately. You only need a 2.5mm split and the rolling resistance is MUCH less. My local track is tough on tires. Stock setup eats rear tires. With the 23t up front, my wear stays relatively even.
gonzoY5 is offline   Reply With Quote
Old 02-17-2005, 05:42 PM   #14658
gijoe64's Avatar
Trader Rating: 30 (100%+)
My car was very fast and your right Team Mugen was running the stock setup and car.
gijoe64 is offline   Reply With Quote
Old 02-17-2005, 11:34 PM   #14659
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I do not run that large of a tire split. While he certainly does not know everything, I had a long conversation with Robbie Collins regarding the tire split. He told me at that time that he does not run the 16/19 conversion. For the stock pulleys he told me he will run a 1.5mm split at the most. That is for the start of a 1 hour main. I have been using the stock pulley setup and start with a 1-1.5mm tire split. I have never used a split larger than 2mm. When I did try the 16/19 conversion, I ran a 2mm split and my tire wear stays even with both setups.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 02-18-2005, 02:42 AM   #14660
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
What is the best way to get more on power steering? Small tight track, running a Diff in the front, or should I run a one way. I like the diff because the track is small, and I need the brake.
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 02-18-2005, 02:52 AM   #14661
asw7576's Avatar
Front caster all the way back ( more laydown ) gives you more steering on full / half throttle.
Old 02-18-2005, 12:34 PM   #14662
less front droop and or stiffer rear springs.
Old 02-21-2005, 10:28 AM   #14663
asw7576's Avatar
Hey, I've got question too : Right know my car is stable and quite okay to drive......., it doesn't spin or flip.
My question : why I feel the car is not perfectly "stick" to the road ?? It doesn't have "on rails" feeling in fast sweeper or fast straight.
Please give me some inputs how to achieve that and I will try your inputs one by one.
Thx.
Old 02-21-2005, 10:35 AM   #14664
InitialD's Avatar
Your car probably has too much rear traction. The rear end needs to slide a little to be fast.
Old 02-21-2005, 11:08 AM   #14665
Number 11's Avatar
Guys,
I was given a MTX-3 Prospec at the end of last summer but never got a chance to drive it since our racing program ends once winter comes along. Anyhow I finally got a chance to clean the car up this past weekend and I got to say impressive car the thought that went into is impressive can't wait to get a chance to drive it once the weather warms up. The only thing I didn't like about it was removing the rear diff. I am so used to my NTC3 where breaking the car apart is extremely easy.
But I do have a question what is a good general setup for this car on rubber tires. I will be running on smooth sealed asphalt with VHT.
Number 11 is offline   Reply With Quote
Old 02-21-2005, 11:33 AM   #14666
asw7576's Avatar
What spring color, piston hole and oil weight do you suggest D ? for front and rear ?
Old 02-21-2005, 01:53 PM   #14667
Number 11's Avatar
I think I might have found setup info off the website I will try it out I hope this weekend if the weather holds up. Hopefully the setup works with rubber tires.
Old 02-22-2005, 02:52 AM   #14668
rcabj's Avatar
Default steering ackerman & rear block
hi....need confirmation regd. the steering ackerman...A is for quick steering, B medium steering and C slower than A & B..?
also rear blocks A more grip,B medium grip and C less grip?
thank u...
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 02-22-2005, 08:39 AM   #14669
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
Default easy diff
the only thing I didn't like about it was removing the rear diff. I am so used to my NTC3 where breaking the car apart is extremely easy.
the rear diff does come out fairly easy you take the rear brace off that is on top of the bulkhead, then remove the four screws under the chasis that holds the bulkhead and the two screws that are horizontal in the rear block. then the whole assembly comes right up, it takes two minutes then you can work on the diff. hope that helps good luck very good car Peter
Team Kyosho, Team Epic, IDM Engines, J-Tech racing fuels, Airtronics, Superiorhobbies.com
Speedypeterb is offline   Reply With Quote
Old 02-22-2005, 09:27 AM   #14670
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default Re: steering ackerman & rear block
thank u...
On the rear blocks: A = less rear traction B=Med. traction C=Most rear traction
Steer ackerman I almost always seem to go back to the C ackerman. I feel that it gets the car into the corner better. I tend to charge the corners a lot!
The B is standard and the A gives you the least amount of ackerman.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
