Old 02-03-2005, 09:43 PM   #14611
gentleman81's Avatar
in the xrc article robbie collins has his right next to the pipe on the radio plate. or either it is held in place by the tightness of the fuel tubing its is wrapped with those tubing clips or whatever and i dont think it has enough slackk to move,, issue jul 104 small but very good article near the end on his car and setup
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 02-04-2005, 12:49 AM   #14612
rcabj's Avatar
does this pressure 'solution' thing got something to do with fuel in the tank vibrating and causing bubble...
anyway this is how mine is (wihout press. chamber...just a longer line)
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 02-04-2005, 04:43 AM   #14613
gonzoY5's Avatar
Yeah I've been trying to find that mag, but now RCX is sold out of it on back issues. Has anybody scanned it or anything? I'd love to read it.
OH yeah, anyone else with pics of how they mounted their pressure chamber? Thanks
gonzoY5 is offline   Reply With Quote
Old 02-04-2005, 05:35 AM   #14614
eric i have the article. remind me next time i am at the track
H STAMEN is offline   Reply With Quote
Old 02-04-2005, 06:57 AM   #14615
cdelong's Avatar
Default Re: Mugen Pressure Chamber
Originally posted by gonzoY5
Anyone have any pics on how you've mounted your Mugen pressure chamber? I jsut got it and I'm trying to figure out how to mount it cleanly.
I secured mine to the radio tray with a zip tie. Place it on the side of the fuel tank next to the pipe and put a zip tie around it and the radio tray. It fits perfectly.
I put the one for my MRX-3 in the same place, bt this pic gives you an idea of where it goes. The MRX-3 has a mount for the chamber, but it looks too big for it's smaller brother.
cdelong is offline   Reply With Quote
Old 02-04-2005, 04:22 PM   #14616
Default damn mugens are pretty
thats a sweet ride man
Old 02-05-2005, 06:53 PM   #14617
Seisick's Avatar
Im using front diff and stock pulleys, hows the wear compared to using one way, with one way I had to use a 2 rears with 1 front is using 42 front 40 rears, which Illbe using with the front diff also.any advise welcome, just wanted to make sure that Ill make the right order about tires,
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 02-05-2005, 10:15 PM   #14618
afm
afm's Avatar
One -Way is best used if you have a large open and fluid track. If your track is short and tachnical, with lots of braking turns, you're best off with a differential, regardless of tire wear.
AFM
afm is offline   Reply With Quote
Old 02-06-2005, 02:45 AM   #14619
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
I just put a diff in the front and switched the diff in the rear. I was playing on a "sandy" steet, just checking breaking and the way the car felt. I was supprized to see the difference. I am goin gto run it today on a small tight track. I did notice that with the one-way, I could stay in the throttle coming out of a turn and it would pull the car out of a slide, but with the diff in the front, I had to blip the throttle and the car snapped back. Now I have to figure out which is faster.
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 02-06-2005, 06:37 AM   #14620
Seisick's Avatar
track is short tight and very technical, which I managed to run using one way. but Im trying now the front diff and times are lower. is the wear the same as if using one way?
HobbymaniA
GoT MuGeN?
Old 02-06-2005, 08:05 AM   #14621
gonzoY5's Avatar
Wear should be pretty even.
Old 02-06-2005, 09:13 PM   #14622
asw7576's Avatar
Does rear chamber affect handling so much ?? My car occasionally flipped in tight corner
Old 02-06-2005, 09:53 PM   #14623
rcfoolz's Avatar
Car flipping in tight corner=TRACTION ROLL Try to take some grip out of the car by going to harder tires. I ran today on a tight technical track. Car with a diff in the front, I ran 3 heats and a main and had 4mm of wear in the rear and 1 in the front, using a 16-19 conversion. Car was setup to be agressive in the turns. The way the ran with the diff in the front was nice, I had breaks, but didnt' need them but for the end of the straights. I experianced traction roll too at the end of the day, but I noticed the car would not roll if I stayed on throttle in the turns, but when I let off, it would roll up on two tires. Another car had the one-way and he noticed the rear of the car was very loose.
Old 02-06-2005, 10:08 PM   #14624
Hello I need help in choosing servos for throttle and steering. Here are the servos that I currently have.
1. Futaba S9404 analog (discontinued) 79.20 oz/in. and 0.11sec at 6v
2. KO 2173 analog - 111.0 oz/in and 0.09sec at 6v
3. KO 2343 digital - 111.0 oz/in and 0.08sec at 6v
Which one should I use for throttle and for steering?
Also how long does an 800mah 5 AAA battery pack last using a digital and an analog servos plus failsafe?
penggoy is offline   Reply With Quote
Old 02-06-2005, 11:27 PM   #14625
rcfoolz's Avatar
If it were my choise, I would use #2 for throttle and #3 for steering.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
