Old 01-20-2005, 07:19 PM   #14536
gentleman81's Avatar
well u r right i haven got the tools yet but i want to know what adjustments make what changes in the car, sway bars front and back, shock oil and springs, and my car doesnt like to turn with much speed in the corners? any help is needed, i will get the setup tools shortly, what all do i need.
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 01-20-2005, 07:25 PM   #14537
mckrooz's Avatar
Send a message via AIM to mckrooz
You need:
Camber gauge
Ride height gauge
Droop gauge
and maybe a set of calipers if you wanna really get some measurements exactly.
If your car is not turning in the corners, try a softer shore front tire. If it still pushes, lay the front sway flat(if not already). Softer springs, raise ride height, move shock to inner hole. These things soften up the front to give you front traction. Having the sway vertical will stiffen it. It's good for high bite and quicker steering response. Let us know what else you need to know.
Kyosho RRR Evo2
mckrooz is offline   Reply With Quote
Old 01-20-2005, 07:32 PM   #14538
how do u set the front and rear sway bars,???
front, push it up or down and tighten the screws , and how tight do you tighten those screws should the sway bars be able to rotate or not, and what does that cam do?
rear, move the mounts in and out, what do its adjustments do?
Old 01-20-2005, 07:37 PM   #14539
BrainTeased's Avatar
sorry guys i know this may sound repeative but any news on mtx-4 yet?
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 01-20-2005, 07:39 PM   #14540
mckrooz's Avatar
The front should not rotate. Just make sure both sides are the same and that the ball end that meets the cup is not too close where it would cause binding.
Rear: moving the mounts in stiffen the bar.
As for the cam on the front, I can't really explain it but there was a website that explained it. I think it was the Xray site. Basically it was adjusting it so that the right wheel lifts up the same amout as the left. (with sway bars disconnected)
Kyosho RRR Evo2
Old 01-20-2005, 08:10 PM   #14541
OZDC's Avatar
Trader Rating: 16 (100%+)
Brain,
Rob Reade was at a recent SE Asian distributiors meeting and there was no mention of an MTX4.
His opinion is that, there is sure to be a new car out at some stage, his guess is later this year at the earliest.
Again this is just his opinion, he has been told nothing.
DC
OZDC is offline   Reply With Quote
Old 01-20-2005, 09:31 PM   #14542
MTX-3 Kid's Avatar
Hey peoples
What shock lengths do you guys run on your suspension for the Front and the Rear?
Thanx
MTX-3 Kid is offline   Reply With Quote
Old 01-20-2005, 09:49 PM   #14543
afm
afm's Avatar
Front: if you put the blades flat i'ts the softest setting, The more you rotate them from flat to vertical the more stiff it gets.
Screws should be totally tight so the blades don't move from were you set them. The cam is to compensate one side from the other so the lower arms are leveled one against the other to were you set your droop.
Rear: move upper mounts in = more stiff. Move them out = more soft.
In general sway bars are to compensate weight transfer of car in turns. In straight line they don't work. This allows to use a softer spring on bumpy and low traction tracks and have the needed stiffness of suspension on turns. On the other hand if you have to much traction, the stiffer you set them prevents traction rolling.
AFM
afm is offline   Reply With Quote
Old 01-21-2005, 03:24 AM   #14544
Taylor-Racing's Avatar
Originally posted by MTX-3 Kid
Hey peoples
Thanx
Dunno the actual lengths off hand, but the rear ball ends have no thread showing.
With the fronts, there is about 3mm of thread showing 'cos we couldn't get enough droop for some situations.
Taylor-Racing is offline   Reply With Quote
Old 01-21-2005, 12:01 PM   #14545
asw7576's Avatar
AFM
AFM, I don't use rear swaybar. From your experience, my car should be oversteer or understeer without rear swaybar ? My goal is to achieve perfect straight line stability at full throttle but I don't want to get oversteering problem too.
Thanks for your input.
Old 01-21-2005, 12:17 PM   #14546
afm
afm's Avatar
Well, i race on rubber tires, and on a medium grip track, and i use sway bars on both axles.
Normally if you use a sway bar on one axle only, it transfers more grip to the opposite axle, so it depends on what your car is doing.
I use Dark blue springs at front, and light blue at rear,with both sway bars on the softest position.
AFM
Old 01-21-2005, 12:26 PM   #14547
asw7576's Avatar
AFM : Thanks alot, man
The dark blue at front is 1.7 diameter.
I want to know more about light blue spring at rear. Is this equivalent to 1.6 diameter ? Is this Mugen springs hop up ?
Old 01-21-2005, 12:44 PM   #14548
afm
afm's Avatar
This is Mugen's MTX 3 spring chart:
FRONT:
HO523 purple 1.6mm
HO524 light blue 1.7mm
HO533 dark blue 1.8mm
REAR:
HO527 purple 1.6mm
HO528 light blue 1.7mm
HO534 dark blue 1.8mm
AFM
Old 01-21-2005, 02:47 PM   #14549
ok now i have laid the front and rear shocks all the way down to the inner whole, i have the rear sway bar at its outer most point on the ends, i have the front sway bar flat and i need to tighten it so it holds the setting.
so if the softer springs give you more traction and i am running the stock blues what color spring will give me more traction?
also i amd running the side belt conv, to help me save on tires, should i put the stock pulleys and belt back on or does this setup help me in the corners, i saw someone wrote it helps the car pull through the turns (belt conv.)
and for more traction i also need to raise my ride height?
front or rear?
Old 01-21-2005, 03:07 PM   #14550
afm
afm's Avatar
front or rear?
What tires are you running, Foams or Rubber???
Side belt pulley conversion is to give different overdrive ratio when running on foams to compensate for running smaller front tires and or more foam wear on front. If you run Rubber you need the stock pulleys and a front diff.
I run with rubbers with front diff, and stock pulleys. My shocks are on the 2nd hole from the top up front and totally laid down on rear, with dark blue springs up front and light blue on rear.
afm
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
