Old 01-13-2005, 09:06 AM   #14476
Sow&Steady's Avatar
Default Re: re: tyre truing
Originally posted by xtreme888
Hiya,
I never true my tires in my MTX 3 ( i do in 1/8th !!!)......Found that trued tires did not affected lap time that much...actually i was quicker with tires out of the box rather than with the recommended split. I normally uses one set front to three set rear ( tired kawahara conversion 16/19...rear still wear at the same rate....hence gone back to stock setup.....
There are some good drivers at my club, whom will always truing their tires. i am not exactly slow at my club, as when i race with some top drivers such as mark green, i would be second and about 0.5sec behind.
Can any other MTX 3 owners out there verified that truing tires had not made any different to their lap times, and some explanations why not ? Coz i don`t know why....whereas in 1/8th it`s very important !!!
Hiya,
Where do you race? Which track I mean?
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 01-13-2005, 09:17 AM   #14477
Default Sow and Steady
Hiya,
Down at crystal palace ( London ).....what about yourself ?
xtreme888 is offline   Reply With Quote
Old 01-13-2005, 10:00 AM   #14478
Seisick's Avatar
Default Re: tire wear
Originally posted by Slotmachine
You will never get a fast set up that has perfectly even tire wear.It just doesnt work like that.
Where do you live? You can get great tires at a low price here in the states. WWW.RCTexas.com This guy also carrys a low cost pretty descent tire truer,made by G.Q.
As far as the pullys, I have always used the stock ones.Do you run on a permanant track or a Car Parking lot?
Ecuador, Southamerica, running on a new race track. rear tires end up 6mm smaller than front when using stock belts and one way. if using the same compound. such as 42. any suggestions on truing at least the front ones, i was thinking about 3-4mm split. so the handling will not differ too much as the tires wear out.
if using the front diff with stock pulleys, the wear is the same?
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 01-13-2005, 12:25 PM   #14479
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default Re: Re: tire wear
Here in the USA a lot of guys run 40 fronts with 42 rears. If the rears are wearing 6mm , are you talking about starting them as new? Have you tried to true them down first?
When I was a the Nats. in Ohio, I started the tires at 58mm and could run practice, 4 qual. and the warm ups for the qual`s.
For 1 hour mains, the racers started the tires out at 60mm, and still had tire when the race was over.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is online now   Reply With Quote
Old 01-13-2005, 12:39 PM   #14480
cdelong's Avatar
Default Re: Re: Re: tire wear
I've never heard of anyone running softer fronts than rears......
generally F & R are run the same with the front's possibly slightly harder- ie. 40 rear/42 or 45 fronts.
cdelong is offline   Reply With Quote
Old 01-14-2005, 12:26 AM   #14481
rcabj's Avatar
Default Re: Re: Re: Re: tire wear
seriously there r guys who does, which bring us to driving style & setup preference . i myself did try but was more comfortable with the same shore all round
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 01-14-2005, 05:08 AM   #14482
hi guys. i am new to mtx3 and 1/10 scale.
what is the correct way to setup brakes with the oe-way up front.
cheers??
KyoshoKev is offline   Reply With Quote
Old 01-14-2005, 06:08 AM   #14483
rjl
rjl's Avatar
I will often run softer fronts than rears, it helps even out the tyre wear and is by far the easiest way to get steering. On my home track I run one front 35 and the rest 37, most don't know how I manage to go inside them on the fastest sweeper.
I bet most have radios with steering balance and dual rate but never use the features they paid the extra dollars for.
rjl is offline   Reply With Quote
Old 01-14-2005, 06:29 AM   #14484
Seisick's Avatar
I dont have access to a tire truer right now, Im saving money with some friends of my track so well purchase it later. tires 42 front and rear end up with a 6mm difference without being trued if using stock belts and one way.
Ive never tried running front softer than rears, but according to slotmachine,I will never get a fast set up that has perfectly even tire wear.It just doesnt work like that, but anyway Ill give it a try compare times, handling wear, etc; and the other temporary solution is to use only the fronts, and wear them down.
now heres the thing that Id like suggestions, if using untrued 42 ellegis all around, stock pulleys and one way, the rear ones end up 6mm smaller than fronts. To what diameter do I have to wear down the front ones (remember I dont have truer now) so handling is consistent and wear is similar? I was thinking on running the front ones at 62 and rears not trued at 65mm. suggestions!
HobbymaniA
GoT MuGeN?
Old 01-14-2005, 06:47 AM   #14485
rjl
rjl's Avatar
Seisick, perhaps you should get 3 pair of rears to one set of fronts and change rears with every tank or heat, get a good vernier and always keep the front smaller than the rears with a one way, and very close to the same size with a diff.
To do truely fast lap times you will need access to a truer even if just to radius the edges.
Old 01-14-2005, 05:27 PM   #14486
rcabj's Avatar
cheers??
hi there.....frankly at least to me, one way means no brakes
seriously u just need to set your braking so that it would not tail out....that is how i did to mine....u wouldn't get the kind of braking that is available with the gear diff/solid....good luck
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 01-14-2005, 05:35 PM   #14487
ok.. i was seting up brake last nite...
i do like this....
set brake epa to max.
drive in a straight line and then apply full brake.... if it spin out then decrease epa..
repeat untill when i brake in a straight line, the rear does not kick out
would this be a good approach.
this would give me max braking but not enough to make the car spin out?
also, other than the fuel tank hole in the body, should i make more body holes? or the less holes the better for better aerodynamics etc.
cheers
Old 01-14-2005, 06:02 PM   #14488
rcabj's Avatar
i do like this....
cheers
i think u got the braking thing... anyway as to holes u really need them to help cool your engine...and normally (for club racing) is 1 front usually 50mm, 1 rear 70mm and both front side windows..
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 01-14-2005, 06:58 PM   #14489
Sow&Steady's Avatar
Default Re: Sow and Steady
Hiya,
I'm even further down ... in Aldershot.
Do you have track pictures of Crystal Palace? I plan to do the nationals this year and can't find much info about your club. In fact, do you have a website?
Thanks and looking forward to meeting you one of these days a t Crystal Palace!
Old 01-14-2005, 07:00 PM   #14490
Sow&Steady's Avatar
I do that a lot if I feel that the car is not balanced enough. Another reason is that I run the one-wa a lot and with it, your rear tyres wear a lot quicker than when you use diffs or a solid front axle.
Lastly, it is always easier to dial out steering rather than not have enough.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
