Old 01-03-2005, 11:52 PM   #14446
asw7576's Avatar
Yes, I mean the amount of play at suspension shaft before the wheels lift off the ground.
All caster clips are position behind the upper arm.
uurrghh....... I can't wait to test it.
Would you like to guess ? do you think the car will be stable or no ?
Old 01-04-2005, 12:18 AM   #14447
InitialD's Avatar
My guess is that this is the one making the car very unstable on the straights and making high speed turn ins understeer while low speed you would turn in fine...
When you turn to the right for example, the small caster angle makes less optimum wheel contacts to the surface (not enough camber) when the front leans to the left side. With more caster, the contact patch of the wheel increases and you get more steering. Try putting it at neutral or at where the stock setting is. If you insist on running the caster this way, you need more front camber dialed in.
For more advance reading, you can read here which applies to all cars. Good luck.
Old 01-04-2005, 12:18 AM   #14448
InitialD's Avatar
Old 01-04-2005, 07:52 AM   #14449
cdelong's Avatar
asw- you need more rear droop. 4- 5mm would probably be fine. 2mm is not enough.
cdelong is offline   Reply With Quote
Old 01-04-2005, 08:20 AM   #14450
InitialD's Avatar
You're quoting values from the droop gauge... asw is quoting values of the chassis uptravel before the tires leave the ground...
Old 01-04-2005, 10:06 AM   #14451
cdelong's Avatar
guess I just figured everyone used droop gauges......
Old 01-04-2005, 03:39 PM   #14452
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default Yes!
As InitialD said more caster will create more turn in but there is another reason for this. When you turn the wheels it forces the chassie to unload the inside rear wheel which will give the rear less grip at that instant.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 01-05-2005, 04:16 AM   #14453
asw7576's Avatar
Thanks everyone,
I changed upper arm's caster position to middle, so it doesn't lean backwards or forwards too much. I observed the front tyres's contact, the tyres actually have less surface contact at full turn position, but the "dig in" or "bite" angle is much steeper.
Another adjustment is smaller EPA ( end point adjustment of steering servo ) and negative EXP ( exponential ).
About the droop thing, yes I made estimation by measuring the upward chassis movements before the tires lift off.
Pardon me guys..... my first engine cars.
Old 01-05-2005, 04:24 AM   #14454
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
kawahara hop-ups
guys, where can i buy kawahara hop-ups for my mtx-3. looks like some hobby shops are already discontinuing these parts since i've been looking for them these past few days. been looking already with online shops but not complete with the hop-ups that i needed. any help will be greatly appreciated, thanks
buboy28 is offline   Reply With Quote
Old 01-05-2005, 04:49 AM   #14455
asw7576's Avatar
RC champ in Japan, you can mail order through them.
Btw, 3 racing is good enough u know and it's cheaper.
I think mtx3 only need these hop up options:
alluminium 4mm chassis ( very strong but heavier )
alluminium radio plate tower
alluminium center pulley holder for front belts
titanium screws, hopefully longer ones by 2mm and 4mm
alluminium front stabiliser holder
Old 01-05-2005, 04:46 PM   #14456
smracer31's Avatar
Send a message via AIM to smracer31
i think one more would be the rear adjustable sway bar.... makes it easier to adjust without having several different tension bars.
smracer31 is offline   Reply With Quote
Old 01-06-2005, 09:47 AM   #14457
Arushmen's Avatar
Default Re: kawahara hop-ups
I have been bought here
http://acehardwarehobbies.com/
http://shop.the-border.nl
and here
http://www.speedtechrc.com/
XB9 x 2
http://txvzla.blogspot.com/
Arushmen is offline   Reply With Quote
Old 01-07-2005, 12:20 AM   #14458
rjl
rjl's Avatar
asw, you must not run the tyres (english) untrued. The fronts will be too large and it will get worse. Out of the box, Zacs are usually 66mm front and 65mm rear.
I find that 35s are good on low grip so I assume that is the conditions you run.
I would set the ride height to 7.5mm both front and rear on 64mm diameter, then depending on the length of the heat I reduce the front tyre diameter by an amount that will finish the heat at slightly less than the rears.
What I'm trying to say is that the car will be a pig if your front tyres are larger than the rears and it puts too much strain on the drive train.
rjl is offline   Reply With Quote
Old 01-07-2005, 03:22 AM   #14459
buboy28's Avatar
thanks asw7576 i will try that, i have a bad experience with 3 racing hop-ups with my v-one RR so as much as possible i am avoiding it and you are right it is really much cheaper than the kawahara hop-ups
Old 01-07-2005, 03:25 AM   #14460
buboy28's Avatar
Default Re: Re: kawahara hop-ups
and here
i have been with speedtechrc but cannot find what i'm looking for but i will also try the other two sites that you recommended thank you very much Arushmen
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
