Old 12-22-2004, 06:21 PM   #14386
AMGRacer's Avatar
The stratus is still a great body for tracks where the grip is high and you want fairly low drag. It is not outdated, but it just needs to be used in the right circumstances.
AMGRacer is offline   Reply With Quote
Old 12-22-2004, 10:14 PM   #14387
asw7576's Avatar
Default Re: asw7576
Originally posted by Slotmachine
I noticed in your picture of the car you run purple front springs and white rears, do you have a steering issue?
Try the ( C ) ackerman on the bellcrank, it will give you better corner speed with lots of turn in.
If you can get some GQTires WWW.RCTexas.com
I haven't test it yet, ....... it's new car.
Those springs come from xray t1 fk, they are more progressive than mtx's.
Could you tell me the effect on A-B-C steering bellcrank ? I'm using A as in the book.
Old 12-23-2004, 02:53 AM   #14388
rcabj's Avatar
asw 7576...
i notice your rear window opening is rather small.... i feel your engine will not get enough cooling air......u probably would suffer overheating problems just my couple cent....
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 12-23-2004, 02:55 AM   #14389
rcabj's Avatar
asw 7576...also your rear tire is 26mm wide... or that was for picture purposes only... should be 30mm rear
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 12-23-2004, 04:55 AM   #14390
asw7576's Avatar
Thanks dude..... My LHS buddy also suggest another side hole or open the rear windscreen as wide as possible.
BTW...... is it true the front / gas tank hole's and ignition hole's diameter are regulated ? can't cut over otherwise get disqualification ?
I'm using 26mm tires all around because I'm thrifty...... I can switch back on forth the front and rear tires. It should be okay, right ?
Old 12-23-2004, 05:05 AM   #14391
AMGRacer's Avatar
That wont work, the front and rear are quite different rubber/foam compound.
Old 12-27-2004, 12:29 AM   #14392
asw7576's Avatar
Wow..... JP FX engine is awesome !!! The power is endless..... Even on the first gear, the roar is loud and long. I haven't test second gear yet, my car it's not stable yet..... even with wider rear tires.... sux
Old 12-28-2004, 03:14 AM   #14393
VenomWorldOrder's Avatar
that's because you are using rears at the front or fronts at the rear as you stated above. use fronts at the front (36mm) and rears at the rear (30mm) and it will be fine.
VenomWorldOrder is offline   Reply With Quote
Old 12-28-2004, 03:38 AM   #14394
smracer31's Avatar
Send a message via AIM to smracer31
you mean 26mm in the front
smracer31 is offline   Reply With Quote
Old 12-28-2004, 06:23 AM   #14395
Canuck's Avatar
Trader Rating: 25 (100%+)
Anybody try Twister tires ?
TWISTER TIRES
Canuck is offline   Reply With Quote
Old 12-28-2004, 06:28 AM   #14396
Sow&Steady's Avatar
Yes surely....
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 12-28-2004, 06:29 AM   #14397
Sow&Steady's Avatar
TWISTER TIRES
The rims look similar to the Enetti Serpent foams so if they're similar then they're awesomely strong and lots of grip.
Old 12-28-2004, 06:33 AM   #14398
Canuck's Avatar
Last year, a guy at the track had them on a Serpent 710 and was very pleased with the compound.
Old 12-28-2004, 06:44 AM   #14399
JustRace's Avatar
TWISTER TIRES
Great tires!! The rims are super strong. Also the foam compound is consistent and provides plenty of traction. Give it a try and see for yourself. Customer service is also great.
JustRace is offline   Reply With Quote
Old 12-28-2004, 06:51 AM   #14400
Canuck's Avatar
Will do ... Thanks.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
