Old 12-27-2002, 07:01 AM   #1426
eurokrn the screws will not strip without a good set of wrenches your hand may get tired trying to tighten the screws the mugen cars dont have the stupid problems the ntc3 does in that respect mugen far exceedes the ntc3 ive had both
jason102276 is offline   Reply With Quote
Old 12-27-2002, 07:16 AM   #1427
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by dtm
705 in MK now!.....price damn good!!! HK$26xx
it is the pre-order price !
Manticore is offline   Reply With Quote
Old 12-27-2002, 08:48 AM   #1428
dtm
dtm's Avatar
Send a message via ICQ to dtm
No...hand over cash and take home car price!!
dtm is offline   Reply With Quote
Old 12-27-2002, 11:19 AM   #1429
Vinyard's Avatar
i was wondering if u guys had a problem with the MTX3's front dogbones? it seem that its abit shory and mine keep popping out after a minor crash at my local track..
Some guys advised me to change to MTX2's dogbones are they are slighty longer.. will it help?
Manti.. loved your hop ups.. where did you got them?
any links to some of the hop-ups you got?
Vinyard is offline   Reply With Quote
Old 12-27-2002, 11:59 AM   #1430
Ok, that's good to hear.. I have a Hudy set so putting the car together was no problem.
EuroKRN is offline   Reply With Quote
Old 12-27-2002, 12:39 PM   #1431
vinyard the front dogbones on my car came out you can fix this a couple of ways
you could put orings into the outdrives
you could get mtx-2 bones because they are longer
or get the universals
Old 12-27-2002, 05:39 PM   #1432
Manticore's Avatar
sorry, they dont have a web site. But you can go to kawahara site to check out the hop up they made for MTX3
http://www.j-net-c.com/kawahara/
Old 12-27-2002, 07:18 PM   #1433
Send a message via Skype™ to JordanC
I've had the pleaseure of going through all of these solutions and end result decided that CV's are going to be the best solution. I've found the steering uprights very flexible and at full lock under power the doggies can actually snatch and come out. I don't like the price tag on the CV's but i can't see any viable alterative.
JordanC is offline   Reply With Quote
Old 12-27-2002, 09:19 PM   #1434
After paying a visit to my LHS today, I heard about the "first 200 MTX3 kits" surprise..
When I got home, sure enough, my kit (which I got from SpeedTech the first week) came with the turbo engine RS-12TS..
Does anyone have specs for this engine including the number of ports? (I haven't bothered taking the engine apart to find out). Oh, and which RB plug is good for this engine running 30% nitro?
Old 12-28-2002, 03:11 AM   #1435
Corse-R's Avatar
Default Got a MTX3.... questions, questions, questions....
Hi all:
Santa put an MTX3 on my 'stable' some days ago and starting to assemble (mid assembled nowadays) I have read the manuals and have some questions.
When assembling the rear end, had three choices of A-arms to install (High, Med, Low) what are the purpose of them? (Adjusting the roll center????). Installed the Medium ones.
On the servo saver I have three choices (of ackermann I suppose). Installed the B as manual stated but none words about those two parts and how to choose.
About the rear gear diff. Put the 10000 silicone, my track is plenty of grip (normally we use 42/42 or 45/42) nowadays with damp weather we use 40/40 or 40/37 it's OK for high traction or is wise to install a solid axle at rear.
About gear ratios. Seemed a 'little short'. My track is very ample and flowing with a >200Ft backstraight... my engines are a Sirio ROAR and one RB 'Rody 3 port' (1700-215) - with this engine 21/27 on 54/48 on my NTC3 is fine. Some people suggested me to use larger pinions from Yokomo, it's true? Mugen ends at 20 for the second gear.
Manticore: Saw your MTX3 photos some pages ago and seemed weird to change the steel screws on the lower chassis for some titanium ones. On my opinion is the best place to have some weight. Can shed some light on this?
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 12-28-2002, 06:56 AM   #1436
Send a message via ICQ to Cartman
Default Re: Got a MTX3.... questions, questions, questions....
Originally posted by Corse-R
Hi all:
they do alter the roll center but what effect it has im unsure
alters the ackerman , i think the more akerman the more intitial turn in , but someone that knows please correct me.
i run rubber tyres sorry
Mugen do make bigger gears think i have a 22 somewhere, but take into account the overall ratio!
Manticore: Saw your MTX3 photos some pages ago and seemed weird to change the steel screws on the lower chassis for some titanium ones. On my opinion is the best place to have some weight. Can shed some light on this?He's got plenty of money
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 12-28-2002, 07:03 AM   #1437
Default Ackerman and roll center's
Can someone please clarify this for me
roll center changes will make the car handling change in what way?
ackerman changes will make the car handling change in what way?
Old 12-28-2002, 08:03 AM   #1438
InitialD's Avatar
Default Re: Ackerman and roll center's
I believe your answers can be found here;
http://www.teamxray.com/teamxray/pro...&kategoria=253
Old 12-28-2002, 08:31 AM   #1439
Default Re: Re: Ackerman and roll center's
sorry but i asked what handling changes will be noticed. your link only tell me what ackeramn is NOT what it does!
Ackermann And Steering Throw Symmetry
Ackermann is a term describing the effect of the inside front wheel turning tighter than the outside front wheel. We have designed the T1's steering system with the optimal Ackermann setting for a touring car, so you do not need to waste time adjusting it. But it is important that turning radii
are the same when the car is turning either left or right.
(click to enlarge)
Put the car on a Hudy Set-up to make sure that the steering turns as sharply to the left as it does to the right. If it is not the case and if your radio has EPA (End Point Adjustment) settings, adjust the EPA on your transmitter in order to achieve symmetry The wheels should turn equally in both directions for balanced handling.
(click to enlarge)
When adjusting the servo, the steering must be adjusted in the way so the steering block does not hit the pivot balls. If it does decrease steering throw with your radio's EPA setting or with the dual-rate setting, if EPA is not available.
Old 12-28-2002, 05:54 PM   #1440
Cartman can you tell approx. how much the shipping is for your area to the USA East Coast. Please let me know if you can find out any info for me.
mobil1rac is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
