Old 12-19-2004, 11:19 AM   #14371
Canuck's Avatar
Trader Rating: 25 (100%+)
Traction is good with some VP sprayed on the track !
I use 40 shore front and back.
Canuck is offline   Reply With Quote
Old 12-19-2004, 12:25 PM   #14372
j240z's Avatar
Default Re: Re: MTX-3 & OS Tr engine?
Originally posted by Slotmachine
Is it the bottom of the throttle pull that hits? If it is can you loosen the screw, and rotate the throttle pull a little to make it clear?
Yes it's the bottom of the throttle mount. I can turn the linkage ball but it would need to be an extreme angle. I may need to do what Seisick said and add shims to the engine mount. Or maybe I will just dremel the radio plate...? It would barely be noticable once it's done.
Thanks for the replies guys!
j240z is offline   Reply With Quote
Old 12-19-2004, 04:17 PM   #14373
miniracer's Avatar
I have the exact same problem with a sirio engine.
miniracer is offline   Reply With Quote
Old 12-19-2004, 04:34 PM   #14374
afm
afm's Avatar
Default Re: Re: Re: MTX-3 & OS Tr engine?
I had same problem with Sirio engine. Best solution was to dremel radio plate. There is enough material and doesn't affect anything on the car.
AFM
afm is offline   Reply With Quote
Old 12-19-2004, 06:21 PM   #14375
j240z's Avatar
Thumbs up Dremel !!!
Ah yes! I just dremeled the plate! Easier fix than I thought. I sealed the cut with CA glue and everything is GREAT! Oh yeah, I also had to flip the linkage to under the servo arm instead of over the arm! Works smooth!
Thanks for the replies! I forgot how good this little TR is
Old 12-19-2004, 09:11 PM   #14376
Slotmachine's Avatar
Send a message via MSN to Slotmachine
I run all of my throttle pulls parralel with the chassie, that way all my engines are the same.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 12-19-2004, 09:17 PM   #14377
Default tires
I run 42 shore GQ Tires on a treated surface.30,000 rear diff with a one way4mm front ride height, 5mm rear.If you guys want a lot of steering, try the Cadilac body. I had my car set up well with the Alfa , when I switched to the Caddy I had to find more rear traction.
Old 12-20-2004, 03:13 AM   #14378
Canuck's Avatar
What about the Status 2.1 body ? Did you ever try it ?
Old 12-20-2004, 03:18 AM   #14379
asw7576's Avatar
Default Re: Re: Re: Re: MTX-3 & OS Tr engine?
Yup..... I also keep the throttle and braking rods parallel and flat to each other. If slide carburator ( the ball ) hit the graphite upper deck, then you need to dremel the graphite to make some rooms...... if you crash so bad, the upper deck won't hit the slide carburator directly.
I think Mugen designed the layout with Novarossi engine, so other brands need extra attention to make it perfect and safe.
I'm running JP FX 5 and FX 3.
Dodge Stratus and Ellegi Wheels.
I'll give you some pics later.
Old 12-20-2004, 03:23 AM   #14380
asw7576's Avatar
don't add shims to engine base because it interups heat transfer from engine block to main chassis.
Old 12-20-2004, 06:39 AM   #14381
Default Yes
I have tried the Stratus, it is kinda old school now. I know thats hard to believe, but its kinda out dated now.
Old 12-20-2004, 09:33 AM   #14382
Canuck's Avatar
Shoot ! I just bought two Stratus 2.1 bodies
Why is it outdated ? Are you talking performance wise ?
Old 12-20-2004, 01:16 PM   #14383
Default yes
I think you would be hard pressed to find the Stratus to be one of the most competitive bodies on the track. The new generation bodies offer more downforce and better steering. Although I hear there is a new Stratus 3.0 body coming out that is supposed to be better. Only problem is it is a 190mm not 200.
Old 12-22-2004, 03:56 AM   #14384
asw7576's Avatar
I don't mind with dodge stratus body....... I'm gonna race it as long as the body is sleek, slender and the front spoiler is small.
Mazda 6 is good and handsome looking car but the front spoiler is too thick and too forward. It easy to get damage if you hit the curbs too often.
Nemesis is perfect, my first choice. The looks little bit lame though.
Dodge stratus is perfect too, my second choice. The rear wing is smaller than the two.
Old 12-22-2004, 06:10 PM   #14385
Default asw7576
I noticed in your picture of the car you run purple front springs and white rears, do you have a steering issue?
Try the ( C ) ackerman on the bellcrank, it will give you better corner speed with lots of turn in.
If you can get some GQTires WWW.RCTexas.com
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
