Mugen MTX-3
Old 11-22-2004, 08:22 AM
  #14281
Ed Delgado's Avatar
Default Used M8 for sale
Used Airtronics M8, in good shaped, never dropped. Comes with 3ch reciever, Novak synthesized TX module and two sets of crystals plus a red MOMO-style steering wheel. Duratrax TX Bag and GP 2100 NIMH batteries included.
$250.00
[email protected]
Ed Delgado is offline
Old 11-24-2004, 02:16 PM
  #14282
Seisick's Avatar
broke my rear suspension mounts b, which one should I put to race on a high grip surface, the a or c, thanks
Seisick is offline
Old 11-24-2004, 02:28 PM
  #14283
cdelong's Avatar
I believe you'd want to install the A- blocks.
cdelong is offline
Old 11-24-2004, 04:22 PM
  #14284
Use MTX3 Prospec for sale for 300. Check ebay
Robert I. is offline
Old 11-26-2004, 09:54 AM
  #14285
tunerjetta29's Avatar
Can anyone tell me what shore the tires that come with the MTX-3 Prospec are? It doesnt seem to say anywhere in/on the box or instructions.
tunerjetta29 is offline
Old 11-26-2004, 11:26 AM
  #14286
27 i think if not 37
Cartman is offline
Old 11-26-2004, 12:06 PM
  #14287
TexasRacer's Avatar
The foam's that come with the Mugen MTX-3 PROSPEC are 37 shore.
TexasRacer is offline
Old 11-27-2004, 11:15 AM
  #14288
Arushmen's Avatar
Default Re: Re: Re: Spool
What is the number parts?
Originally posted by eddiethefish
Thanks, Slotmachine for the referral.
Here's how it looks like.
best,
fish
Arushmen is offline
Old 11-27-2004, 01:15 PM
  #14289
Ed Delgado's Avatar
Default Re: Used M8 for sale
Originally posted by Ed Delgado
Used Airtronics M8, in good shaped, never dropped. Comes with 3ch reciever, Novak synthesized TX module AND a Novak synthesized reciever, two sets of crystals plus a red MOMO-style steering wheel. Duratrax TX Bag and GP 2100 NIMH batteries included.
$250.00 o.b.o.
[email protected]
Old 11-28-2004, 06:02 AM
  #14290
dg8one's Avatar
anybody here try to used a KO reciever to a M8 radio if anybody tyied it cause i'm thinkin about using that KO reciever to my M8 radio
THANKS
dg8one is offline
Old 11-29-2004, 07:47 AM
  #14291
gonzoY5's Avatar
Default Cadillac Body
I tried the Cadillac body this weekend going from the Mazda and I found it to give TOO much steering. It was a totally different car when switching between bodies, without changing settings. I had my tail sliding out all over the place. Off power and on power, sweeping and tight turns. I played with some settings, and made it a bit more managable, but I still need to improve on it. My times were easily half a second slower. I race on a permanent track with decent traction. Has anyone else experinced this?
gonzoY5 is offline
Old 11-29-2004, 11:34 AM
  #14292
eddiethefish's Avatar
Default Re: Re: Re: Re: Spool
K-781
smiley fish
eddiethefish is offline
Old 11-29-2004, 11:39 AM
  #14293
Slotmachine's Avatar
Default Re: Cadillac Body
Yes I have tried the Cadilac and like the steering that it gives. If you need more rear bite try flatening out the top rear A/ Arm ( more parralel to the ground ). When I did that, the car was faster on the track.
Slotmachine is offline
Old 11-29-2004, 11:43 AM
  #14294
gonzoY5's Avatar
Default Re: Re: Cadillac Body
How flat do you have it? i only have a 1mm spacer there as it is. Do you think a .5mm spacer will make a big enough difference? Or should I remove all spacers altogether? I already put the stock sway bar in an it helped a bit. But I still need more bite. I'll give the spacers a try this weekend.
gonzoY5 is offline
Old 11-30-2004, 10:15 PM
  #14295
Default Re: Re: Re: Cadillac Body
If you have the option Kawahara rear shock tower, you put the arm in the top hole long. Then take out all of the shims on the outer hub, thats as flat as you can get it without cuting down the outer rear uprights.That is a trick the racers do with a rubber tire set up.
