Old 10-04-2004, 07:02 PM   #14146
gentleman81's Avatar
so if there is no real change in running the .8 gears why make them? there has to be a difference in performance.
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 10-04-2004, 08:53 PM   #14147
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default 0.8 Gears
With trhe 0.8 gears you can get a finer gear change in the ratios. You can also get a greater top end and bottom end. That is why it is worth changing.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 10-04-2004, 09:46 PM   #14148
Default roll center blocks
just purchased a mtx-3 and just after some info on the roll center blocks in the rear for a low traction surface should i be using the "c" block. No matter wat ive done in the setup so far i'm close but the car seems really taily on direction change ie through a chicane. once this is sorted i will be on fire. any help appreciated
onto greener pastures
stuff for sale associated 12r5 $175, team magic 1/10 pit bag $40, top racing pit bag $30, KO helios with spektrum module and 3 receivers $200, CEN CT5 $100 all are plus post
dangles is offline   Reply With Quote
Old 10-04-2004, 10:26 PM   #14149
chippy's Avatar
Default Re: roll center blocks
Yes you are right with the rear c blocks for low traction
rear diff oil also help 30,000 low to mid traction
50,000 for high traction
also try removing some of the shims from the top of the rear arms helps also
chippy is offline   Reply With Quote
Old 10-04-2004, 10:52 PM   #14150
rcabj's Avatar
Default Re: 0.8 Gears
isn't that same as saying u'll be getting quarter or half a second faster than the 1.0 gear...
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 10-05-2004, 02:29 AM   #14151
Picard's Avatar
To sell them to us suckers
I am not saying they are useless but I doubt you would get a benifit of half a second a lap.
Maybe somebody that has run both with the same setup and track conditions could give us some feedback
Picard is offline   Reply With Quote
Old 10-05-2004, 05:41 AM   #14152
VenomWorldOrder's Avatar
fine pitch versus normal pitch: the verdict.
normal gears due to the fact they have less teeth have a smaller, or should i say a sharper acceleration curve. what i mean by this is that power feels more "on, Off" with the coarse pitch gears.
witht he fine pitch gears due to the fact there are more teeth the curve of the power band from zero to full throttle is alot smoother. the fine pitch gears allow for a smoother acceleration and allows for a better top end and low end.
to give you an idea exagerate the situation. imagine a gear and pinion with 4 teeth. the power would be very mich "on off" due to the lack of gears touching and spinning each other.
fine pitch is like having a 6th gear in a real car (more teeth) coarse pitch is like having only 5th. ie due to one less gear, you have to shift more often and have a less smooth power band.
VenomWorldOrder is offline   Reply With Quote
Old 10-05-2004, 06:42 AM   #14153
Default gears
Why does Swagert use them? Because they are better! He has a choice on which ones to run, he chooses 0.8 not the coarse ones.
Old 10-05-2004, 06:52 AM   #14154
Picard's Avatar
Hey feel free to use them, all I am saying is that dont expect to see 1 second come of your lap times.
The 710 only has .8 personally I dont think there is anything special about them
Old 10-05-2004, 07:07 AM   #14155
Taylor-Racing's Avatar
We've used 0.8M and 1.0M on the same car and same track. Actually we've used both gear types on the Kyosho Evo as well.
The verdict in my book is that there's not a measureable difference, unless you count the rate the K gears wear out.
Taylor-Racing is offline   Reply With Quote
Old 10-05-2004, 07:19 AM   #14156
BrainTeased's Avatar
also i think with the 0.8 gears your permitted to go off a few teeth.
EG 20/50 26/46
where as 1.0 gears you had to be spot on
20/50 26/44
true?
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 10-05-2004, 07:22 AM   #14157
Picard's Avatar
EG 20/50 26/46
20/50 26/44
true?
With the .8 gears mesh is even more important, less marging for error otherwise they strip
Old 10-05-2004, 07:44 AM   #14158
ops! i was told the opposite GrRrR!
Old 10-06-2004, 10:53 PM   #14159
rcabj's Avatar
Default wheel hex..
just like to know besides the mugen wheel hex...anybody have tried other manufacturers hex that fits on to the mugen's..
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 10-07-2004, 12:20 AM   #14160
FREAKAH's Avatar
Default Re: wheel hex..
I have the Mugens ones and the 3Racing ones. The 3R hexes work fine for what they are and I have had no problems with them.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
