Old 10-01-2004, 09:52 PM   #14101
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default seting
Originally posted by gentleman81
so u loosen the screws adjust the bars then screw them back in tight? i thought it had to have some play in it, that is what i couldnt understand. how does it hold the setting
The set screws hold them tight.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 10-01-2004, 10:15 PM   #14102
gentleman81's Avatar
so the screws that go in the front of the sway bar holders not the allen key screws that set the droop correct
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 10-01-2004, 10:30 PM   #14103
Default Correct!
I push my wrench thru the foam bumper, so you dont have to take the bumper off everytime to loosen the set screws.
Old 10-01-2004, 10:37 PM   #14104
the flatter the sway bar = what?
the more angle = what?
Old 10-01-2004, 11:08 PM   #14105
rcabj's Avatar
Default Re: Diff oil
Originally posted by no4hitter
I race in Cincy and use 50,000 in the rear.
how does it feel with the 50k oil ?
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 10-01-2004, 11:30 PM   #14106
Taylor-Racing's Avatar
Default Re: Why?????
Originally posted by Slotmachine
I run 0 offset GQTires and dont have a problem with wheel rub, I dont understand why you guys are having so many problems with that.
Or is there somthing else I am missing?
I'm "told" that merely winding out the pivot balls to accomodate 0 offset wheels will affect the geometry and that we would "do this at our peril".
While the reasoning is logical, I haven't actually tried it to find out. Anyone?
Yes, the GQ wheels are very good in terms of strength/rigidity - excellent, in fact.
I also like that they fit quite snugly on the hex. Most wheels are just a "so so" fit.
The tyres themselves seem to take longer to warm up but the grip and wear seems to be fine. We really must finish testing them properly.
Taylor-Racing is offline   Reply With Quote
Old 10-02-2004, 06:09 AM   #14107
Default Diff oil
I ran 30,000 at first but we just sealed the track, now with the traction we have the 50,000 is great. I would like to try the 100,000.
no4hitter is offline   Reply With Quote
Old 10-02-2004, 08:32 AM   #14108
what does the different diff oils do in terms of handling, i am running the stock setup, and i could use more bite in tight corners. what should i try. our track is small to medium size with a technical infield and maybe to straight streches.
Old 10-02-2004, 08:47 AM   #14109
when u order the kawahara center body post do u get a body post also or just the carbon fiber plate? it just shows the plate but kfactory shows the entire unit with post. does anyone else make it?
Old 10-02-2004, 09:08 AM   #14110
If you run anything lighter in the rear diff, you may experience excessive tire wear. What happens is the inside rear tire will spin more in the corner wearing the rear tires out sooner.
As far as the body post question, you have to supply your own post with some, if it doesnt show it in the picture its not coming with the graphite.
In cincinati you have massive traction, kinda like Toledo does. In parking lots, you dont have that kind of traction. I would not recomend any stiffer then 30,000.
The flater the sway bar, the more front grip.
(-)= flat (/)=45deg. (|)= straight up less traction and body roll but more responsive.
Old 10-02-2004, 09:17 AM   #14111
thanks im gonna get the rear swaybar hopup, the aluminum one. is that one easy to set up, like i said i am running the stock parts now. and with the better sway bar u have to buy the aluminum brake bracket too right, doesnt the hopup sway bar have to mount to it?
Old 10-02-2004, 09:33 AM   #14112
j240z's Avatar
Kawahara only comes with the carbon fiber plate. I used a front post from a NTC3 and it works perfect.
j240z is offline   Reply With Quote
Old 10-02-2004, 08:03 PM   #14113
If I am not mistaken, the sway bar comes with all the nessasary parts.
Old 10-02-2004, 10:04 PM   #14114
what does the rear sway bar do for the handling, at what adjustments?
Old 10-03-2004, 10:49 AM   #14115
Default 16/19 conversion
Hi Guys,
I am running the 16/19 conversion with a metal 16 kawahara rear side pully and belt......the problem is that the 16 pully and belt are worn away very quick....belt replacement after about 4 meeting and pully about 8 meeting. Is there any plastic gear out there a can replace the metal pully with coz i noticed that the 19 plastic pully with very little wear !!! Hence was thinking if i replace the metal one the belt would last longer. Is there any other similar conversion that i can use to make the front tyres wear more quicker like the 16/19 conversion?
xtreme888
xtreme888 is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
