Old 10-01-2004, 08:02 PM   #14086
gentleman81's Avatar
thanks alot i been seaching all over for a retailer in the states that sells tires for cheap, besides Cali anyway, are there any more that you know of, texas to VA hmmm 3-4days i guess, that would be nice!
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 10-01-2004, 08:04 PM   #14087
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default 3 or 4 days...
Yes 3 to 4 days, I think he charges a flat rate shiping whether you buy 1 pair or 50 pairs. Duane the owner is a great guy.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 10-01-2004, 08:06 PM   #14088
so these are pretty strong rims huh? its a shame i have to ask but im getting better!
Old 10-01-2004, 08:09 PM   #14089
Default strong!!!!!!!!!!!!!!!!!!!!!!!!!!
I have run these rims all summer, seen 2 or 3 bent a little .I have never seen one broken. Even the 1/8 scale guys have not broken any as far as I know.
Old 10-01-2004, 08:10 PM   #14090
ching, ching, sold. i gotta get some next week, thanks for all the info. what u running as far as hopups on you mtx3? anything that makes setup easier?
Old 10-01-2004, 08:18 PM   #14091
Default hop ups
I am runing the RD Logics chassie, universals, Kawahara sway bar in the rear, Kawahara rear shock mount,Clamp on wheel hexes, 3 Racing shock towers, 3 Racing 3rd. body post in the front. At the nats I ran 58mm tires and had to add 40 grams of weight to get the car to legal, I qualified 7th. in the Masters A Main, but didnt get to run the main because of a throttle servo failer.
Old 10-01-2004, 08:25 PM   #14092
have people had probs with the stock shock towers, what are the differences?
i have the mugen uni's front and rear
16/19 conversion
clamp on hexes
i want the
kawahara,3racing, or kfactory front and rear sway bars
center body post
rear braces x2
is the brand name a thing to consider with these hopups?
Old 10-01-2004, 08:28 PM   #14093
16/19 conversion
clamp on hexes
i want the
center body post
rear braces x2
I dont run the 16/19 pullys, the shock towers are 5mm thick, RD Logics unis. are not as tough as the Mugen ones . Do you run on a permanant track?
Old 10-01-2004, 08:36 PM   #14094
not really we run in a parking lot, its the same place all the time though, its asphault, and we use real boards, wood all the way around so it will cost me less money in broken rims and uprights if i can get the best hop ups that alow me a better setup.
the last race i was doing real good but i am going on my own setup and i am playing it by ear, the sway bars are a total mystery to me? i need a setup board also, but i do ok
Old 10-01-2004, 08:51 PM   #14095
Default set up for parking lot
I run 35 front tires
37 rears
50 weight shock oil all around
front one way
10,000 rear diff
stock front springs
grey rear springs
front shocks all the way down, leaning in
rears 1 hole from leaning all the way down
front caster thin shim in the back
front camber 2.5
rear camber 3.5
rear toe in 1.5 deg. per side
front sway bar flat
rear sway bar stiffest seting on kawahara, or thick Mugen one
clutch is set up for high revs off the line
front droop or up lift is 2mm
rear droop or up lift is 4mm.
I use the C ackerman for steering
Old 10-01-2004, 08:52 PM   #14096
how do u set the front sway bar, stock?
Old 10-01-2004, 09:34 PM   #14097
Default FRONT SWAY BAR
The front sway bar is flat, for the most body roll.
Old 10-01-2004, 09:39 PM   #14098
but who do u set it physically, with the allem screws, with the cam or what?
Old 10-01-2004, 09:47 PM   #14099
Default flat
You xcan loosen the set screws on the plastic pieces, rotate the two sway bar pieces so that they are paralel to the ground. The more you stand them up, the stiffer it gets.
Old 10-01-2004, 09:49 PM   #14100
so u loosen the screws adjust the bars then screw them back in tight? i thought it had to have some play in it, that is what i couldnt understand. how does it hold the setting
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
