Old 09-09-2004, 09:48 PM   #13966
j240z's Avatar
Default CHARGE throttle servo laydown kit?
Has anyone used this? It looks sweet, but I'm looking for some feedback before I purchase it. How hard is the install? Any info would be great! Also, if anyone knows of a retailer in the US please LMK! Thanks
j240z is offline   Reply With Quote
Old 09-09-2004, 10:38 PM   #13967
Default Re: CHARGE throttle servo laydown kit?
I like the one Cartman has on his car--though I think it's not really helpful.
RC Dumb is offline   Reply With Quote
Old 09-10-2004, 02:12 PM   #13968
theRED5's Avatar
R/C Tech Charter Subscriber
Grinder had one on his car...and took it off, he didn't like it.
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
theRED5 is offline   Reply With Quote
Old 09-10-2004, 04:12 PM   #13969
j240z's Avatar
Thanks for the feedback guys. I overheard the "MTX-4" might have a laydown th servo, so I was thinking of doing it to my mtx3 since I probably won't run out and get the new mtx as soon as it's out.
I was mainly going for the "cool" factor.
Old 09-10-2004, 04:28 PM   #13970
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
In addition to the laydown th servo, that's the same thing that I overheard the "MTX-4" migght have a laydown engine, as well.
eddiethefish is offline   Reply With Quote
Old 09-10-2004, 06:18 PM   #13971
mistercrash's Avatar
Is this modification necessary? Is the engine tilted enough to affect the CG? At first glance, it seems to me that the engine is not tilted enough to affect anything.
No brain, no headaches.
mistercrash is offline   Reply With Quote
Old 09-12-2004, 05:14 AM   #13972
bleach1's Avatar
A few questions about the kawahara clutch kit for the mtx3.
I am fitting the clutch kit to a brand new novarossi ns12s3 engine. I have had to put over a 1mm of shims behind the collet to raise the flywheel close to the nut for the flywheel but it still seems to far away because i cant tighten that nut without turning the crankshaft. How far if at all does the collet need to be shimmed out from te crankcase? Im also having difficulty with the bearing for the clutch bell. They are extremly tight over the snout of the shaft, has anyone had to sand down shafts a little to make the bearings easy to fit and remove???
Thanks.
bleach1 is offline   Reply With Quote
Old 09-12-2004, 06:34 AM   #13973
VenomWorldOrder's Avatar
Thanks.
don't be afraid to sand the crank chris, just clean it of before trying to put the bearing in. use wet and dry fine grit paper. bring it down to EC this saturday and i'll help you set it up.
VenomWorldOrder is offline   Reply With Quote
Old 09-12-2004, 10:27 AM   #13974
It sounds like you might get the defective set of Kawahara SS Clutch. Mine does not give any problem. Besides, if you do not sand the crank shaft right, you might end up having the bearing wabble.
Thanks.
Old 09-12-2004, 10:05 PM   #13975
mckrooz's Avatar
Send a message via AIM to mckrooz
This 'mod' is rediculous. Did anyone ever stop to think for a moment how you are supposed to adjust the low end needle?
Kyosho RRR Evo2
mckrooz is offline   Reply With Quote
Old 09-13-2004, 06:19 AM   #13976
Taylor-Racing's Avatar
Well the engine is the heaviest and highest thing in the whole car, so any lowering of it would be a decent gain, I'd think.
But, yes, how to adjust the low end needle.
Taylor-Racing is offline   Reply With Quote
Old 09-13-2004, 06:23 AM   #13977
sparksy's Avatar
Trader Rating: 14 (94%+)
from a hole in the bottom of the chassis?
sparksy is offline   Reply With Quote
Old 09-13-2004, 06:37 AM   #13978
alucard13's Avatar
Default Re: Sway Bar tweak
Originally posted by Ed Delgado
By the way, I am using the 3 Racing aluminum sway bar holders that have the cam adjustment on both sides. It makes it alot easier to adjust. And the fact that aluminum doesn't "squish" means that the settings don't change as much when you tighten down on the cam screws.
Whew! That whas alot of typing!
Ed, thanx for the tip. I bought the last one at the shop on sat. Its only $20 and WELL worth the price. I was able to do it in about 10 minutes, where before it was taking me 30 minutes to 40 minutes. If anyone is listening, GET IT! Well worth it.
Ed, we ran at Coral Springs yesterday. Nice track. Very smooth and a lot of grip.
alucard13 is offline   Reply With Quote
Old 09-13-2004, 06:37 AM   #13979
Through a neatly drilled hole in the servo.
Old 09-13-2004, 06:39 AM   #13980
sparksy's Avatar
the servo is not in the standard position. Unless it is a very big servo, there is room.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
