Mugen MTX-3
i mostly run 0 offset wheels. i think the car handles better with them. i can throw on my powers 42-40 0 offset trued to 62mm run it and then throw on the fast tyres 42-40 trued the same 2 degree offset and car handles way different. i like the 0 degree offset better. the narrower the car, the more traction you should have(in theory).
When buying used neg diff, check the following:
1. The condition of the Delrin Pulley, make sure all the teeth are there and in good condition. Yes, delrin wears.
2. The condition of each outdrive. The only problem on MTX-3 neg diff is that the outdrives wear out so fast. Well, anything wears. It's just that the neg diff outdrives wear faster than Mugen Stock rear diff outdrives.
3. The condition of the bevel gears, the neg diff bearing, the o-rings.
4. The condition of the finger-type clutch. After all what a neg diff would be used for without its Solid Axle Action.
best,
best,
Originally posted by picco007
Eddie,
Would you happen to know what a negative diff would go for used? I found one but not sure what condition it is in. Let me know what you think......I think it is 6 to 8 months old.....Is the negative diff worth it?
Eddie,
I don't remember the part number, but it's the Mugen MTX-2 wheel spacer.
Kawahara MTX-3 Al Hex Wheel Adapter already includes spacers, so one can decide if he/she should need to use it or not.
best,
best,
Originally posted by j240z
Also, where can I get some wheel spacers? It seems it would be easier to be able to use any offset wheel.
BTW I have the Kawahara wheel hexes, if that makes a difference...?
This is terrific! Something I never thought about, but it's sure good to know. Thanks for sharing!
best,
best,
rear end traction
i need more rearend traction my car wants to spin out in the turns. i am running the c rear end block i think its the one for low traction tracks. everything else is stock. what do i need to adjust?
What is your set-up right now?
im a rookie at 1/10 and it is just a few turns in in the rear. give me a set up to start at and then some adjustments to make after that.
Re: rear end traction
best to try with lower shore on your rear tires then work on it from there.
metal handle
hi guy,
where on the internet that i can order a metal handle and brace for the MTX3. The stock plastic handle is too fragile. Thinking on the line to the 1/8th on road style handle.
thanks
thanks
It seems I may have too much tractrion today, I am running 37 shores, with no offset and the car wanted to roll in alot of turns, If I tried taking any "u' type turns ...even wide and slow..the car seemed to roll over. What can I adjust to fix this? I assume this means the track had alot of traction today.
Re: metal handle
Originally posted by xtreme888
hi guy,
thanks
hi guy,
thanks
http://acehardwarehobbies.com/2.2/ca...oducts_id=4482
But with those part numbers maybe at the Kawara dealer in your country.
AFM
Re: metal handle
something like this?
hi guy,
thanks
hi guy,
thanks
thanks for the info on the rear end i will try those suggestions.
Be aware :!: if you're running a sedan body, I bought one of those handles, don't know whether it was Kawa or 3 racing, or what brand it was but it wouldn't fit under a sedan body...too tall.
