Old 08-18-2004, 11:01 AM   #13801
Send a message via ICQ to Mugen Power
Originally posted by Mugen Power
oh...i just get a GP 800mah to make Reciever Batt by DIY!
So Easy....Cheaper than the Sanyo one by ......50%offˇI
The recevier batt finally built up...first charge already have 780mah...
still need cycle~
i may try to cycle one times....see see how much MAH can it have!
Mugen Power is offline   Reply With Quote
Old 08-19-2004, 01:57 AM   #13802
Ybakoff's Avatar
need urgent helps.
I am halfway thru building a kawahara neg diff.
Does anyone know where the red o ring goes. Cause I can't work it out ?
Ybakoff is offline   Reply With Quote
Old 08-19-2004, 02:02 AM   #13803
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
sorry Y, dont know. been a couple months since i built mine. try matching it up on the instructions.
GrandeGixxer is offline   Reply With Quote
Old 08-19-2004, 02:05 AM   #13804
Ybakoff's Avatar
I did that but can't see where it goes. Cause you use the ones that come out of the normal diff
An i have this one red o ring left over
Old 08-19-2004, 02:57 AM   #13805
Send a message via ICQ to Cartman
sure it goes between the diff housing and showe housing
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 08-19-2004, 03:22 AM   #13806
Ybakoff's Avatar
This may sound stupid but what is a showe housing ?
Old 08-19-2004, 03:25 AM   #13807
chippy's Avatar
shoe housing
chippy is offline   Reply With Quote
Old 08-19-2004, 05:04 AM   #13808
Ybakoff's Avatar
Originally posted by chippy
shoe housing
I just checked the instructions again. But it's not shown there.
Maybe I have disabled instructions
Old 08-19-2004, 07:20 AM   #13809
Taylor-Racing's Avatar
Hmmm . . . we use a Neg. Diff on a Kyosho Evo and I guess it must be similar. The main thing to worry about is insuring you keep the diff oil away from the clutch shoes, yeah?
Does this look right?
Taylor-Racing is offline   Reply With Quote
Old 08-19-2004, 02:46 PM   #13810
j240z's Avatar
Default MTX-3 tire sizes...?
It's been a while since I've had to buy new tires. Just want to make sure I'm getting the right sizes...:
It's 0 offset FRONT
2 deg offset REAR
right?
j240z is offline   Reply With Quote
Old 08-19-2004, 02:48 PM   #13811
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Default Re: MTX-3 tire sizes...?
Per manual, it should be ALL offset.
I've been running mine with wheel spacer, so I can use anything I can get.
best,
It's 0 offset FRONT
2 deg offset REAR
right?
eddiethefish is offline   Reply With Quote
Old 08-19-2004, 10:01 PM   #13812
picco007's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Eddie,
Would you happen to know what a negative diff would go for used? I found one but not sure what condition it is in. Let me know what you think......I think it is 6 to 8 months old.....Is the negative diff worth it?
EA Motorsports
picco007 is offline   Reply With Quote
Old 08-19-2004, 10:10 PM   #13813
j240z's Avatar
Default Re: Re: MTX-3 tire sizes...?
best,
So front and rear should both be 2deg offset? I don't have the manual anymore...
Old 08-19-2004, 10:23 PM   #13814
j240z's Avatar
Also, where can I get some wheel spacers? It seems it would be easier to be able to use any offset wheel.
BTW I have the Kawahara wheel hexes, if that makes a difference...?
Old 08-20-2004, 12:51 AM   #13815
FREAKAH's Avatar
Depends.
If you are running 24mm or 26mm wheels(for rubber) then you dont need spacers. If you run regular offset 30mm wheels then you will need spacers.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
