Old 07-30-2004, 11:17 AM   #13531
Ed Delgado's Avatar
Default one more pic
one more pic
Ed Delgado is offline   Reply With Quote
Old 07-30-2004, 11:27 AM   #13532
Bandeira's Avatar
Send a message via ICQ to Bandeira
Default Re: Gandini Racing Products
Originally posted by Ed Delgado
It's funny that you say that, because both Fast and Ellegi brands are produced by GRP (Gandini Racing Products). It's the same rubber, it's only the wheels that are different.
I myself prefer the Mugen design wheels (as used on the Fast brand) over the dish-type or multi-spoke wheels used by GRP on the Ellegi brand. It's a stronger and lighter wheel. You can find good deals on GRP tires in Asia at www.rcmart.com and www.rcmushroom.com.
I know they're all from GRP... It feels strange but that what applied to me... Ellegi gave me lost of traction rolling... Fast tyres dish-wheels gave me lots of flex, Fast spoked wheels are very nice... The power wheels seem to be very nice also... I doubt the rubber is the same.... must be some difference in compound.
What I wanted to knoe is if anybody knows a place where I can get the Kawahara Zac tires apart from the MugenUsa website and the 'the Border' one...
Bandeira is offline   Reply With Quote
Old 07-30-2004, 11:44 AM   #13533
Default Startup Questions...
I just bought a pro spec and have a couple of starup questions.
1) What starter box/battery combo is best for racing
2) I bought the mugen hoping to not have to tweak it all the time, what would be some neccessary setup tools? Is the hudy board a simple tuning tool? What would I need?
What extra parts should I buy for spares? I assume since i bought the pro spec kit I will not need any hop ups.
e420x is offline   Reply With Quote
Old 07-30-2004, 02:42 PM   #13534
Default Re: Startup Questions...
1> Mugen BTII is a nice box. you will need (2) 6cell stick packs.
2> Prospec, you need no upgrades. All necessities are there. Anything more would be eye candy.
vadn1 is offline   Reply With Quote
Old 07-30-2004, 04:33 PM   #13535
dpdiehl's Avatar
Ed...that's sharp looking. It would be neat to see a heat of "scale" looking cars like yours racing.
dpdiehl is offline   Reply With Quote
Old 07-30-2004, 06:41 PM   #13536
alucard13's Avatar
Default Re: Re: Wire detail....
On my othe car, I did the same thing from the outside (shortening the servo wires). You can buy the any style servo connector unassembled (JR/Sanwa/Fut/KO Propo, etc.) and just trim the wire to length, add the pins to the ends of the wire and then insert the pins into the plug body. I did it this way because I thought it was easier than opening the servo case and having to unsolder/solder on the circuitry board-YIKES!
Ed, if i already have the servos is there a kit to be able to shorten the wires? or do i need to buy new servos?
alucard13 is offline   Reply With Quote
Old 07-30-2004, 07:30 PM   #13537
are there any parts that are interchangable between mtx2 and 3? diff? one way? shocks?
Alex
brooklynrc is offline   Reply With Quote
Old 07-30-2004, 11:26 PM   #13538
Ed Delgado's Avatar
Default GT Bodies
Yeah that would be cool wouldn't it? I've been e-mailing body companies about making more GT racing car bodies ( Like the Ferrari 550 and 575 Maranellos) and haven't gotten any positive responses. The only company that has expressed and interest in GT bodies was PTI Racing. Maybe if more people let them know what they want, then maybe they'll do it.
File Type: jpg 575 maranello-black and 550 maranello-red.jpg (42.0 KB, 117 views)
Old 07-30-2004, 11:29 PM   #13539
Ed Delgado's Avatar
Default Re: Re: Re: Wire detail....
Yes Mike, we have the servo connectors in stock at the store. For about $5 you can do three or four servos.
Old 07-30-2004, 11:30 PM   #13540
Ed Delgado's Avatar
Default MTX2
Maybe the shocks, but not much else, I don't think.
Old 07-30-2004, 11:42 PM   #13541
Ed Delgado's Avatar
1) Mugen's box is one of the best. You'll need two 7.2V battery packs for it.
2) For proper chassis set-up you'll need a HUDY Set-Up Board, Hudy Droop blocks and a camber gauge. Check out this link to see how to properly set up your chassis settings:
http://www.mytsn.com/publ/publ.asp?sn=7&pid=7002
The numbers for the settings might be a little different, but the proccess is the correct way to set-up a car. By the way, contrary to the article, you should disconnect the shocks before checking the droop settings.
You should also buy Mugen's clutch nut tool, to make setting your clutch's spring tension alot easier.
I would start with a set of steering blocks and an extra front and side belt as well as a second set of spur gears. As far other plastic parts like susp. arms and bulkheads, the more you have the better.
Old 07-30-2004, 11:46 PM   #13542
Which 4mm chassis is the lightest?
I want to make my MTX-3 the lightest MTX-3. I am gonna start with Chassis but if you have more suggestion, please let me know....
dragoneuh is offline   Reply With Quote
Old 07-31-2004, 01:03 AM   #13543
FREAKAH's Avatar
Shocks, one-way, diff gears, diff outdrives, dogbones, belt tensioner, rod ends/balls, pillow balls and retainers, rear belt, bearings, brake pads, brake disc, brake hub, brake cam, bumper, upper and lower bumper plates, body posts, hinge pins.
That's all I can think of now.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 07-31-2004, 02:57 AM   #13544
Send a message via ICQ to Cartman
one way is a deff no as the one way bearings will be the wrong way round, brake disk was only one piece!
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 07-31-2004, 03:55 AM   #13545
BrainTeased's Avatar
the optional 4 mm mugen chassis is the lightest i think
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
