Old 07-27-2004, 09:09 AM   #13456
afm
afm's Avatar
Originally posted by Profoxcg
thanks AFM,
where in Lima is the track btw, post some pictures
The track is located in the parking lot of Lima's horse track.
I don't know how to post pictures, but if you go to our club's web page www.perurc.com and click on "fotos" you'll see a lot of them of our recently resealed track.
AFM
afm is offline   Reply With Quote
Old 07-27-2004, 09:16 AM   #13457
Send a message via AIM to Profoxcg
En de monterrico? used to live by there on the other side of La Panamericana Sur.
Profoxcg is offline   Reply With Quote
Old 07-27-2004, 09:32 AM   #13458
afm
afm's Avatar
Yes, the good old Hipodromo de Monterrico. When you come to Lima to visit old friends, bring your gear and lets have some fun.
Did you check our web site??? What do you think??
AFM
Old 07-27-2004, 09:42 AM   #13459
Send a message via Yahoo to TambokGT
whats the difference between the prospec and the old one....setup wise....I wouldn't care less with titanium parts.
I drove someone elses prospec and liked it and was wondering what was the standard setup.
thanks in advance.
TambokGT is offline   Reply With Quote
Old 07-27-2004, 10:28 AM   #13460
afm
afm's Avatar
thanks in advance.
Go to http://www.mugenseiki.com/menueefi.htm
You can get all the setting sheets and charts for all Mugen products
AFM
Old 07-27-2004, 11:02 AM   #13461
AFM
Your website looks good. I have to go run that track !, when i lived in Lima I was too young and could not afford those toys nor did I know it existed.
My dad used to take me to the Track though, we had horses there.
Old 07-27-2004, 11:07 AM   #13462
Default AFM
does the horse track, not function anymore? where is the track
Old 07-27-2004, 11:51 AM   #13463
afm
afm's Avatar
Default Re: AFM
Yes it still functions with two concentrical tracks, one of sand and the other of grass. Our track is located in the middle (center) parking lot of the pelouse.
AFM
Old 07-27-2004, 12:29 PM   #13464
Does the Pelouse still has the ponnies? i used to ride those man looong time ago haha !
cool !
Old 07-27-2004, 01:39 PM   #13465
afm
afm's Avatar
cool !
Still there man....you sure making a trip to the past... ha.
Hope to see you some day back here.
AFM
Old 07-27-2004, 06:25 PM   #13466
Arushmen's Avatar
Thumbs up I Have a question
I read in the ebay web this:
This is brand new never been used side belt for Mugen MTX-3.
This is like the Kawahara Belt that solves the overdrive problem of the MTX-3. With the stock side belt, the rear tires wear out about two times faster than the front. With this belt, the tires front and rear wear almost the same which makes the car handle a lot better. And saves you tires too. In my case I always had to true my front tires to match the rear tires that get so small every run. But with this belt I don't have to do that anymore.
Is it true?; Do stock cars have this problem?
XB9 x 2
http://txvzla.blogspot.com/
Arushmen is offline   Reply With Quote
Old 07-27-2004, 06:36 PM   #13467
j240z's Avatar
Default Re: I Have a question
Yes, this is true. The "fix" is commonly referred to as a 16/19 conversion. This means the 2 side pulleys are changed to a 16 tooth and 19 tooth combo. You will need a conversion belt sucj as the one you have mentioned to complete the conversion. It really helps even out the tire wear.
j240z is offline   Reply With Quote
Old 07-27-2004, 07:31 PM   #13468
rjl
rjl's Avatar
Evens out the tyre wear because you must run the fronts smaller than the rears to start with.
rjl is offline   Reply With Quote
Old 07-27-2004, 08:06 PM   #13469
gonzoY5's Avatar
The biggest benefit of the 16/19 pulley setup isn't the even tire wear in the sense of "saving" tires. The biggest benefit is that the car keeps the same OD ratio during a run. When your rears wear down faster than the front, If you start with even tire diameter you have a 1.00 OD ratio, by the end of a main, say if your rears have worn 3mm more than the front(or more depending on how long the main is), you have a 1.05 OD ratio. You car will be driving different and actually slower than if it had stayed even. The car will push on sweeping turns, and hook when coming out of a turn unless you're careful. For a new driver this can be difficult, and for a more experienced driver this can make the difference of winning and losing a tight race at the end because your car isn't handling as well as it was in the beginning. Remember, at 1.05 your fronts are now trying to pull the car, and "dragging" the slower spinning rears. Some people say the car drives easier with smaller rears. I say it's because the car is actually driving slower. Slower definitely feels easier. If there was a way to keep the tire wear reasonably even with the stock setup this would be ideal because of less internal drag, but the even wear is key
Now from my experience, with the 16/19 setup and the split, the tires wear at nearly the same rate. Now that 3.5mm spilt isn't just some magic number that someone pulled out of the air. With the 16/19 and a 3.5mm split, you get a 1.00 OD ratio, which means the fronts and rears will spin at the same rate. If the tires wear at the same rate, that means you'll keep your 1.00 ratio, which gives a more CONSISTANT driving car. Which for a beginner is an easier driving car, and for an expert, gives him a sweet handling car to beat the guy who's car changed towards the end of the race.
PHEW...just had to give my two cents. Any thoughts?
gonzoY5 is offline   Reply With Quote
Old 07-27-2004, 08:24 PM   #13470
so for the conversion i to buy two pulleys?
I thought it was the front one I had to change to 16 from the stock 24
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
