Old 07-26-2004, 02:31 AM   #13441
Ybakoff's Avatar
Originally posted by revRCshop
in case anyone is interested...we have 30% off all mugen parts starting today...ending...i'm not sure when
thanks.
Site doesn't work, Is it just me. ????
Ybakoff is offline   Reply With Quote
Old 07-26-2004, 02:47 AM   #13442
chippy's Avatar
No I cant get to open
chippy is offline   Reply With Quote
Old 07-26-2004, 03:33 AM   #13443
rcabj's Avatar
Default site...
just delete the word after the .com url and u'l be there...
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 07-26-2004, 03:59 AM   #13444
BrainTeased's Avatar
Default Re: ko propo
Originally posted by rocca30
i had a 2143 just freeze up on me in a quailifier. then a throttle sevo hitec 625 on my other car the same weekend just quit, so it really does matter how much money you send, none are bullet proff.
may i ask what was your KO 2143 used for? steering or throttle?
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 07-26-2004, 03:59 AM   #13445
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I have only used the Hitec 600 series servos on throttle/brake, but none have ever lasted 2 months. Now, I only use high quality analog servos on throttle/brake and normally use digitals on steering. I don't have a lot of digitals, but they all get used on steering.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 07-26-2004, 04:17 AM   #13446
Ybakoff's Avatar
Default Re: site...
Thanks Mate.
here's the link
http://www.revrcshop.com
Old 07-26-2004, 01:31 PM   #13447
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Default Re: Re: ko propo
It's actually good for both purposes. But, it's best fit at the Steering for its fast speed.
best,
eddiethefish is offline   Reply With Quote
Old 07-26-2004, 07:25 PM   #13448
what is the stock droop on mtx3?
and also pro spec?
Alex
brooklynrc is offline   Reply With Quote
Old 07-26-2004, 07:55 PM   #13449
Send a message via AIM to Johnnytc3
2mm in front and 6mm in the rear
Johnnytc3 is offline   Reply With Quote
Old 07-26-2004, 08:43 PM   #13450
afm
afm's Avatar
and also pro spec?
Go to http://www.mugenseiki.com/menueefi.htm
You can get all the setting sheets and charts for all Mugen products
AFM
afm is offline   Reply With Quote
Old 07-26-2004, 09:43 PM   #13451
thanks a lot.
Alex
Old 07-27-2004, 07:43 AM   #13452
Send a message via AIM to Profoxcg
Default Changing belts
will 16/19 converstion changed the handling of the car, or will it just solve the tire wear issue?
Profoxcg is offline   Reply With Quote
Old 07-27-2004, 07:44 AM   #13453
Thumbs up Shims in the rear upright
can someone please tell me what exactly does adding or taking away shims from the rear upright does? when you will add and or subtract?
Old 07-27-2004, 08:52 AM   #13454
afm
afm's Avatar
Default Re: Shims in the rear upright
The most normal position of the rear link arm is in the outer hole of the rear shock support assy. and with 2.00mm shims in the upright.
With more shims, more negative camber will the wheels have as the suspension compresses and viceversa.
The longer the link arm(inner hole) less camber variation we'll have as suspension compresses and viceversa.
Not putting shims, and/or putting the link arm in the inner hole produces very little camber variation when the car goes through a turn with the suspension compressed. You use this setting when you have poor traction, or wet track, or in little parking lot tracks, in which turns are done at low speed and you wan't the tires to have maximum contact. This is also true for rubber tires.
AFM
Old 07-27-2004, 08:55 AM   #13455
thanks AFM,
where in Lima is the track btw, post some pictures
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
