Old 07-23-2004, 05:51 PM   #13411
theRED5's Avatar
R/C Tech Charter Subscriber
Oh, and I'm Chuck Carter.
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
theRED5 is offline   Reply With Quote
Old 07-23-2004, 09:47 PM   #13412
Taylor-Racing's Avatar
Originally posted by cdelong
I just bought all of this from Ashford's and the cross shafts were in a bag of their own. I'll try to get the part numbers when I get home, but each thing listed below came in it's own bag.
1). cross shafts
2). gears
3). drive cups
4). shim kit
5). o-ring kit
the drive pins that hold the gears on the cross shafts were not in any of these bags- I had them in my pit box. You'll also need the 2.6mm screws from the original kit to hold the case together.
Hmmm, the pic of C0228 in the instructions seems to include THESE PARTS.
While surfing I also found these HEAVY DUTY GEARS. . . . . are the standard gears a bit "weak"?
Yes, your items 3, 4 and 5 aren't included in C0228, and thanks, I'll need to get some 2.6mm screws.
Taylor-Racing is offline   Reply With Quote
Old 07-23-2004, 09:49 PM   #13413
Originally posted by afm
Taylor-Racing
I recently bought a Prospec, and since we race rubber tires I had to build the front diff. so the parts listing you posted plus the TO210 o-ring set is what you need, and you'll have some extra rings of different sizes left for spares. I 've done it and built it perfectly.
AFM
Thanks AFM. That's kind of what I figured.
Old 07-23-2004, 10:27 PM   #13414
gentleman81's Avatar
Default Ackerman
what is the easiest way to change the steering ackerman?
i put the A in thinking it was the most steering but it is the least, and my newly painted body shows the signs of this!!!
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 07-23-2004, 11:34 PM   #13415
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
Default CartMan
That is not lowering your roll center, it is raising it just so you know. Which usually works quite a bit better with rubber tires.
GrandeGixxer is offline   Reply With Quote
Old 07-23-2004, 11:53 PM   #13416
Guys,
Who makes some + 1mm ally wheel hex's?
Thanks for any help.
Old 07-24-2004, 12:04 AM   #13417
rjl
rjl's Avatar
Originally posted by Taylor-Racing
Guys,
Kawahara give a 1mm shim with theirs.
rjl is offline   Reply With Quote
Old 07-24-2004, 12:37 AM   #13418
Hmmm . . I made up some 1mm shims but was a bit worried about sufficient hex engagement of the wheel. Maybe it isn't a problem
I might be able to mod some V-One items.
Old 07-24-2004, 01:25 AM   #13419
afm
afm's Avatar
Default Re: Ackerman
Not correct. Servo saver kit comes with 3 pieces named "a", "b", and"c".
"a" is the longest "b" is 1mm shorter amd "c" 2mm shorter than "a".
"a" is the one that gives you the most ackerman (more steering), and "c" the least ackerman (less steering), but the 3 give you ackerman.
The difference in ackerman between the 3 pieces is very little, and only expert hands will notice the difference.
According to official Japanese drivers from Mugen, the usual setting is with the "a" piece and in some ocassions the "b" piece, specially when you have a lot of grip and you wan't less steering.
How do you change ackerman? simply by changing one piece for the other.
AFM
afm is offline   Reply With Quote
Old 07-24-2004, 01:30 AM   #13420
BrainTeased's Avatar
i think he wants to know the easiest way for changing that servo saver thingy. Example, what to take off or disconnect and what not to.
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 07-24-2004, 01:46 AM   #13421
afm
afm's Avatar
OOOPS!! well... the only way is taking the radio plate out and dissasembling the servo saver...there is no other way.
But still, if he want's more steering, "a" piece gives you the most, and he allready has it on.
Maybe there are other issues to look at his settings to know why he isn't getting enough.....
AFM
Old 07-24-2004, 08:19 AM   #13422
Default ackerman
the article in xtreme rc from robbie collins says the A ackerman gives u less steering in the corner on tracks with very good grip, im running on a parkinglot track that tends to be a little slick in my opinion, and i had to fight my car threw the turns with the A ackerman?
I just put the C ackerman in and ill see what it does.
Old 07-24-2004, 11:03 AM   #13423
Bivens's Avatar
Please post result of your test......many are curious....everyone just seems to run A without ever trying C....only trusting what they hear or read without trying it.
Bivens is offline   Reply With Quote
Old 07-24-2004, 11:29 AM   #13424
Send a message via AIM to Johnnytc3
True...
Johnnytc3 is offline   Reply With Quote
Old 07-24-2004, 04:11 PM   #13425
Does anybody know the part number for the centax shims, it doesnt say in the manual, or any other similar sized shims that would work?
thanks
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
