Old 07-10-2004, 10:27 PM   #13261
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default Re: Turnbuckles
Originally posted by ProRacer03
I just completed my MTX-3 Prospec and was wondering what tool you guys use to adjust the turnbuckles.
It's a little bigger than the usual lunsford wrench i normally use. I tried some needle nose but i can't get a good grip on them.
thanks in advance
Go to the hardware store and pick up a set of picks. One has a 90deg bend one is a hook and 1 is a 45deg angle, they cost about $5.00 and you can use them as a castor clip tool also!
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 07-10-2004, 11:45 PM   #13262
thanks in advance
I use a Craftsman 4mm open wrench.
FlipperCVT is offline   Reply With Quote
Old 07-11-2004, 04:18 AM   #13263
VenomWorldOrder's Avatar
Default Re: Re: Turnbuckles
the prospec is different to the original mugen mtx3 it has the titanium turnbuckles which have no holes in the turnbuckles.
you could try drilling a small hole in the turnbuckle or making a wrench yourself with a 90 degree angle on the wrench
TO THE GUY WHO HAS THE CAR THAT SPINS OUT;
you are running too much droop on the rear. ie the car lifts too much under heavy braking, reduce the droop, thereby reducing the weight shift to the front and your problem will be solved. if you are running the car with the right tyres, the tweek taken out etc the droop will be the crucks of your issues.
VenomWorldOrder is offline   Reply With Quote
Old 07-11-2004, 06:25 AM   #13264
chambalero's Avatar
thanks in advance
if u want somethin nice get a tamiya turnbuckle wrench. fits perfectly
Hi guys! just finished building my first mugen car, my prospec mtx3, and i must say the quality is very good and it looks very durable
chambalero is offline   Reply With Quote
Old 07-11-2004, 09:21 AM   #13265
Bivens's Avatar
Default Spin on the brakes....
Also, the front shock damping rate plays in here......you can thicken-up the front oil to keep RAPID weight transfer from occurring under braking......but you'll still have similar weight transfer when not braking hard.....keeps it turning in good on the off-power corners while not spinning under hard braking.....
If you simply remove droop, you can remove turn-in in non-braking corners also....where you may not have a problem now.
Bivens is offline   Reply With Quote
Old 07-11-2004, 06:03 PM   #13266
Send a message via AIM to ProRacer03
Default Clutch tuning for Prospec
I just began the break in stage on my MTX-3 Prospec. I have a problem I think you guys might be able to help with.
When i start the car, the wheels begin to spin, as soon as the wheels stop, the car dies.
So I put the car on the starter box, engine fires up, put the car on the ground it dies. I think the clutch spring might be set too tight but I have it on stock settings with only 2mm spacing on the clutch spring.
My question is, should i tighten the clutch spring down? Do I need to open up the pinion gears in order to do it or can i tighten down the pilot shaft screw?
Thanks in advance, this forum has been a very valuable resource of information.
ProRacer03 is offline   Reply With Quote
Old 07-11-2004, 06:18 PM   #13267
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Default Re: Clutch tuning for Prospec
Seems like your clutch bell is engaging with the clutch shoe, you need some space between them so it doesnt engage when idling!
Ah10 is offline   Reply With Quote
Old 07-11-2004, 06:51 PM   #13268
Default Re: Re: Clutch tuning for Prospec
How is this done? Should I put in some spacers? Would this require shaving anything down?
Do you have a picture?
What you describe sounds like the reason my car dies out. Just need to find a remedy
Old 07-11-2004, 07:06 PM   #13269
mckrooz's Avatar
Send a message via AIM to mckrooz
You need to add more shims behind the clutchbell.
Kyosho RRR Evo2
mckrooz is offline   Reply With Quote
Old 07-11-2004, 08:15 PM   #13270
Default Engine Mounting...
Getting to the final steps of assembly on the MTX-3. When mounting the engine with a slide carb, I don't have enough clearance on the top tray for the carb to fully open unless I twist the carb about 15%. Is this normal? Should I instead grind the tray to get the clearance?
Thanks!
elmar66 is offline   Reply With Quote
Old 07-11-2004, 08:59 PM   #13271
racecar850's Avatar
Send a message via MSN to racecar850 Send a message via Yahoo to racecar850 Send a message via Skype™ to racecar850
Exclamation ENGINE MOUNTING
Very normal
Mugen MTX-4 :tire:
T-MAXX 3.3 :deathstar
MacBook...got fed up with pc :confused:
DRIVING...An inconvenient way of getting from A to B
racecar850 is offline   Reply With Quote
Old 07-11-2004, 09:43 PM   #13272
Ah10's Avatar
Default Re: Re: Re: Clutch tuning for Prospec
I think the easiest way is to remove some shims on the thrust bearing side, to give it some more room for the clutch bell to clear the clutch shoe!
Old 07-11-2004, 09:54 PM   #13273
gonzoY5's Avatar
Just put some shims BEFORE the bearing on the INSIDE of the clutchbell. I had that problema little with the clutch dragging, I wouldn't shut the engine down, but you would tell it was dragging. Good luck
gonzoY5 is offline   Reply With Quote
Old 07-11-2004, 09:58 PM   #13274
Thanks for all your help! I added some shims and that seemed to fix the problem.
It's a good things that the car fired right up. Does anyone run the 5.4 carb restricter on their NS12? I left it in to be on the safe side.
I added the 19/16 conversion and 3Racing aluminum pulleys all around.
Here are some pics of what you guys helped me out with.
Old 07-11-2004, 10:49 PM   #13275
Data's Avatar
you need to come out to the track more instead of here came across a new pipe from a company called "skyline". seems pretty good, let you try it next week, if you ever came to the track.
Data is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
