Old 07-07-2004, 04:10 AM   #13216
Taylor-Racing's Avatar
Wow DC, that's a fantastic invention.
Australians are so good at inventing things - first the "stump jump plow" and now this.
What did the Americans ever invent?
Errrmmm . . . the light bulb, the telegraph . . oh . . and WMD.
Taylor-Racing is offline   Reply With Quote
Old 07-07-2004, 08:30 AM   #13217
Bivens's Avatar
Mugen shocks are great.....my opinion anyway....earlier this year, I built a total of 12 shocks "one-time" each without having to disassemble and re-fill.......couldn't believe it....
With the shock shaft pulled down completely, fill the shock to the top.....work the shock to remove air and let it sit as long as possible or use the vacuum pump on it to remove all possible air.....push the shaft up about 3/4 travel (near the top) and start to slowly screw on the cap. Excess oil should bleed out the overflow hole in the cap and the shaft should re-bound to an extended position SLOWLY.....
The exact amount of built-in rebound that you leave behind isn't that critical......as long as it's the same on both sides and the car is tuned to it......Forceful rebound is similar to a slightly stiffer spring.....weak rebound will be like a slightly softer spring....
I usually try to get the shock shaft to fully rebound slowly.....if it doesn't rebound completely, start over....if it comes out too hard or you cannot push it in completely, then you have too much oil...you can break the seal and bleed off a little oil....
The vacuum pump I spoke of earlier is made by Ride.....check this out.....it's the best thing for shock building since silicone oils.....I highly recommend.....and if you have one and it doesn't pull a strong vacuum.....simply oil the plunger well with shock oil...it should come back to life....
http://www.rc-ride.co.jp/eng/docs/rp600.html
You can buy it here......or you're LHS can get one....
http://rc-mushroom.com/product_info....oducts_id=2236
Bivens is offline   Reply With Quote
Old 07-07-2004, 08:56 AM   #13218
alucard13's Avatar
Originally posted by veecee
mine were very tight. don't know if I'll ever get them out...
Really? On my rear uprights the bigger of the two bearings kept falling out.
alucard13 is offline   Reply With Quote
Old 07-07-2004, 11:05 AM   #13219
raffaelli's Avatar
Bivens, Does the volume of 3/4 of the shaft roughly equal that of the displacement of the bladder? (meaning, no room for air)
raffaelli is offline   Reply With Quote
Old 07-07-2004, 04:09 PM   #13220
Bandeira's Avatar
Send a message via ICQ to Bandeira
Hello guys,
Have you guys ever driven in VHT treated tracks?
They used to pul sugarwater but they will try VHT for the Nats... What should I expect?
Thanks in advance...
cheers...
Bandeira is offline   Reply With Quote
Old 07-07-2004, 04:30 PM   #13221
Bivens's Avatar
Default raffaelli
When you complete the process...if you find out that the shaft won't fully compress...then you've simply screwed the cap on fully while the shaft was extended too far.....
If you end up leaving"no room for air" then the rebound will be excessively strong also and you won't have full travel available.....not good....simply break the seal and push the shaft in.....bleeding off some oil....then tighten and re-check. If necessary, clean it out and try again.
Typically I get good results with screwing on the cap while the shaft is about 3/4 out......then screw the cap on slowly....
Old 07-07-2004, 05:03 PM   #13222
rjl
rjl's Avatar
Originally posted by Bandeira
Hello guys,
cheers...
Expect traction rolling.
rjl is offline   Reply With Quote
Old 07-07-2004, 05:14 PM   #13223
raffaelli's Avatar
Bivens, thanks for the info! I will start bleeding tonight!
Old 07-07-2004, 05:44 PM   #13224
Bandeira's Avatar
Aff...
I'm having the worst traction rolling problems with Sugarwater...
I can't imagine what is going to be with the vht...
Maybe I'll have to set the car lower and lower and limit the bottoming on the upstops...
cheers...
Old 07-07-2004, 06:59 PM   #13225
gentleman81's Avatar
Default mtx3 tires
what shore tire does the mtx3 regular comes with?
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 07-07-2004, 07:23 PM   #13226
mckrooz's Avatar
Send a message via AIM to mckrooz
Default Re: mtx3 tires
37 shore
Kyosho RRR Evo2
mckrooz is offline   Reply With Quote
Old 07-07-2004, 08:11 PM   #13227
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Aff...
cheers...
I would try a stiffer oil; try 800 wt. stiffer springs, I used 1/8th. pink rears on the front of my mtx3 at the biggie with softer rears like stock. Try more camber, 4deg. in the rear, 3deg. in the front, you can also try slowing your servo speed down so the car wont be so twitchy with your radio input.Also try a stiffer sway bar.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 07-07-2004, 10:49 PM   #13228
Default diff parts
where can i get the front inside parts for my diff in my mtx3 the kit comes with the housing, are the front and rear diffs the same inside? and what oil should be used for a parking lot track with some tight turns and a low bite surface?
and do i need anything else to run a diff up front in this car?
Old 07-08-2004, 02:45 AM   #13229
rjl
rjl's Avatar
Aff...
cheers...
I broke a front shock shaft after traction rolling in a state final once, the traction rolling problem went away immediately. Lap times went down but.
Old 07-08-2004, 02:59 AM   #13230
finchy's Avatar
rjl are you going to be competing in the QLD state titles, we don't use VHT up here. But since we had the track cleaned early this year the grip is excellent. I've never in the 3 years of racing seen the track so good. Natural grip is always better than man made grip.
Inf1nity IF1
OS Speed
KO PRO PO
Runnertime
Hudy
finchy is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
