Old 07-06-2004, 01:34 PM   #13201
Send a message via AIM to ProRacer03
Hi, I was looking for a little info on the MTX-3 Prospec. I'm in the middle of building one and I have a minor problem.
I'm having a little problem with the 2-speed assembly. When I thread down the pinion gears and assemble them. When I turn the motor over it unthreads the pinion. I'm pretty sure I'm screwing them down the right way.
Thank you in advance.
ProRacer03 is offline   Reply With Quote
Old 07-06-2004, 01:47 PM   #13202
gonzoY5's Avatar
Sounds like you're starting the engine the wrong way. when looking at the front of the engine, the flywheel should turn counterclockwise. Good luck
gonzoY5 is offline   Reply With Quote
Old 07-06-2004, 02:17 PM   #13203
I don't think i'm starting it the wrong way. It's when I turn the spur gear to check the drivetrain, when it sticks because of the new motor, is where it begins to unthread.
One more question, Do the servo horns come with the kit? I can't seem to find them, specifically the steering one.
Old 07-06-2004, 02:34 PM   #13204
Send a message via AIM to Johnnytc3
Dont worry, that normal, try spining your flywheel instead, it will tighten itself, as for the servo horns, they do not come with the kit.
Johnnytc3 is offline   Reply With Quote
Old 07-06-2004, 02:59 PM   #13205
On the clutch bell isnt locktite a requirement to hold the gears down.
vadn1 is offline   Reply With Quote
Old 07-06-2004, 03:17 PM   #13206
rjl
rjl's Avatar
If your two speed is assembled correctly then the pinions will self tighten, there is no need for threadlock and if used will cause problems. If the two speed assembly spins freely backwards then all is good, if there is any binding first gear will unthread itself.
rjl is offline   Reply With Quote
Old 07-06-2004, 08:04 PM   #13207
ilaybrk's Avatar
has anybody had problems with the rear diffs my 10/15 bearings dont fit I had to sand to get bearings to fit two difrent diff cases.
ilaybrk is offline   Reply With Quote
Old 07-06-2004, 08:17 PM   #13208
rjl
rjl's Avatar
I had no trouble getting the bearing on the diff, it will not slide over the outdrive though.
Old 07-06-2004, 08:47 PM   #13209
veecee's Avatar
Trader Rating: 34 (100%+)
mine were very tight. don't know if I'll ever get them out...
veecee is offline   Reply With Quote
Old 07-06-2004, 08:49 PM   #13210
i had to sand to get mine to fit on the left side
Old 07-06-2004, 08:53 PM   #13211
Seisick's Avatar
need higher top end on an oval huge track, can I just purchase a 22 or 23teeth for the 2 gear and It will work fine with the stock 43-47 and 16teeth 1st. gear?
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 07-06-2004, 08:56 PM   #13212
mckrooz's Avatar
Send a message via AIM to mckrooz
Mine too. I thought I was gonna destroy a bearing trying to get it on.
Kyosho RRR Evo2
mckrooz is offline   Reply With Quote
Old 07-06-2004, 09:56 PM   #13213
raffaelli's Avatar
Default Shock Rebound
So, tonight I am in the middle of a shock rebuild. I am always guessing at the shock oil volume and rebound. And I always notice that the bladder is always pushed in.
So,
How much rebound do you have?
How far is the piston extended when you tighten the cap?
Does the bladder end up pushed in?
Thanks!
(after typing this, I realize that these questions will lead to much abuse about my extended shaft and pushed in bladder...please be gentle on me....
raffaelli is offline   Reply With Quote
Old 07-06-2004, 10:18 PM   #13214
OZDC's Avatar
Trader Rating: 16 (100%+)
Use 3 nickels and glue them together. 5.5mm....
and
Originally posted by H STAMEN
mike are you going to royal palm sunday? i think i have one of the plastic parts you need ..thanks for the pit work. i use the droop made by hudy
Actually you guys have pre-empted asomething I have been working on for a while now.
Perhaps you guys should check out my exciting new range of RC products.
Amazingly the first Item we are producing are ride height gauges.
Check out HERE
Site is under construction, more details and more products coming soon.
Dave Calwell
DUDY Performance RC Products
Proudly manufactured and designed in Australia
P.S
Its pronounced Dud- e, not Dude - e
OZDC is offline   Reply With Quote
Old 07-06-2004, 10:29 PM   #13215
raffaelli's Avatar
HAHAHAHAHHA
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
