Mugen MTX-3
Old 06-18-2004, 02:04 PM
  #12931
hello,
do you guys have an idea where i can download the mtx-3 manual? thanks.
JackPot is offline
Old 06-18-2004, 02:46 PM
  #12932
David Joor's Avatar
www.mugenracing.com
David Joor is offline
Old 06-18-2004, 03:38 PM
  #12933
Just got my MTX-3 ready to go. I was wondering what gearing should I start out with on a large track. 270 Ft. straight and large infield located in Hamilton, Ohio. Any help would be appreciated. Thanks
no4hitter is offline
Old 06-18-2004, 06:30 PM
  #12934
rcabj's Avatar
Originally posted by rc_alan
It sound like you have a bone stock MTX3 rcabj... Go with front universeals, MRX3 front outdrives, the MRX3's front belt and change to aluminum hexes all the way around and you should have no more problems.. As for trust spring.. I take it you're talking about the centax clutch... Go with the hard spring if you're running a 5 port Nova... Then again, that one is totally up to you, because changing the clutch shoes as well, ie. black, grey and red can also make a difference... Most racers will use grey or red, while the stock shoes are black I believe... I'm running red which is super hear... Robbie Collins mention in his article that he uses grey clutch shoes and super hard spings.. Remember, you can always adjust it's engagement... Hope the info helps you out...
RC_Alan
thanks for the info
one more thing when using a front one way , what no. diff oil would be good for the rear diff. thanks again.
rcabj is offline
Old 06-18-2004, 06:35 PM
  #12935
mckrooz's Avatar
If your track has good bite, try using 30,000 in the rear. You can get on the throttle sooner. I switch between 10K and 30K depending on the track conditions.
mckrooz is offline
Old 06-18-2004, 09:45 PM
  #12936
Originally posted by David Joor
www.mugenracing.com
tnx david
JackPot is offline
Old 06-18-2004, 11:31 PM
  #12937
GrandeGixxer's Avatar
Trader Rating: 18 (100%+)
I just got an mtx3 after i sold my ntc3. I was wondering what do you guys measure your shocks at? guy at the track is saying 11.3 mm in front and 12.3 in rear. thanks for the help.
GrandeGixxer is offline
Old 06-19-2004, 03:13 AM
  #12938
EVOLUTION's Avatar
Originally posted by Taylor-Racing
Evo is nearly indestructable.
Yeah, so long as you take your time when assembling the battery pack and choose the right plug.
EVOLUTION is offline
Old 06-19-2004, 05:28 AM
  #12939
Taylor-Racing's Avatar
Oh, had a little trouble did we?
Taylor-Racing is offline
Old 06-19-2004, 06:19 PM
  #12940
Seisick's Avatar
Need help setting my mugen for a short track, little grip and foams.
basically Ive just finished breakin my mugen with mt12 and had some runaways with rubber but Id like to try the foams that came with the kit on my first race tomorrow against 7 tc3s, 2 hpi and 1 kyosho. any recommendations. running with 18 benol, 20 klotz nitro (LHS ran out of fuel til next week).
Seisick is offline
Old 06-19-2004, 08:03 PM
  #12941
Default Setup
I have done a little searching, but I have not been able to find anything. I need a good basic setup for the MTX-3 with rubber tires and a one-way. Does anybody have one that they can post?
Thank You
NickName999 is offline
Old 06-19-2004, 08:18 PM
  #12942
nick the stock setup with purple springs and the b block in the servo saver is what i run. might want to try a diff in the front also if there is anything less than absolute traction.
Old 06-19-2004, 08:20 PM
  #12943
Seisick. What is with the fuel filter on the pressure line?
Old 06-19-2004, 08:30 PM
  #12944
tranced's Avatar
run a front mechanical diff if you're using rubber tyres.
the rubbers will not have enough grip for the one-way to act efficiently.
tranced is offline
Old 06-19-2004, 08:37 PM
  #12945
Ya, I thought a front diff would be a better way to go...I just do not have one. Guess I will need to order one. Thanks
