Mugen MTX-3
mtx-3
7 mm nut drive integy hex metri tools will work fine
What size for the rest of the screws? 3mm, 2.5mm, 2mm and 1.5? Will that cover all of them?
mtx-3
yes just buy integy set that will cover it all ,youll be in business.
spare screws
Go to www.RCScrewZ.com and order the box of assorted metric sizes
its about $40.00 for like 450 screws!
http://www.rcscrewz.com/bulk_screws_kits.htm THIS IS THE LINK FOR THE BULK SCREW KITS
Re: Need some info...Switching to MTX-3
Originally posted by elmar66
What drivers do I need for the screws? What size is the nut for the wheels? I want to order my tools and allen drivers from the web before my car arrives.
1.5mm
2.0mm
2.5mm
on regular hex tip, Integy has the best quality, they are just a bit oversized so it fits very very tight on the hex screws.
you might also want to get a ball head 2.5mm, and Hudy one is the best, and hudy hook to remove exhaust springs and those castor clips, it works really good.
and if you are planning to use power tools, then get a set of Ofna power tools adaptor, it comes with 1.5, 2.0, 2.5 and 3.0mm tip.
Ah10, where can I get the Ofna power tools adapter?
Are you saying that it will also not work on the newer 0.8 gearing of the MTX-3? I tried the tool on the Centax 3 and it worked fine.
Send a P.M and i can hook you up.
It is a handy tool.
www.twistertires.com
By the way, I think Mugen makes it too.
Here is Ofna one
I remember I have seen something similar with Mugen headboard, so I assume Mugen makes one.
Re: tools
Originally posted by Bivens
What I am saying is this......A serpent 710 has a "Centax III" clutch......The Mugen tool will NOT hold the clutch bell for the serpent....it is smaller than the clutch bell of the Centax II that we have on our MTX-3's. (The gear-turning handle works with all gears, it's the clutch-bell holding handle that works only with the Centax II clutch bells.)
front susp. set up
i need a starting point to set my front suspesion, its a brand new mtx3 and the front feels very hard and the back feels good and soft, i notice the front sway bar is very close to touching. any answers?
Re: front susp. set up
Re: Re: front susp. set up
Originally posted by Data
i think the ball end is touching or is very close to the bottom of the cup. try to move the two sway bars apart a little.
