Old 06-12-2004, 10:35 PM   #12826
HELLION's Avatar
Default MTX-2
I have other cars that are pretty cool but I got to tell you every time I drive the little MTX-2 It puts a big smile on my face! The car has been destroyed twice both times it was blasting down the straight and hit a stalled car. (Which reminds me when you stall in the straight away shout out so the other drivers know to slow down trust me they won't get mad at you) It's 3 years old now but it can still pop off T.Qs And if it gets totaled again I will repair it. Can't say the same for the other cars.
HELLION is offline   Reply With Quote
Old 06-12-2004, 10:37 PM   #12827
picco007's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Originally posted by chippy
Start from the inside with about 1mm washer I use a washer from oan old thrust race bearing its a good place to start.then shim so the clutch bell does not have much side ways movement but still spins freely.
if to tight will destroy the thrust race bearing.
Thanks..........
picco007 is offline   Reply With Quote
Old 06-12-2004, 10:39 PM   #12828
HELLION's Avatar
Default Pulleys?
Originally posted by Neoracer
Hi guys,
Need a bit of help with the Kawahara solid axel adpter kit.
Basicaly I fit the adapter, the 16 touth pully and new shorter belt. Is this right?
Well basically the mesh is wrong somewhere. When I push the car along the ground the belt slips or clicks as if the one set of wheels is spinning faster than the other.
Am I missing a part of this conversion? Does anybody know what might be wrong?
NeoRacer.
Hey Neo It sounds like you have your pulleys mixed up
Old 06-13-2004, 02:21 AM   #12829
rcabj's Avatar
Default stock gearing
hello...just got a used mtx3..need to know what is the stock gearing for the pinion and spurs..
thank u.
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 06-13-2004, 03:29 AM   #12830
mckrooz's Avatar
Send a message via AIM to mckrooz
stock gearing is 16/47 1st gear, 20/43 2nd gear.
Kyosho RRR Evo2
mckrooz is offline   Reply With Quote
Old 06-13-2004, 07:34 AM   #12831
rcabj's Avatar
Default thanks
thanks mckrooz....anyway the mtx3 is using dog bones all round and there is some amount of gap between the axle and wheel hex. r u using d/bones ... is this normal for mugens.
the wheel hex on this mugens is the aluminum type and a bit wide. what type of wheel hex and size r u using..thanks
one more thing does mugens have the problem of tires rubbing againts the rear hubs when using 30mm rears.
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 06-13-2004, 08:01 AM   #12832
Any one know the angle of a countersink bit needed to produce countersink holes found on the underside of the mtx-3 chassis.
vadn1 is offline   Reply With Quote
Old 06-13-2004, 12:59 PM   #12833
Bivens's Avatar
Default NeoRacer
The solid adapter for the front diff-case (or rear) has no impact on your problem.......
If you have the 16-tooth pulley on the rear shaft and the 19-tooth pulley on the front shaft, along with the NOT-stock conversion belt.....there should be no problems.....Your front tires MUST be smaller than the rears now to keep both ends of the car rolling along at the same speed.....You are likely seeing that the rollout of the front is now higher than the rear if you didn't change the front-tire size to be approx 3.5mm smaller (see posts about 5-pages back)......simply put...now the front tires spin faster and you need smaller tires on the front to get back to an "even" drive between front and rear.......
There shouldn't be a problem with the tension on the belt being too loose....is there?
Bivens is offline   Reply With Quote
Old 06-13-2004, 02:31 PM   #12834
Send a message via ICQ to Cartman
yep same angle as the screws!!
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 06-13-2004, 02:40 PM   #12835
Data's Avatar
82
Data is offline   Reply With Quote
Old 06-13-2004, 02:45 PM   #12836
Originally posted by Data
82
you sure its not 82.15574125574856546468146146169817
Old 06-13-2004, 02:50 PM   #12837
Data's Avatar
sorry, my bad.........
Old 06-13-2004, 07:09 PM   #12838
rcabj's Avatar
Default front one way
a freind gave me a used fr. one way.
i spin the left tires and its almost spin freely without any binding..but when i spin the right wheel it won't spin as freely as the other side..sort of the feeling of a very heavy diff oil spin...
since i have never use a front one way b4 i need to know if this is normal.
if not could it be repair or else...thank u very much.
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 06-13-2004, 08:07 PM   #12839
alucard13's Avatar
Anyone have any links for the front universal joints for the MTX-3? I can't sem to find them online. And the one place i did they were out of stock.
alucard13 is offline   Reply With Quote
Old 06-13-2004, 08:24 PM   #12840
Send a message via AIM to Profoxcg
Angry selling
guys, my engine died today... i aprears it was defective from the day i bought it, but due to my lack of knowledge, i neved knew, and today someone very knowledable tried to help me and the engine is just tired....
I have had very bad luck engines and cars and even people at the track threating me over stupid stuff that i have decided to get out of the hobby.
I am selling my prospec that was run today and electronics with a 3pk.
I am will keep my tools as maybe i will try this in the future,
drop me a line if you are interested.
I wil like 550.00 for the car and servos FUT 9451 and a KO PS-2174FET and 260.00 for the radio 3pk PCM and receiver..
I will throw a serpent box and my ofna X12 pipe, if you want the engine you can have it for $80 it still runs but need the front bearing changed......
thanks,
my e-mail is [email protected]
Profoxcg is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
