Old 06-11-2004, 12:27 PM   #12811
R/C Tech Charter Subscriber
Originally posted by elmar66
Well, my wonderful wife has blessed me with a brand new Mugen MTX-3. It's not the Prospect, but she got a HECK of a deal on it, compliments of E-bay!!!
I am looking at a motor for it, I am not going high end right now, trying to keep my costs down.
I am considering the OS motor, but don't know what the difference is between:
O.S. .12 TR w/10J Slide-Valve Carb
or the
O.S. .12 TR (P) w/10J Slide-Valve Carb
What does the (P) denote?
Also, what are some of the first Hop Ups to consider?
Elmar,
You gotta do the front universals. The upgraded brake is a must and the titanium middle shaft helps.
www.twistertires.com
racinghobbies is offline   Reply With Quote
Old 06-11-2004, 02:12 PM   #12812
Send a message via ICQ to Cartman
Originally posted by racinghobbies
Elmar,
my mate ran dog bone for 6 months with no probs!! just use orings to space en out of the one way
std brake is OK and middle shaft is not a necessity
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 06-11-2004, 04:46 PM   #12813
chookgb's Avatar
Trader Rating: 26 (100%+)
Originally posted by Bandeira
Hello guys...
I was taking a look at the Serpent Website and regarding clutch adjustments they say that the clutch housing should have minimal play, acquired but putting some shims between the bearing and the spring collar..
But I didn't see any Mugen guy playing with this endplay in mugen clutches. Assuming that both clutches are supposingly equal, if not, very similar, what this adjustment would bring?
Have you guys tryed this in our mugen clutches?
cheers...
i run my clutch with around 1mm of shims between the bearing and spring collar and then shim the bell to have just enough movement to spin freely this method allows for consistant clutch engagement as it is in a set position and does not rely on the bell sliding in and out which can be different depending on whether it moves freely every time,give it a try you wont be dissapointed
chookgb is offline   Reply With Quote
Old 06-12-2004, 01:35 AM   #12814
Send a message via AIM to Profoxcg
can you post a picture?
Profoxcg is offline   Reply With Quote
Old 06-12-2004, 01:36 AM   #12815
Default shifting point
What is a good point at wich to sift..
my car seems slow because its sifting way too early..(in the infield..)
Old 06-12-2004, 02:41 AM   #12816
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
Default Re: shifting point
if you want your 2 speed to shift a bit later then just simply tighten both set screws, 1/4 turn a time until it shifts to your liking..
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 06-12-2004, 04:17 AM   #12817
chookgb's Avatar
i will do a pic as soon as i can hopefully tommorrow
Old 06-12-2004, 05:16 AM   #12818
Originally posted by vadn1
If you get a chance grab an issue of Xtreme RC car magazine, this month as a set up by Robbie Collins on the Mugen MTX-3. He recommends going with a B block and tells under what circumstances to change to the A or C. Grab one issue, it helps in other areas of the car also. Great to have in the Tool box when out at the track working on setup...
any chance of some one scanning it and emailing it to me? can not get it in the UK
thanks
Mark
Old 06-12-2004, 06:36 AM   #12819
Bivens's Avatar
Careful......the set-screws set the clearance of the clutch shoes to the 2-speed housing (See the manual for details).......they are different than the "Adjustment" screws.......
The 2-speed adjustment screws are the screws that do-NOT go straight in and hit the center of the shoes......(the screws that go straight-in are the set-screws).........To change the shift point.....adjust the OFF-centered screws that appear to be "angled" into the shoes......notice that the hole in the housing to adjust them is "angled" also....it should be clear.....(when you're on the right screw....and your wrench is locked-on and ready to tighten....the shaft of the wrench should NOT be pointed at the center of the assembly.)
Loosen both adjustment screws equally to make shifting earlier and tighten equally to make it later.
Not that I've had a problem with inconsistent engagement.....but this sounds like a great idea...simply have to change the way I measure the clearance.....can't measure it anymore, can you?
Bivens is offline   Reply With Quote
Old 06-12-2004, 11:01 AM   #12820
mckrooz's Avatar
Send a message via AIM to mckrooz
If you're adding the shims between the collar and bearing, where else are you adding shims to for the bell? Thats where I shim also(between bearing and collar) I thought that was how it was told in the instructions.
Kyosho RRR Evo2
mckrooz is offline   Reply With Quote
Old 06-12-2004, 02:14 PM   #12821
put shims between the clutch bell bearing abd crank nut until the bell does not drag when pushed towards the engine, then ad shims to the thrust race to adjust!
Old 06-12-2004, 04:24 PM   #12822
Angry
Hi guys,
Need a bit of help with the Kawahara solid axel adpter kit.
Basicaly I fit the adapter, the 16 touth pully and new shorter belt. Is this right?
Well basically the mesh is wrong somewhere. When I push the car along the ground the belt slips or clicks as if the one set of wheels is spinning faster than the other.
Am I missing a part of this conversion? Does anybody know what might be wrong?
NeoRacer.
Neoracer is offline   Reply With Quote
Old 06-12-2004, 08:56 PM   #12823
alucard13's Avatar
Post office found my package. I am ready to build the Prospec. If anyone has done the prospec and came across anything while building that i should be aware of, please let me know. Thanx.
alucard13 is offline   Reply With Quote
Old 06-12-2004, 09:55 PM   #12824
picco007's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Which part do you shim first? Do you shim endplay then shim the inside where the spring collar and bearing meet? I have always had problems with my clutches not being consistent. Any help is appreciated.
picco007 is offline   Reply With Quote
Old 06-12-2004, 10:33 PM   #12825
chippy's Avatar
Start from the inside with about 1mm washer I use a washer from oan old thrust race bearing its a good place to start.then shim so the clutch bell does not have much side ways movement but still spins freely.
if to tight will destroy the thrust race bearing.
chippy is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
