Old 06-10-2004, 12:59 AM   #12796
Default Hi Guy's and Gal's..
Wow it's great to see so many new MTX 3 owner's... Welcome!... Sorry, (Marine) and I havent been around in a while but he's been moving around alot and Ive been a faithfull wife... But we did get to spend a couple of day's at the Texas Biggie.. That was a blast! Congrat's on All the drivers who raced.!! We will be heading to Austin to race next weekend so if you guy's want to meet up.. send me a pm... thanx..R.
freefallgirl is offline   Reply With Quote
Old 06-10-2004, 06:01 AM   #12797
Taylor-Racing's Avatar
Default Re: BACKWARDS
Originally posted by Slotmachine
I do believe that you have that backwards A in the front and B in the rear is called pro squat! The other way around is anti squat.
Anti squat in the rear will cause the car to square off the corner late in the apex or shortly after.
Yes, thanks, I had it round the wrong way.
I guess it's all a matter of terminology depending on your neck of the woods.
For instance, I would refer to a rasied front pin position as "positive" anti-squat, and this should limit weight transfer to the rear, yeah.
So, what I meant to type was:
Has anyone tried, a rear "A" block with a front "B" block to generate some positive anti-squat?
Taylor-Racing is offline   Reply With Quote
Old 06-10-2004, 06:02 AM   #12798
Originally posted by AMGRacer
Well I can happily report that I have no idea what you are talking about
But HPI does also agree with your theory.............
http://www.hpiracing.com/graphics/in.../Pro4_pg33.jpg
They also say move lower pin down on high traction surfaces.
Serpent and XRAY however disagree with this advice and say to go the completely opposite way. I am starting to wonder whether there are some car specific effects which override the general rule.
Moving the lower pivot point does change how the suspension reacts a little but, this is not the full reason for changing the rollcenter in the rear.
Did you notice that HPI recommends that you raise the rollcenter with the camberlinks for high bite tracks only to tell you to lower the rollcenter with the lower blocks? Interesting...
The XRay guys learned a pretty big carpet/foam tire lesson at Cleveland this year. I was at the warm-up race when the XRay guys started flipping. The all raised the rollcenters on their cars when the traction came up and it made their cars tractionroll worse.
In the end, you can run whatever rollcenter location that you find makes the car handle the best unless the car starts tractionrolling. If there's so much traction that the car flips before it leans into the turn it's time to lower the rollcenter. Rollcenter is not the first thing to change if you're flipping though.
Unregistered is offline   Reply With Quote
Old 06-10-2004, 08:34 AM   #12799
rjl
rjl's Avatar
I think that sometimes too much is weight is placed on roll centre, ( ) it would be interesting to see those diagrams with the chassis rotated 5 degrees or so. I think that sometimes it's the arc scribed by the arms and links that makes the car handle differently. For us mortals the stock setting is pretty good on most club tracks.
rjl is offline   Reply With Quote
Old 06-10-2004, 04:28 PM   #12800
I wonder, should i buy the Prospec, or will Mugen release MTX4 within april next year???
Finken is offline   Reply With Quote
Old 06-10-2004, 07:50 PM   #12801
Smile
Well, my wonderful wife has blessed me with a brand new Mugen MTX-3. It's not the Prospect, but she got a HECK of a deal on it, compliments of E-bay!!!
I am looking at a motor for it, I am not going high end right now, trying to keep my costs down.
I am considering the OS motor, but don't know what the difference is between:
O.S. .12 TR w/10J Slide-Valve Carb
or the
O.S. .12 TR (P) w/10J Slide-Valve Carb
What does the (P) denote?
Also, what are some of the first Hop Ups to consider?
elmar66 is offline   Reply With Quote
Old 06-10-2004, 07:54 PM   #12802
alucard13's Avatar
I would have had my prospec yesterday but the postal service LOST THE PACKAGE. IDIOTS!!!!
alucard13 is offline   Reply With Quote
Old 06-10-2004, 07:57 PM   #12803
spawn's Avatar
or the
Congrats!, first thing to get is the front universals otherwise you will have to look for the front missing dogbones all the time on the track.
(P) denotes pilot shaft, you will have to run the pilot shaft in the Mugen.
spawn is offline   Reply With Quote
Old 06-10-2004, 08:09 PM   #12804
Registered User
HelpWanted's Avatar
Default Diff Oil
There's alot of good information being shared here and I am greatful for all inputs.
Regarding Differential fluid, how does using thicker or lighter fluid in the diff effect how the car perform? For instance, I am currently using 30K in the front and 10K in the rear. If I were to go lighter in the front, how would that effect the car? Same question for if I were to put thicker to the rear, how would that effect the car.
HelpWanted is offline   Reply With Quote
Old 06-10-2004, 08:20 PM   #12805
Send a message via AIM to Johnnytc3
The thicker the oil, the more the diff will behave like a solid.
Johnnytc3 is offline   Reply With Quote
Old 06-11-2004, 05:10 AM   #12806
BrainTeased's Avatar
May i ask what are the advantages of having a solid diff or a loose diff? and what are the disadvantages of them please, Ta
I thought mugens and RR evo etc... use SG cranks and that pilot shafts are for cars like VoneS's?
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 06-11-2004, 06:52 AM   #12807
Default Pilot Shaft or No Pilot Shaft?
Has anyone determined which motor is needed for the MTX-3?
Thanks!
Elmar
Old 06-11-2004, 06:52 AM   #12808
TAW
Trader Rating: 18 (100%+)
Send a message via AIM to TAW
Pilot shaft and SG crank are two names for the sme thing.
TAW is offline   Reply With Quote
Old 06-11-2004, 07:15 AM   #12809
Thanks for the clarification!!!!
Old 06-11-2004, 10:06 AM   #12810
Bandeira's Avatar
Send a message via ICQ to Bandeira
Hello guys...
I was taking a look at the Serpent Website and regarding clutch adjustments they say that the clutch housing should have minimal play, acquired but putting some shims between the bearing and the spring collar..
But I didn't see any Mugen guy playing with this endplay in mugen clutches. Assuming that both clutches are supposingly equal, if not, very similar, what this adjustment would bring?
Have you guys tryed this in our mugen clutches?
cheers...
Bandeira is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
