Old 06-07-2004, 05:39 PM   #12736
racecar850's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to racecar850 Send a message via Yahoo to racecar850 Send a message via Skype™ to racecar850
huh !
Originally posted by Bandeira
Quick question to see if you guys come with anything interesting...
Apart from rear toe-in, removing shims and cuting down the rear hub to chance roll center... using the A rear blocks, A-Ackerman, front hard swaybar... How would you decrease steering in the entry part of the curves?
Why would you want to do that ???????
Mugen MTX-4 :tire:
T-MAXX 3.3 :deathstar
MacBook...got fed up with pc :confused:
DRIVING...An inconvenient way of getting from A to B
racecar850 is offline   Reply With Quote
Old 06-07-2004, 05:45 PM   #12737
AMGRacer's Avatar
Are the rear A blocks the lower or higher roll centre adjustment?
AMGRacer is offline   Reply With Quote
Old 06-07-2004, 06:15 PM   #12738
rjl
rjl's Avatar
Less castor, less rear droop, less steering wheel movement.
rjl is offline   Reply With Quote
Old 06-07-2004, 06:25 PM   #12739
Bandeira's Avatar
Send a message via ICQ to Bandeira
All the suggested things were already done... I just couldn't list them all in the first post hehehheheheheheh
I wanted to do that because I fell the could be faster I didn't needed to control my turning so much in the first part of the turn... The car feels a lot twitchy in this part and I would prefer it not to...
Did you really Mean LESS caster or MORE caster?
'cause as far as I am concerned more caster would aid turning instability and reduce steering
Bandeira is offline   Reply With Quote
Old 06-07-2004, 06:34 PM   #12740
Try the B-Ackerman, this should reduce the initial turn-in.
I got to run the prospec yesterday. The stock setup is pretty good. The only things I changed were the B ackerman, A rear block (lower roll center), and 2 deg of rear camber. Pretty much hooked up for our track, even though I was only suppose to be running-in my new engine as well as the chassis.
darkangel is offline   Reply With Quote
Old 06-07-2004, 06:43 PM   #12741
Q
Q's Avatar
i know this is off topic for this thread but i trust everybodys opinion. especially if they own a mtx-3 . was looking to buy a tire truer and wanted opinions on the ofna truer. i have used and liked the hudy but to much $$$ . thanks in advance..
Q is offline   Reply With Quote
Old 06-07-2004, 07:05 PM   #12742
Bandeira's Avatar
I've always read that the B would increase the initial turn in...
Old 06-07-2004, 07:15 PM   #12743
Bivens's Avatar
Try it for yourself and see what it does......reading won't fully make you understand the effect on your car on your track.....besides....it only takes 5 minutes to change, run it, then change back if you don't like it.....It can't hurt...
I understand that the A is the most aggressive, followed by the B, then the C is mildest on initial turn in.......
(gotta be honest....I haven't tried all 3 either....just heard that the A is the most agressive and went that way......NOW that my curiosity is peaked....I think I'll try the other 2....just for fun....)
More rear wing....or move it further back on the body....THIS WILL FOR SURE take some twitch out of the car...especially at high speeds...... ...also...you could try a milder "flat-nose" body....don't know what you've got now....but this can work also...and...if nobody mentioned it....you can widen the front track...also a FOR SURE fix...
Bivens is offline   Reply With Quote
Old 06-07-2004, 07:22 PM   #12744
Bandeira's Avatar
Already did that... gave me good results...
5 mins for changing ackerman??? How do you do it? It took me 20mins the last time I did it!!!! Maybe the next time I should consider running softer rear springs and the B or even C ackerman and switch back to front 40shore tyres...
About the rear Roll center... I've had better results with the A-block... strange isn't it?
Old 06-07-2004, 08:50 PM   #12745
chippy's Avatar
A blocks used for high tracktion tracks
Less body roll Less side ways bite
So the A blocks lower the roll centre
chippy is offline   Reply With Quote
Old 06-07-2004, 09:17 PM   #12746
Send a message via AIM to Profoxcg
... Less body roll ... So the A blocks lower the roll centre
actually, I think that by having a lower roll center the car will roll more...
typically you raise your roll center to present the car from rolling.
however, in the case of this car,I guess that by raising the rear roll center, you are actually incresing overall roll. So you are correct, the lower the roll center the less roll...
Profoxcg is offline   Reply With Quote
Old 06-07-2004, 10:00 PM   #12747
gentleman81's Avatar
Default mtx 3 assembly/extra parts?
i am just waiting on a motor for my kar and besides the clutch parts and the throttle linkage parts i have three small plastic parts left from the kit, any body have any parts left after assembly? i was very patient with putting it together and even i have went back throught the book but i dont see them, no pics at this time.
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 06-07-2004, 10:04 PM   #12748
they are for the mugen started box
Old 06-07-2004, 10:07 PM   #12749
thanks thats a good thing to hear, i was like o no.
Old 06-07-2004, 10:09 PM   #12750
is there an easy way to change the part of the rear susp, that is up in the car a ways, the one that is labeled A, B, C. the back plate is easy so is the servo saver one but do u have to gut the back of the car to get to that other piece?
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
