Old 06-05-2004, 04:14 AM   #12676
BrainTeased's Avatar
Hi guys
16/19 topic.
What if we were to use newer front foams with like 50% foam tread left on the rear is this like the same effect as a front overdrive 16/19 thingy? im just asking out of curiousty. As today i learnt a lesson where my fronts were low and my rears where high (in terms of foam tread % left.) and the car kept spining or loosing control when giving the it power out of the corners. I was then told that because the rear wheels have more of a diameter the rear wheels are forced to push the front of the car.
Then i shoved on a brand new set and the car handled like it was on rails.
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 06-05-2004, 04:29 AM   #12677
Taylor-Racing's Avatar
Let's be clear; when you install the 16/19 conversion, you overdrive the front pulley. i.e. the front wheels now spin faster than the rears.
When you then true the front tyres to ~4mm smaller than the rears, you restore the overall gearing to 1:1.
Taylor-Racing is offline   Reply With Quote
Old 06-05-2004, 05:15 AM   #12678
sbmon's Avatar
16 19 conversion
Bivens Thank you for answering my questions concerning tire wear with the conversion and all of the other information you have provided, I may give the conversion a try in the near future. I also agree with you about more tuning options for the car like 1/8 cars. But with these extra tuning options comes the ability to tune the car right out of the ball park, which I would hate to see a newbie do to this car. Even though the mtx3 has a very large suspension tuning sweet spot it can be put out of whack from poor adjustments, and the last thing a newbie needs is an ill handling car. My rambling point here is nothing new and directed to newbies spend your dough on tires and fuel the car is extremely competitive stock (and i don't mean prokit stock).
sbmon is offline   Reply With Quote
Old 06-05-2004, 08:00 AM   #12679
When do you guys set track width (199,200 etc) before or after setting camber and toe? I noticed if you set your toe after you set the width of the car it gets wider.
czotalis is offline   Reply With Quote
Old 06-05-2004, 09:36 AM   #12680
mckrooz's Avatar
Send a message via AIM to mckrooz
Kyosho RRR Evo2
mckrooz is offline   Reply With Quote
Old 06-05-2004, 11:27 AM   #12681
Send a message via ICQ to Cartman
set width then toe but dont adjust rear pivots do say front ball in 1/2 turn rear out 1/2 turn that keeps your hub center same
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 06-05-2004, 12:45 PM   #12682
Bivens's Avatar
But....the stock setup is still great....you can always start there...make one change at a time until you fully understand the car...
Exactly the same concept as putting the conversion on the car without running smaller fronts.......Overdrive ratio well above 1.00....Gets really noticable on low-bite tracks and with OD ratios above 1.03.......
I'd just like to encourage everyone to keep an open mind...the best way to learn about the car is to try every possible adjustment (one-at-a-time) and know what happens with your car with those track conditions........for example....
One of the best tips I've tried to get rear traction on low-bite tracks is to cut-down the rear uprights (like the rubber-tire guys do in UK).....I think I learned about this from Cartman MANY pages ago in this thread.....(it works with foam tires also......anytime you need more rear bite mid-corner to off corner......)
Most people wouldn't try to tune a nice car like a MTX-3 with a hacksaw....but I have an open mind......and the rear uprights were a cheap replacement if it didn't work........
For all of you afraid of trying the 16/19 conversion....the cost is less than $10........give it a shot and see if YOU like it....that's what practice is for.......
Bivens is offline   Reply With Quote
Old 06-05-2004, 02:38 PM   #12683
rcmike's Avatar
Trader Rating: 40 (100%+)
Default Bivens
Hi,Is there any way you can send a picture of the way you did the rear upright to me. I understand what your saying but just want to make sure its the same idea" Thanks if you can [email protected]
rcmike is offline   Reply With Quote
Old 06-05-2004, 04:26 PM   #12684
Send a message via AIM to goldenboy
hey mtx3 guys, do any of you know the bearing size that goes inside the clutch bell, on the inner side, i am using a mtx3 clutch bell on my r40, and i need a new bearing. but i dont have the instruction book for the mtx3 so i dont know what size it is. if you could tell me that would be great
thanks
goldenboy is offline   Reply With Quote
Old 06-05-2004, 05:03 PM   #12685
Send a message via AIM to Johnnytc3
they are 5x10 bearings
Johnnytc3 is offline   Reply With Quote
Old 06-05-2004, 05:47 PM   #12686
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default SPOOL !
Originally posted by Profoxcg
Can you run a spool in the front of a mugen? who makes it?
thanks !
kAWAHARA MAKES A SPOOL KIT, i TRIED IT AT THE tEXAS bIGGIE AND IT WAS AWSOME!
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 06-05-2004, 07:55 PM   #12687
ok i got the bearings. and when i screw down the clutch bell, i cant move it, so i dont think the shoes will be able to expand. where do i need to add shims to make it move a little bit?? if i can.
Old 06-05-2004, 07:58 PM   #12688
Make sure you installed it right, usually when you install it, there should be a lot of play , hence the need for shims.
Old 06-05-2004, 08:04 PM   #12689
i am pretty sure i installed it correctly, if i did that means that it wont work on the r40, dang!
Old 06-05-2004, 08:06 PM   #12690
make sure you when you screw on the centex adjusting nut, there should be about 2mm of the threads exposing.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
